Daniel26 Posted January 16, 2019 Posted January 16, 2019 Hello, what is the correct way to install x2goserver on armbian? Which repos to use? Regards Daniel
Tido Posted January 16, 2019 Posted January 16, 2019 Hi Daniel, try the searchbox in the right hand corner with: x2go
JMCC Posted January 16, 2019 Posted January 16, 2019 Depends on your board. If it's armhf, you can use Raspbian Stretch repos, otherwise you may need to build. I recommend to build from source in any case, I did it once and didn't take long. https://wiki.x2go.org/doku.php/wiki:repositories:raspbian 1
