MikeL Posted November 18, 2018 Posted November 18, 2018 (edited) In the last weeks I've successfully installed Armbian Debian Stretch 5.59 onto a Banana Pi M2 Berry, now I'm trying with a Banana Pi M1. From https://www.armbian.com/bananapi/ I've downloaded the Debian Stretch image and wrote it to my 4GB SD-card using Etcher (on Windows 10) - Etcher meant it was successfully after writing. I've safely ejected the SD-card from Windows, plugged it into the Banana Pi M, but it tries to boot from the network. Then I've taken a look at https://dl.armbian.com/bananapi/archive/ and downloaded Armbian-5.59 Debian Stretch image, wrote it with Etcher again, booted. Same issue. It shows a red armbian logo with "initializing boot loader" and below output (typed from screenshots, so there might be typos): HDMI connected: Setting up a 1920x1080 hdmi console (overscan 0x0) Error: no valid bmp image at 66000000 In: serial Out: vga Err: vga SCSI: SATA link 0 timeout AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst Net: eth0: ethernet@01c50000 230454 bytes read in 32 ms (6.9 MiB/s) starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning bus 1 for devices... 1 USB Device(s) found scanning bus 3 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop scanning bus for devices... Found 0 device(s). Device 0: not available Device 0: device type unknown ... is now current device ** Bad device usb 0** ** Bad device usb 0** ethernet@01c50000 Waiting for PHY auto negotiation to complete ........... TIMEOUT ! Could not initialze PHY ethernet@01c500000 missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 ethernet@01c50000 Waiting for PHY auto negotiation to complete ........... TIMEOUT ! Could not initialze PHY ethernet@01c500000 => How to convince it to boot to the normal login prompt? Mike Edited November 18, 2018 by MikeL
MikeL Posted November 19, 2018 Author Posted November 19, 2018 No idea what could cause the problem? Is it the right image for this Banana Pi M1? Is there something I should check on the SD card using a Linux? I don't have a TTL-to-USB serial adapter.
martinayotte Posted November 19, 2018 Posted November 19, 2018 23 minutes ago, MikeL said: I don't have a TTL-to-USB serial adapter. Those are really helpful to have some in your toolbox, they are pretty cheap, around US$1 ... If you had some, I would ask you to press <space> at u-boot prompt and do "mmc info" to see why u-boot doesn't find the SDCard. Maybe the SDCard detect pin is broken on your board ...
MikeL Posted November 20, 2018 Author Posted November 20, 2018 Thank you for answering. If the SD card could not be detected, shouldn't it behave as there would be no SD card inserted? I'm asking because I've tried that and got no output at all. So from my naive understanding it seems to have found the SD card.
MikeL Posted November 20, 2018 Author Posted November 20, 2018 I followed the SD card trail and tried a different SD card (16 GB micro-SD with SD-Adapter instead of the 4 GB full size SD). I noticed a click when inserting while the normal SD card made none, but could not be inserted farther. And now it booted. Very odd.
martinayotte Posted November 20, 2018 Posted November 20, 2018 2 hours ago, MikeL said: I noticed a click when inserting while the normal SD card made none, but could not be inserted farther. And now it booted. Very odd. Some people experienced even worst issue than your : completely broken detect pin ! In this case, the only workarounds are to either solder wire to ground, or edit Main DT to remove the detect pin declaration and/or having custom compiled u-boot.
niccodemi Posted November 20, 2018 Posted November 20, 2018 @martinayotte I've got Banana pi M1 with broken sd card detect pin (pad is delaminated and I cannot solder it to ground). Do you know which part of "Main DT" to edit in order to remove detect pin declaration?
martinayotte Posted November 21, 2018 Posted November 21, 2018 12 hours ago, niccodemi said: o you know which part of "Main DT" to edit the "cd-gpio" in "mmc" node should be removed and "broken-cd" should be added. https://www.kernel.org/doc/Documentation/devicetree/bindings/mmc/mmc.txt
niccodemi Posted November 22, 2018 Posted November 22, 2018 @martinayotte Thanks a lot, it worked. For anyone else looking for solution; below file has to be changed; patch created and then image built (with patch placed in build\userpatches\kernel\sunxi-next) build\cache\sources\linux-mainline\linux-4.14.y\arch\arm\boot\dts\sun7i-a20-bananapi.dts &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_bananapi>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; broken-cd; cd-inverted; status = "okay"; };
