martinayotte Posted December 31, 2018 Share Posted December 31, 2018 Hi to all Armbian Devs, According to my local experience done today with newly Ayufan's 4.20.0 tag done this morning, it seems to be quite ready ... (Except for my failure to get eMMC running on RockPro64, but works well on OPi-RK3399 and NanoPC-T4) So, I'm asking you if I should commit all those stuff !!! @TonyMac32 during those builds, I see 2 patches broken, I didn't investigated, but maybe those patches are simply not relevant anymore and can be deleted : [ warn ] * [l][c] renegade-add-uhs.patch [ failed ] [ warn ] * [l][c] rk3328-add-GRF-GPIO.patch [ failed ] One my side, I need to fix some patches too : [[[0;35m warn [[0m] * [[[32ml[[0m][[[32mc[[0m] fix-rockpro64-pmic-int-l.patch [[[0;33m failed [[0m] [[[0;35m warn [[0m] * [[[32ml[[0m][[[32mc[[0m] general-add-overlay-compilation-support.patch [[[0;33m failed [[0m] The first one is not relevant : Ayufan fixed it already by cheery-picking my fix. Second one is not a big issue : "make dtbs" and "make dtbs-install" are not target anymore in 4.20.y, but DTB and DTBO for overlays seems to be build anyway, maybe embedded to "make Image" ... So, if all Devs involved give me "green light", I will push 4.20.0 changes ASAP !!! Link to comment Share on other sites More sharing options...
TonyMac32 Posted December 31, 2018 Share Posted December 31, 2018 The grf patch should be part of the 4.20, so that's ok, UHS should likewise be unneeded, but I'll check itSent from my Pixel using Tapatalk Link to comment Share on other sites More sharing options...
martinayotte Posted December 31, 2018 Author Share Posted December 31, 2018 I've done a build for Rock64 too, it's eMMC working too, but since there is no native WiFi there, I've a RTL8188ETV dongle ... It's connection seems to fail while it wasn't on 4.19.y ... Link to comment Share on other sites More sharing options...
TonyMac32 Posted December 31, 2018 Share Posted December 31, 2018 Ok, the UHS and GRF-GPIO patches are both superseded and present upstream. only note from patches: To use this feature, the following options are required in kernel config: - CONFIG_GPIO_SYSCON=y - CONFIG_POWER_AVS=y - CONFIG_ROCKCHIP_IODOMAIN=y Link to comment Share on other sites More sharing options...
TonyMac32 Posted December 31, 2018 Share Posted December 31, 2018 Last note on eMMC https://github.com/ayufan-rock64/linux-mainline-kernel/commit/686e1f1aa461afd4100a18f0374a59e86b23069b Link to comment Share on other sites More sharing options...
martinayotte Posted December 31, 2018 Author Share Posted December 31, 2018 9 hours ago, TonyMac32 said: Last note on eMMC Interesting ! I will try that ... With this extraargs, it is working !!! Thanks a lot, @TonyMac32 ! Link to comment Share on other sites More sharing options...
belfastraven Posted January 3, 2019 Share Posted January 3, 2019 Is any one else having problems with USB3 devices on rock64 with the 4.20 kernel? U-boot seems to recognize that the device (a Samsung T1 ssd) is there but once I get the kernel starting message there is no power to the device. I can boot the that device on the 4.19-rc4 kernel. Link to comment Share on other sites More sharing options...
TonyMac32 Posted January 3, 2019 Share Posted January 3, 2019 I'll take a look, my Rock64 is unfortunately a Rev 1, so there are some differences, but I don't think any are in the USB pathway. On my Renegade (similar) I seem to be having trouble with one of the USB 2.0 ports, still debugging. Link to comment Share on other sites More sharing options...
TonyMac32 Posted January 3, 2019 Share Posted January 3, 2019 Well, mine will talk to various devices over USB3, so I can't reproduce the issue I'm afraid. Link to comment Share on other sites More sharing options...
belfastraven Posted January 3, 2019 Share Posted January 3, 2019 thanks. I did try device in the bottom usb2 port and it still got no power. I'm going to try it on a powered hub to see if it is somehow a powersupply issue. I didn't notice any change in the device tree that would cause this.... . Link to comment Share on other sites More sharing options...
martinayotte Posted January 3, 2019 Author Share Posted January 3, 2019 I've both bottom and upper USB working on my Rock64 with 4.20.0 ... Link to comment Share on other sites More sharing options...
belfastraven Posted January 4, 2019 Share Posted January 4, 2019 Thanks everyone for checking on this. In my case, I have narrowed the problematic devices down to USB storage devices (all are USB3--don't have any 2's). I've tested with the samsung T1, a WD Passport HD, a Sandisk USB stick--in no cases are they recognized by the rock64 on 4.20 On a RockPro64 (3399) with the 4.20 kernel. they are all powered on and recognized when I plug them in. I notice that the uas module is not loaded on the rock64 I boot the device with one of those plugged in. I tried force loading it using initramfs, and it loads, but the device(s) is still not available. As I mentioned before, I was actually booting from the Samsung t1 on the 4.19 kernel. If any one want to see logs--I have a great number of them :-). If noone else is seeing this, though, I just keep trying to figure out what is broken. thanks again. Link to comment Share on other sites More sharing options...
