Hi there,
I'm currently working on cross compiling libva-v4l2-request to test the VPU on the Allwinner V3s. I cloned the master branch from Github and told autoreconf to cross compile, but however it keeps looking for the wrong libva and libdrm libraries. Also everything with arm-linux-gnueabi fails somehow.
I hope someone can help me with that.
user@workpad:~/workspace/allwinnerV3s/libva-v4l2-request$ ./autogen.sh --host=arm-linux-gnueabi --build=x86_64-linux-gnu
autoreconf: Entering directory `.'
autoreconf: configure.ac: not using Gettext
autoreconf: running: aclocal
autoreconf: configure.ac: tracing
autoreconf: running: libtoolize --copy
libtoolize: Consider adding 'AC_CONFIG_MACRO_DIRS([m4])' to configure.ac,
libtoolize: and rerunning libtoolize and aclocal.
libtoolize: Consider adding '-I m4' to ACLOCAL_AMFLAGS in Makefile.am.
autoreconf: running: /usr/bin/autoconf
autoreconf: running: /usr/bin/autoheader
autoreconf: running: automake --add-missing --copy --no-force
autoreconf: Leaving directory `.'
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for arm-linux-gnueabi-strip... no
checking for strip... strip
configure: WARNING: using cross tools not prefixed with host triplet
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether UID '1000' is supported by ustar format... yes
checking whether GID '1000' is supported by ustar format... yes
checking how to create a ustar tar archive... gnutar
checking whether make supports nested variables... (cached) yes
checking build system type... x86_64-pc-linux-gnu
checking host system type... arm-unknown-linux-gnueabi
checking how to print strings... printf
checking for style of include used by make... GNU
checking for arm-linux-gnueabi-gcc... no
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... yes
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... no
checking for arm-linux-gnueabi-dumpbin... no
checking for arm-linux-gnueabi-link... no
checking for dumpbin... no
checking for link... link -dump
checking the name lister (nm) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking how to convert x86_64-pc-linux-gnu file names to arm-unknown-linux-gnueabi format... func_convert_file_noop
checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for arm-linux-gnueabi-objdump... no
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for arm-linux-gnueabi-dlltool... no
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for arm-linux-gnueabi-ar... no
checking for ar... ar
checking for archiver @FILE support... @
checking for arm-linux-gnueabi-strip... strip
checking for arm-linux-gnueabi-ranlib... no
checking for ranlib... ranlib
checking command to parse nm output from gcc object... ok
checking for sysroot... no
checking for a working dd... /bin/dd
checking how to truncate binary pipes... /bin/dd bs=4096 count=1
checking for arm-linux-gnueabi-mt... no
checking for mt... mt
checking if mt is a manifest tool... no
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking for arm-linux-gnueabi-gcc... gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether gcc understands -c and -o together... (cached) yes
checking dependency style of gcc... (cached) gcc3
checking whether byte ordering is bigendian... no
checking for ANSI C header files... (cached) yes
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking for sin in -lm... yes
checking for arm-linux-gnueabi-pkg-config... no
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for DRM... yes
checking for LIBVA_DEPS... yes
checking for LIBVA_DRM_DEPS... yes
checking for MPEG2 support... no
checking for H.264 support... no
checking for H.265 support... no
checking for VA drivers path... /usr/lib/x86_64-linux-gnu/dri
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating src/autoconfig.h
config.status: src/autoconfig.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
v4l2_request configuration summary:
VA-API version ................... : 1.1.0
VA-API drivers path .............. : /usr/lib/x86_64-linux-gnu/dri
H.264 support .................... : no
H.265 support .................... : no
MPEG2 support .................... : no
Since these kind of libraries are not too big, I usually compile them natively on an ARM board. V3s' CPU may be a little too weak, but you can do it on any other armhf board you have, and it won't take more than a few minutes.
Thanks, I will give it a try. Since this is a compiled library, where I should put the compiled files ? And do I have to create systemlinks or something similiar?
Hello @petit_miner,
How is the status of your hardware?  Is it good enough to be built for evaluation?  I want to do something similar, and have some V3s's laying about because of it that need a home.  :lol:
I think so, but I would suggest that you try the 4 Layer version. It has more interfaces (VGA out) and also uses 3 seperate DC DC step down modules which are easy to solder. I haven't tested the HDMI IN (ADV7611) yet, but every other interface works flawlessly.
However I made a mistake while exporting the gerber files from eagle, the pcb misses the hole for the strain relief of the ethernet jack. It isn't that critical since the strain relief is made of plastic and you can easily cut it. If you want to I can sell you a bare PCB.
