overlays=w1-gpio spi-spidev are not working anymore since upgrade to 4.19.13-sunxi
Hi, my overlays=w1-gpio spi-spidev are not working anymore since I upgraded from 4.14.84-sunxi to 4.19.13-sunxi (Banana Pi with armbian 5.70).
Regarding the 1-wire protocol cat /sys/bus/w1/devices/*/w1_slave responds "No such file or directory" since the upgrade.
Also regarding the spi overlay  # ls /dev/spi* should result in  /dev/spidev0.0 whereas kernel 4.19 says "cannot access /dev/spi*: No such file or directory".
All was working fine with the 4.14 kernel.
thanks in advance
What is shown in u-boot log during booting ? Do you see any errors ?
Sorry that it took so long, but serial boot debugging there is misleading info out there, like at http://linux-sunxi.org/LeMaker_Banana_Pi.
In opposite of what is drawn there, I found UART0 wired to J11 (1x2 header). Also the baud rate is 115200 and not 9600 as other sites suggest.
So I also tried to get w1-wire and spi working with kernel 4.19.13 using a new installation (Armbian_5.69_Bananapi_Debian_stretch_next_4.19.13.img) - showing the same results.
Here is my boot-output:
U-Boot SPL 2018.05-armbian (Jan 09 2019 - 16:25:26 +0100)
DRAM: 1024 MiB
CPU: 912000000Hz, AXI/AHB/APB: 3/2/2
Trying to boot from MMC1
U-Boot 2018.05-armbian (Jan 09 2019 - 16:25:26 +0100) Allwinner Technology
CPU:   Allwinner A20 (SUN7I)
Model: LeMaker Banana Pi
I2C:   ready
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
Failed (-5)
Setting up a 720x576i composite-pal console (overscan 32x20)
Error: no valid bmp image at 66000000
In:    serial
Out:   vga
Err:   vga
SCSI:  SATA link 0 timeout.
AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: ncq stag pm led clo only pmp pio slum part ccc apst
Net:   eth0: ethernet@01c50000
230454 bytes read in 28 ms (7.8 MiB/s)
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3798 bytes read in 24 ms (154.3 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
272 bytes read in 19 ms (13.7 KiB/s)
4948290 bytes read in 308 ms (15.3 MiB/s)
6906880 bytes read in 417 ms (15.8 MiB/s)
40331 bytes read in 76 ms (517.6 KiB/s)
777 bytes read in 131 ms (4.9 KiB/s)
Applying kernel provided DT overlay sun7i-a20-w1-gpio.dtbo
1057 bytes read in 127 ms (7.8 KiB/s)
Applying kernel provided DT overlay sun7i-a20-spi-spidev.dtbo
5925 bytes read in 119 ms (47.9 KiB/s)
Applying kernel provided DT fixup script (sun7i-a20-fixup.scr)
## Executing script at 44000000
libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND
tmp_bank=H
tmp_pin=20
Sorry, I could not convert " 7 20 0>"
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    4948226 Bytes = 4.7 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
   Loading Ramdisk to 49b47000, end 49fff102 ... OK
   reserving fdt memory region: addr=43000000 size=70000
   Loading Device Tree to 49ad4000, end 49b46fff ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
?H?Debian GNU/Linux 9 bananapi ttyS0
Here is my armbianEnv.txt:
verbosity=1
logo=disabled
console=both
disp_mode=1920x1080p60
overlay_prefix=sun7i-a20
rootdev=UUID=85fff9ba-cebc-4404-98b3-05ec04f392be
rootfstype=ext4
param_spidev_spi_bus=0
param_w1_pin=PH20
-thanks-
tmp_bank=H
tmp_pin=20
Those errors have been fixed 11 days ago with this commit : https://github.com/armbian/build/commit/592c8bd76b006c64564d88145c867f231e5e3791
Please, take a newer build or do your own build using Armbian scripts : https://docs.armbian.com/Developer-Guide_Build-Preparation/
