Hi! I was using armbian 5.60 with 4.14.70 kernel and WiFi AP worked flawsessly.
Today I had to rebuild my sd card, so I downloaded the latest available build  Armbian Stretch mainline kernel 4.19.y
I can connect to WiFi from the board, also able to setup a WiFi AP on the board. But when I try to connect to the new AP I see the following message in terminal and the connecting device fails after several seconds:
Message from syslogd@localhost at Jan 17 18:20:38 ...
 kernel:[  349.842020] Internal error: Oops: 96000004 [#1] SMP
 kernel:[  350.021242] Process RTW_CMD_THREAD (pid: 607, stack limit = 0x0000000068aba9f4)
 kernel:[  350.069577] Code: f9405ae0 a90a0ba0 11000421 8b02001b (b8626800)
Edited by maxbl4
Here is the output from main console.
I got this with the latest Ubuntu based build.
The errors appear once I try to connect to AP
Downloaded 5.59 stretch image from archive. Clean install, no updates. AP works fine, no problems, no errors on console.
