Liqui Posted February 7, 2019 Posted February 7, 2019 (edited) I found this project very interesting and I would like to try Armbian for this new board Turris MOX. I've got your build environment working and tested my own build for a couple of supported boards. It was successful. I would like to ask you if you could help me in preparing the .config file for this board. Board Specification: https://mox.turris.cz/en/specification/ Documentation: https://doc.turris.cz/doc/en/howto/mox/mox-a-cpu Indiegogo: https://www.indiegogo.com/projects/turris-mox-modular-open-source-router Edited February 7, 2019 by Liqui 1
chwe Posted February 7, 2019 Posted February 7, 2019 https://github.com/armbian/build/pull/1151 going through this PR can give you a insight how to bring up a new board family. Is it the same SoC as on the EspressoBin?
umiddelb Posted February 8, 2019 Posted February 8, 2019 I've talked to some Turris people at FOSDEM 2019, they are using the same SoC and they've published the kernel source code and u-boot source code. Chances are that the EspressoBin might benefit from the MOX kernel, as the Turris people have added support for some additional hardware the SoC comes with.
