rhagu Posted February 12, 2019 Share Posted February 12, 2019 Armbianmonitor: http://ix.io/1ATz Hi, I am trying to install the aircrack-ng driver via dkms from over here: https://github.com/aircrack-ng/rtl8812au When I change the Makefile to match my processor arm-sun50iw1p1 , I receive these compilation errors and do not know how to fix them. cat /var/lib/dkms/rtl8812au/5.2.20.2/build/make.log DKMS make.log for rtl8812au-5.2.20.2 for kernel 4.19.20-sunxi64 (aarch64) Tue Feb 12 21:53:55 UTC 2019 make ARCH=arm64 CROSS_COMPILE=/home/android_sdk/Allwinner/a64/android-51/lichee/out/sun50iw1p1/android/common/buildroot/external-toolchain/bin/aarch64-linux-gnu- -C /lib/modules/4.19.20-sunxi64/build M=/var/lib/dkms/rtl8812au/5.2.20.2/build modules make[1]: Entering directory '/usr/src/linux-headers-4.19.20-sunxi64' arch/arm64/Makefile:27: ld does not support --fix-cortex-a53-843419; kernel may be susceptible to erratum arch/arm64/Makefile:48: Detected assembler with broken .inst; disassembly will be unreliable ./scripts/gcc-version.sh: line 26: /home/android_sdk/Allwinner/a64/android-51/lichee/out/sun50iw1p1/android/common/buildroot/external-toolchain/bin/aarch64-linux-gnu-gcc: No such file or directory ./scripts/gcc-version.sh: line 27: /home/android_sdk/Allwinner/a64/android-51/lichee/out/sun50iw1p1/android/common/buildroot/external-toolchain/bin/aarch64-linux-gnu-gcc: No such file or directory make[1]: /home/android_sdk/Allwinner/a64/android-51/lichee/out/sun50iw1p1/android/common/buildroot/external-toolchain/bin/aarch64-linux-gnu-gcc: Command not found make[1]: /home/android_sdk/Allwinner/a64/android-51/lichee/out/sun50iw1p1/android/common/buildroot/external-toolchain/bin/aarch64-linux-gnu-gcc: Command not found make[1]: /home/android_sdk/Allwinner/a64/android-51/lichee/out/sun50iw1p1/android/common/buildroot/external-toolchain/bin/aarch64-linux-gnu-gcc: Command not found make[1]: /home/android_sdk/Allwinner/a64/android-51/lichee/out/sun50iw1p1/android/common/buildroot/external-toolchain/bin/aarch64-linux-gnu-gcc: Command not found /bin/sh: 1: /home/android_sdk/Allwinner/a64/android-51/lichee/out/sun50iw1p1/android/common/buildroot/external-toolchain/bin/aarch64-linux-gnu-gcc: not found (standard_in) 1: syntax error CC [M] /var/lib/dkms/rtl8812au/5.2.20.2/build/core/rtw_cmd.o /bin/sh: 1: /home/android_sdk/Allwinner/a64/android-51/lichee/out/sun50iw1p1/android/common/buildroot/external-toolchain/bin/aarch64-linux-gnu-gcc: not found scripts/Makefile.build:303: recipe for target '/var/lib/dkms/rtl8812au/5.2.20.2/build/core/rtw_cmd.o' failed make[2]: *** [/var/lib/dkms/rtl8812au/5.2.20.2/build/core/rtw_cmd.o] Error 127 make[2]: *** Waiting for unfinished jobs.... CC [M] /var/lib/dkms/rtl8812au/5.2.20.2/build/core/rtw_security.o /bin/sh: 1: /home/android_sdk/Allwinner/a64/android-51/lichee/out/sun50iw1p1/android/common/buildroot/external-toolchain/bin/aarch64-linux-gnu-gcc: not found scripts/Makefile.build:303: recipe for target '/var/lib/dkms/rtl8812au/5.2.20.2/build/core/rtw_security.o' failed make[2]: *** [/var/lib/dkms/rtl8812au/5.2.20.2/build/core/rtw_security.o] Error 127 Makefile:1520: recipe for target '_module_/var/lib/dkms/rtl8812au/5.2.20.2/build' failed make[1]: *** [_module_/var/lib/dkms/rtl8812au/5.2.20.2/build] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-4.19.20-sunxi64' Makefile:1551: recipe for target 'modules' failed make: *** [modules] Error 2 Any ideas? kind regards, rhagu Link to comment Share on other sites More sharing options...
