Karolis Marksaitis Posted February 7, 2019 Posted February 7, 2019 Hi, I have this latest ESPRESSObin v7 board. It doe's not boot official Armbian BIONIC. I have used Armbian before on other chips and I am pretty confident I am following the instructions correctly. Steps I did to get it going: 1. I followed official instructions to flash u-boot with bubt tool to it's latest version. My board is DDR4, 1GB,1 ram chip, 1000cpu,800ram. I got the right one - as all works just fine after a reset. Also applied relevant boot environment as instructed here https://www.armbian.com/espressobin/ 2. I have then used etcher to burn SD card with bionic. Tried to boot - didn't work. Only getting call traces in kernel log. 3. I burned a flash stick and tried to boot from it over USB3 port - same result. kernel traces. 4. Just tried again with same USB - it all booted as i'm writing. I was greeted with linux login prompt. I thought all good. Then in 10 seconds after, without clicking anything - it failed with kernel error. Full log attached below. Beginning of it you can see kernel log of a failed boot attempt. Then after I hit reset - you will see that it booted to login prompt as normal - and then shortly after it failed. [ 971.024128] kthread+0x128/0x130 [ 971.027443] ret_from_fork+0x10/0x1c [ 971.031115] rcu: INFO: rcu_sched detected stalls on CPUs/tasks: [ 971.037212] rcu: 0-...!: (29 ticks this GP) idle=c42/1/0x4000000000000002 softirq=76/91 fqs=88 [ 971.046256] rcu: (detected by 1, t=241577 jiffies, g=-1183, q=53) [ 971.052618] Task dump for CPU 0: [ 971.055933] rcu_preempt R running task 0 10 2 0x0000002a [ 971.063190] Call trace: [ 971.065703] __switch_to+0x94/0xd8 [ 971.069197] schedule_timeout+0x1c4/0x368 [ 971.073318] rcu_gp_kthread+0x48c/0x840 [ 971.077260] kthread+0x128/0x130 [ 971.080577] ret_from_fork+0x10/0x1c [ 971.084252] rcu: rcu_sched kthread starved for 241397 jiffies! g-1183 f0x2 RCU_GP_WAIT_FQS(5) ->state=0x0 ->cpu=1 [ 971.094819] rcu: RCU grace-period kthread stack dump: [ 971.100016] rcu_sched R running task 0 11 2 0x00000028 [ 971.107274] Call trace: [ 971.109786] __switch_to+0x94/0xd8 [ 971.113281] __schedule+0x1e4/0x618 [ 971.116865] schedule+0x38/0xa0 [ 971.120089] schedule_timeout+0x90/0x368 [ 971.124121] rcu_gp_kthread+0x48c/0x840 [ 971.128064] kthread+0x128/0x130 [ 971.131378] ret_from_fork+0x10/0x1c [ 1033.956483] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks: [ 1033.959908] rcu: 0-...!: (1 ticks this GP) idle=c42/1/0x4000000000000002 softirq=91/91 fqs=0 [ 1033.968771] rcu: (detected by 1, t=257332 jiffies, g=-931, q=10717) [ 1033.975312] Task dump for CPU 0: [ 1033.978628] rcu_preempt R running task 0 10 2 0x0000002a [ 1033.985884] Call trace: [ 1033.988397] __switch_to+0x94/0xd8 [ 1033.991891] schedule_timeout+0x1c4/0x368 [ 1033.996012] rcu_gp_kthread+0x48c/0x840 [ 1033.999955] kthread+0x128/0x130 [ 1034.003270] ret_from_fork+0x10/0x1c [ 1034.006946] rcu: rcu_preempt kthread starved for 257332 jiffies! g-931 f0x2 RCU_GP_WAIT_FQS(5) ->state=0x0 ->cpu=0 [ 1034.017603] rcu: RCU grace-period kthread stack dump: [ 1034.022801] rcu_preempt R running task 0 10 2 0x0000002a [ 1034.030058] Call trace: [ 1034.032569] __switch_to+0x94/0xd8 [ 1034.036063] schedule_timeout+0x1c4/0x368 [ 1034.040185] rcu_gp_kthread+0x48c/0x840 [ 1034.044128] kthread+0x128/0x130 [ 1034.047442] ret_from_fork+0x10/0x1c [ 1034.051114] rcu: INFO: rcu_sched detected stalls on CPUs/tasks: [ 1034.057212] rcu: 0-...!: (29 ticks this GP) idle=c42/1/0x4000000000000002 softirq=76/91 fqs=88 [ 1034.066256] rcu: (detected by 1, t=257332 jiffies, g=-1183, q=53) [ 1034.072618] Task dump for CPU 0: [ 1034.075934] rcu_preempt R running task 0 10 2 0x0000002a [ 1034.083190] Call trace: [ 1034.085703] __switch_to+0x94/0xd8 [ 1034.089197] schedule_timeout+0x1c4/0x368 [ 1034.093318] rcu_gp_kthread+0x48c/0x840 [ 1034.097260] kthread+0x128/0x130 [ 1034.100576] ret_from_fork+0x10/0x1c [ 1034.104252] rcu: rcu_sched kthread starved for 257152 jiffies! g-1183 f0x2 RCU_GP_WAIT_FQS(5) ->state=0x0 ->cpu=1 [ 1034.114819] rcu: RCU grace-period kthread stack dump: [ 1034.120016] rcu_sched R running task 0 11 2 0x00000028 [ 1034.127274] Call trace: [ 1034.129786] __switch_to+0x94/0xd8 [ 1034.133280] __schedule+0x1e4/0x618 [ 1034.136865] schedule+0x38/0xa0 [ 1034.140089] schedule_timeout+0x90/0x368 [ 1034.144121] rcu_gp_kthread+0x48c/0x840 [ 1034.148064] kthread+0x128/0x130 [ 1034.151379] ret_from_fork+0x10/0x1c [ 1096.976483] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks: [ 1096.979908] rcu: 0-...!: (1 ticks this GP) idle=c42/1/0x4000000000000002 softirq=91/91 fqs=0 [ 1096.988772] rcu: (detected by 1, t=273087 jiffies, g=-931, q=10717) [ 1096.995313] Task dump for CPU 0: [ 1096.998628] rcu_preempt R running task 0 10 2 0x0000002a [ 1097.005884] Call trace: [ 1097.008399] __switch_to+0x94/0xd8 [ 1097.011892] schedule_timeout+0x1c4/0x368 [ 1097.016012] rcu_gp_kthread+0x48c/0x840 [ 1097.019956] kthread+0x128/0x130 [ 1097.023271] ret_from_fork+0x10/0x1c [ 1097.026946] rcu: rcu_preempt kthread starved for 273087 jiffies! g-931 f0x2 RCU_GP_WAIT_FQS(5) ->state=0x0 ->cpu=0 [ 1097.037604] rcu: RCU grace-period kthread stack dump: [ 1097.042801] rcu_preempt R running task 0 10 2 0x0000002a [ 1097.050057] Call trace: [ 1097.052570] __switch_to+0x94/0xd8 [ 1097.056064] schedule_timeout+0x1c4/0x368 [ 1097.060185] rcu_gp_kthread+0x48c/0x840 [ 1097.064128] kthread+0x128/0x130 [ 1097.067444] ret_from_fork+0x10/0x1c [ 1097.071115] rcu: INFO: rcu_sched detected stalls on CPUs/tasks: [ 1097.077212] rcu: 0-...!: (29 ticks this GP) idle=c42/1/0x4000000000000002 softirq=76/91 fqs=88 [ 1097.086256] rcu: (detected by 1, t=273087 jiffies, g=-1183, q=53) [ 1097.092618] Task dump for CPU 0: [ 1097.095934] rcu_preempt R running task 0 10 2 0x0000002a [ 1097.103191] Call trace: [ 1097.105703] __switch_to+0x94/0xd8 [ 1097.109197] schedule_timeout+0x1c4/0x368 [ 1097.113318] rcu_gp_kthread+0x48c/0x840 [ 1097.117261] kthread+0x128/0x130 [ 1097.120576] ret_from_fork+0x10/0x1c [ 1097.124252] rcu: rcu_sched kthread starved for 272907 jiffies! g-1183 f0x2 RCU_GP_WAIT_FQS(5) ->state=0x0 ->cpu=1 [ 1097.134819] rcu: RCU grace-period kthread stack dump: [ 1097.140017] rcu_sched R running task 0 11 2 0x00000028 [ 1097.147275] Call trace: [ 1097.149786] __switch_to+0x94/0xd8 [ 1097.153281] __schedule+0x1e4/0x618 [ 1097.156865] schedule+0x38/0xa0 [ 1097.160090] schedule_timeout+0x90/0x368 [ 1097.164121] rcu_gp_kthread+0x48c/0x840 [ 1097.168064] kthread+0x128/0x130 [ 1097.171379] ret_from_fork+0x10/0x1c TIM-1.0 WTMI-devel-18.12.0-a0a1cb8 WTMI: system early-init SVC REV: 4, CPU VDD voltage: 1.120V NOTICE: Booting Trusted Firmware NOTICE: BL1: v1.5(release):1f8ca7e (Marvell-devel-18.12.2) NOTICE: BL1: Built : 13:50:08, Dec 26 2018 NOTICE: BL1: Booting BL2 NOTICE: BL2: v1.5(release):1f8ca7e (Marvell-devel-18.12.2) NOTICE: BL2: Built : 13:50:09, Dec 26 2018 NOTICE: BL1: Booting BL31 NOTICE: BL31: v1.5(release):1f8ca7e (Marvell-devel-18.12.2) NOTICE: BL31: Built : 13:5 U-Boot 2018.03-devel-18.12.3-gc9aa92c-armbian (Dec 26 2018 - 13:45:06 +0100) Model: Marvell Armada 3720 Community Board ESPRESSOBin CPU 1000 [MHz] L2 800 [MHz] TClock 200 [MHz] DDR 800 [MHz] DRAM: 1 GiB Comphy chip #0: Comphy-0: USB3 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 6 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link down MMC: sdhci@d0000: 0 Loading Environment from SPI Flash... SF: Detected mx25u3235f with page size 256 Bytes, erase size 64 KiB, total 4 MiB OK Model: Marvell Armada 3720 Community Board ESPRESSOBin Net: eth0: neta@30000 [PRIME] Hit any key to stop autoboot: 0 starting USB... USB0: Register 2000104 NbrPorts 2 Starting the controller USB XHCI 1.00 USB1: USB EHCI 1.00 scanning bus 0 for devices... 2 USB Device(s) found scanning bus 1 for devices... 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found / ** File not found /boot.scr ** ## Executing script at 06d00000 Wrong image format for "source" command /boot/ 1119 bytes read in 25 ms (43 KiB/s) ## Executing script at 06d00000 172 bytes read in 10 ms (16.6 KiB/s) 15897088 bytes read in 101 ms (150.1 MiB/s) 7879752 bytes read in 61 ms (123.2 MiB/s) ** File not found /boot/dtb/marvell/armada-3720-community.dtb ** 8942 bytes read in 16 ms (544.9 KiB/s) ## Loading init Ramdisk from Legacy Image at 01100000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 7879688 Bytes = 7.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 06000000 Booting using the fdt blob at 0x6000000 Loading Ramdisk to 3eea7000, end 3f62ac08 ... OK Using Device Tree in place at 0000000006000000, end 00000000060052ed Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 4.19.14-mvebu64 (root@nightly) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #5.69 SMP PREEMPT T9 [ 0.000000] Machine model: Globalscale Marvell ESPRESSOBin Board [ 0.000000] earlycon: ar3700_uart0 at MMIO 0x00000000d0012000 (options '') [ 0.000000] bootconsole [ar3700_uart0] enabled Loading, please wait... starting version 237 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.31.1 [/sbin/fsck.ext4 (1) -- /dev/sda1] fsck.ext4 -a -C0 /dev/sda1 /dev/sda1: clean, 34664/67104 files, 229938/268288 blocks done. done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. Welcome to Ubuntu 18.04.1 LTS! [ OK ] Reached target Remote File Systems. [ OK ] Created slice User and Session Slice. [ OK ] Started Forward Password Requests to Wall Directory Watch. [ OK ] Created slice System Slice. [ OK ] Listening on Journal Socket (/dev/log). [ OK ] Reached target Slices. [ OK ] Created slice system-serial\x2dgetty.slice. [ OK ] Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Listening on fsck to fsckd communication Socket. [ OK ] Listening on Syslog Socket. [ OK ] Listening on udev Kernel Socket. [ OK ] Listening on udev Control Socket. [ OK ] Listening on Journal Audit Socket. [ OK ] Reached target Swap. [ OK ] Reached target System Time Synchronized. [ OK ] Started ntp-systemd-netif.path. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ OK ] Reached target Local Encrypted Volumes. [ OK ] Listening on Journal Socket. Starting Create list of required st?…ce nodes for the current kernel... Starting Nameserver information manager... Starting Journal Service... Starting Remount Root and Kernel File Systems... Mounting Huge Pages File System... Mounting POSIX Message Queue File System... Starting udev Coldplug all Devices... Mounting Kernel Debug File System... Starting Load Kernel Modules... Starting Restore / save the current clock... Starting Set the console keyboard layout... [ OK ] Started Create list of required sta?…vice nodes for the current kernel. [ OK ] Started Journal Service. [ OK ] Started Remount Root and Kernel File Systems. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Started Load Kernel Modules. [ OK ] Started Restore / save the current clock. [ OK ] Started Nameserver information manager. [ OK ] Reached target Network (Pre). Mounting Kernel Configuration File System... Starting Apply Kernel Variables... Starting Load/Save Random Seed... Starting Flush Journal to Persistent Storage... Starting Create Static Device Nodes in /dev... [ OK ] Mounted Kernel Configuration File System. [ OK ] Started Load/Save Random Seed. [ OK ] Started Apply Kernel Variables. [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started Create Static Device Nodes in /dev. Starting udev Kernel Device Manager... [ OK ] Started udev Coldplug all Devices. [ OK ] Started udev Kernel Device Manager. [ OK ] Started Set the console keyboard layout. [ OK ] Reached target Local File Systems (Pre). Mounting /tmp... [ OK ] Mounted /tmp. [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... Starting Raise network interfaces... Starting Armbian ZRAM config... Starting Set console font and keymap... [ OK ] Started Set console font and keymap. [ OK ] Started Create Volatile Files and Directories. Starting Network Name Resolution... Starting Network Time Synchronization... Starting Update UTMP about System Boot/Shutdown... [ OK ] Started Entropy daemon using the HAVEGE algorithm. [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started Network Time Synchronization. [ OK ] Started Network Name Resolution. [ OK ] Reached target Host and Network Name Lookups. [ OK ] Found device /dev/ttyMV0. [ OK ] Started Raise network interfaces. [ OK ] Started Armbian ZRAM config. Starting Armbian memory supported logging... [ OK ] Started Armbian memory supported logging. [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. Starting Armbian hardware monitoring... [ OK ] Started Daily apt download activities. [ OK ] Started resolvconf-pull-resolved.path. [ OK ] Reached target Paths. [ OK ] Started Daily apt upgrade and clean activities. [ OK ] Started Discard unused blocks once a week. [ OK ] Started Message of the Day. [ OK ] Reached target Timers. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Reached target Sockets. Starting Armbian filesystem resize... Starting Armbian hardware optimization... [ OK ] Started Armbian hardware monitoring. [ OK ] Started Armbian hardware optimization. [ OK ] Started Armbian filesystem resize. [ OK ] Reached target Basic System. Starting Resets System Activity Data Collector... Starting resolvconf-pull-resolved.service... Starting Dispatcher daemon for systemd-networkd... Starting System Logging Service... Starting LSB: Load kernel modules needed to enable cpufreq scaling... Starting Login Service... [ OK ] Started ntp-systemd-netif.service. [ OK ] Started D-Bus System Message Bus. [ OK ] Started Login Service. Starting WPA supplicant... Starting Network Manager... [ OK ] Started Regular background program processing daemon. [ OK ] Started Armbian first run tasks. [ OK ] Started System Logging Service. [ OK ] Started Resets System Activity Data Collector. [ OK ] Started resolvconf-pull-resolved.service. [ OK ] Started WPA supplicant. [ OK ] Started LSB: Load kernel modules needed to enable cpufreq scaling. Starting LSB: set CPUFreq kernel parameters... Starting Hostname Service... [ OK ] Started LSB: set CPUFreq kernel parameters. Starting LSB: Set sysfs variables from /etc/sysfs.conf... [ OK ] Started LSB: Set sysfs variables from /etc/sysfs.conf. [ OK ] Started Hostname Service. [ OK ] Started Network Manager. Starting Network Manager Wait Online... [ OK ] Reached target Network. Starting OpenBSD Secure Shell server... [ OK ] Started Unattended Upgrades Shutdown. Starting Permit User Sessions... [ OK ] Started Permit User Sessions. Starting Network Manager Script Dispatcher Service... Starting Set console scheme... [ OK ] Started Set console scheme. [ OK ] Created slice system-getty.slice. [ OK ] Started Network Manager Script Dispatcher Service. [ OK ] Started OpenBSD Secure Shell server. Starting Authorization Manager... [ OK ] Started Network Manager Wait Online. [ OK ] Reached target Network is Online. Starting /etc/rc.local Compatibility... Starting LSB: Advanced IEEE 802.11 management daemon... [ OK ] Started Authorization Manager. [ OK ] Started /etc/rc.local Compatibility. [ OK ] Started LSB: Advanced IEEE 802.11 management daemon. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyMV0. [ OK ] Reached target Login Prompts. [ OK ] Started Dispatcher daemon for systemd-networkd. [ OK ] Reached target Multi-User System. [ OK ] Reached target Graphical Interface. Starting Update UTMP about System Runlevel Changes... [ OK ] Started Update UTMP about System Runlevel Changes. Ubuntu 18.04.1 LTS espressobin ttyMV0 espressobin login: [ 47.082691] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000100 [ 47.089045] Mem abort info: [ 47.091855] ESR = 0x96000005 [ 47.094981] Exception class = DABT (current EL), IL = 32 bits [ 47.101079] SET = 0, FnV = 0 [ 47.104215] EA = 0, S1PTW = 0 [ 47.107435] Data abort info: [ 47.110394] ISV = 0, ISS = 0x00000005 [ 47.114364] CM = 0, WnR = 0 [ 47.117406] user pgtable: 4k pages, 39-bit VAs, pgdp = 00000000a7778165 [ 47.124205] [0000000000000100] pgd=0000000000000000, pud=0000000000000000 [ 47.131198] Internal error: Oops: 96000005 [#1] PREEMPT SMP [ 47.136875] Modules linked in: bridge stp llc zstd zram zsmalloc sch_fq_codel ip_tables x_tables mv88e6xxx uas dsa_core [ 47.148000] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.19.14-mvebu64 #5.69 [ 47.155148] Hardware name: Globalscale Marvell ESPRESSOBin Board (DT) [ 47.161786] pstate: 40000005 (nZcv daif -PAN -UAO) [ 47.166746] pc : ipv6_chk_mcast_addr+0x6c/0x140 [ 47.171378] lr : ipv6_chk_mcast_addr+0x54/0x140 [ 47.176021] sp : ffffff8008003740 [ 47.179429] x29: ffffff8008003740 x28: ffffff8008003b48 [ 47.184893] x27: 0000000000000000 x26: ffffffc03b013828 [ 47.190358] x25: 0000000000000001 x24: ffffffc03228faca [ 47.195825] x23: ffffffc03b89dcd0 x22: ffffffc03228faf0 [ 47.201288] x21: 0000000000000000 x20: 0000000000000000 [ 47.206756] x19: 0000000000000100 x18: 0000000000000000 [ 47.212220] x17: 0000000000000000 x16: 0000000000000000 [ 47.217687] x15: 0000000000000100 x14: 0000000000000400 [ 47.223153] x13: 000000000000000a x12: 0000000000000000 [ 47.228617] x11: 0000000000000000 x10: ffffff8008ef96c8 [ 47.234083] x9 : 0000000000000000 x8 : ffffffc03b108e40 [ 47.239548] x7 : 0000000000000001 x6 : 0000000000000001 [ 47.245014] x5 : 00000040370d6000 x4 : 0000000000000064 [ 47.250479] x3 : 00000000000002ff x2 : 0200010000000000 [ 47.255945] x1 : 0300010000000000 x0 : 0300010000000300 [ 47.261420] Process swapper/0 (pid: 0, stack limit = 0x000000002308e799) [ 47.268310] Call trace: [ 47.270839] ipv6_chk_mcast_addr+0x6c/0x140 [ 47.275138] ip6_mc_input+0xd0/0x238 [ 47.278808] ip6_rcv_finish+0x4c/0x80 [ 47.282571] ipv6_rcv+0x64/0xf8 [ 47.285800] __netif_receive_skb_one_core+0x54/0x80 [ 47.290810] __netif_receive_skb+0x14/0x60 [ 47.295022] netif_receive_skb_internal+0x54/0x150 [ 47.299950] netif_receive_skb+0xc/0x18 [ 47.304009] br_netif_receive_skb+0x2c/0x48 [bridge] [ 47.309094] br_pass_frame_up+0x9c/0x130 [bridge] [ 47.313930] br_handle_frame_finish+0x2d8/0x400 [bridge] [ 47.319396] br_handle_frame+0x158/0x328 [bridge] [ 47.324146] __netif_receive_skb_core+0x218/0xac0 [ 47.328981] __netif_receive_skb_one_core+0x38/0x80 [ 47.333998] __netif_receive_skb+0x14/0x60 [ 47.338210] netif_receive_skb_internal+0x54/0x150 [ 47.343137] netif_receive_skb+0xc/0x18 [ 47.347130] dsa_switch_rcv+0xac/0x1e0 [dsa_core] [ 47.351918] __netif_receive_skb_one_core+0x54/0x80 [ 47.356935] __netif_receive_skb+0x14/0x60 [ 47.361148] netif_receive_skb_internal+0x54/0x150 [ 47.366074] napi_gro_receive+0xa4/0xc8 [ 47.370028] mvneta_poll+0x758/0xc30 [ 47.373690] net_rx_action+0x10c/0x2d0 [ 47.377547] __do_softirq+0x10c/0x200 [ 47.381310] irq_exit+0xac/0xc0 [ 47.384538] __handle_domain_irq+0x60/0xb0 [ 47.388741] gic_handle_irq+0x7c/0x180 [ 47.392593] el1_irq+0xb0/0x128 [ 47.395824] arch_cpu_idle+0x10/0x18 [ 47.399494] do_idle+0x1d4/0x298 [ 47.402810] cpu_startup_entry+0x24/0x28 [ 47.406851] rest_init+0xd0/0xe0 [ 47.410164] start_kernel+0x3ec/0x418 [ 47.413932] Code: a9400ac3 14000003 f9400e73 b4000593 (a9400660) [ 47.420209] ---[ end trace e9c57f1bcaeb7111 ]--- [ 47.424938] Kernel panic - not syncing: Fatal exception in interrupt [ 47.431475] SMP: stopping secondary CPUs [ 47.435511] Kernel Offset: disabled [ 47.439093] CPU features: 0x0,2080200c [ 47.442939] Memory Limit: none [ 47.446094] ---[ end Kernel panic - not syncing: Fatal exception in interrupt ]---
gus.tech Posted April 25, 2019 Posted April 25, 2019 I have the same issue. Bought my v7 from Amazon. Like your board, my board says its 1000cpu and 800ram. I tried flashing it with the *correct* firmware flash-image-ddr4-1g-1cs-1000_800.bin and got the same kernel panic issues. I then flashed it with flash-image-ddr4-1g-1cs-600_600.bin and it works fine. Problem is, it only runs at 300mhz per core. I'm returning my v7 to Amazon. I'll stick to my v5 until the bugs get ironed out. Oh well.
