temps Posted February 25, 2019 Share Posted February 25, 2019 hdmi.sh ? Will someone help me by telling me the parameters of hdmi.sh ? I use Armbian_5.44_S9xxx_Ubuntu_bionic_3.14.29_mate_20180729.img.xz my box is KM8P (S912) Link to comment Share on other sites More sharing options...
AndrewDB Posted February 25, 2019 Share Posted February 25, 2019 5 hours ago, temps said: hdmi.sh ? Will someone help me by telling me the parameters of hdmi.sh ? I use Armbian_5.44_S9xxx_Ubuntu_bionic_3.14.29_mate_20180729.img.xz my box is KM8P (S912) Please attach hdmi.sh to your post and tell us what is the resolution of the monitor or TV you are using. Link to comment Share on other sites More sharing options...
temps Posted February 27, 2019 Author Share Posted February 27, 2019 #!/bin/sh bpp=16 mode=1080p60hz #mode=720p60hz for x in $(cat /proc/cmdline); do case ${x} in m_bpp=*) export bpp=${x#*=} ;; hdmimode=*) export mode=${x#*=} ;; esac done HPD_STATE=/sys/class/amhdmitx/amhdmitx0/hpd_state DISP_CAP=/sys/class/amhdmitx/amhdmitx0/disp_cap DISP_MODE=/sys/class/display/mode echo $mode > $DISP_MODE common_display_setup() { M="0 0 $(($X - 1)) $(($Y - 1))" Y_VIRT=$(($Y * 2)) fbset -fb /dev/fb0 -g $X $Y $X $Y_VIRT $bpp echo $mode > /sys/class/display/mode echo 0 > /sys/class/graphics/fb0/free_scale echo 1 > /sys/class/graphics/fb0/freescale_mode echo $M > /sys/class/graphics/fb0/free_scale_axis echo $M > /sys/class/graphics/fb0/window_axis echo 0 > /sys/class/graphics/fb1/free_scale echo 1 > /sys/class/graphics/fb1/freescale_mode } case $mode in 720p*) export X=1024 export Y=768 ;; 1080p*) export X=1920 export Y=1080 ;; esac common_display_setup # Enable framebuffer device echo 0 > /sys/class/graphics/fb0/blank # Blank fb1 to prevent static noise echo 1 > /sys/class/graphics/fb1/blank echo 0 > /sys/devices/virtual/graphics/fbcon/cursor_blink exit 0 Link to comment Share on other sites More sharing options...
AndrewDB Posted February 27, 2019 Share Posted February 27, 2019 44 minutes ago, temps said: #!/bin/sh ... exit 0 hdmi.sh reads the mode parameter in the command line and sets up the framebuffer accordingly. The default is 1080p. Please run the following command: cat /proc/cmdline and report the result here. Also please indicate what resolution(s) your monitor or TV is capable of. Link to comment Share on other sites More sharing options...
temps Posted February 27, 2019 Author Share Posted February 27, 2019 cat /proc/cmdline root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=${mac} Link to comment Share on other sites More sharing options...
temps Posted February 27, 2019 Author Share Posted February 27, 2019 19EL933G toshiba TV HD, but I have many TV toshiba, samsung, philips ... and I have the same problem with the display ( 1366x768 50Hz for the first toshiba) Link to comment Share on other sites More sharing options...
temps Posted February 27, 2019 Author Share Posted February 27, 2019 If I do : 720p*) export X=1360 export Y=768 I have a very beautiful image, but it is deported on the left, and I miss all the beginning of the lines of codes Link to comment Share on other sites More sharing options...
AndrewDB Posted February 27, 2019 Share Posted February 27, 2019 Either you try a proper HD TV or monitor capable of 1920x1080p, or you have to play around a little bit with the fbset command to try to find some setting that will work on your TV's. Link to comment Share on other sites More sharing options...
temps Posted February 27, 2019 Author Share Posted February 27, 2019 Thanks, when I do fbset --info mode "1360x768" geometry 1360 768 1360 768 32 timings 0 0 0 0 0 0 0 rgba 8/16,8/8,8/0,8/24 endmode Frame buffer device information: Name : OSD FB Address : 0x3a200000 Size : 25497600 Type : PACKED PIXELS Visual : TRUECOLOR XPanStep : 1 YPanStep : 1 YWrapStep : 0 LineLength : 5440 Accelerator : No But when I do fbset -left 50 this do nothing Link to comment Share on other sites More sharing options...
temps Posted February 27, 2019 Author Share Posted February 27, 2019 Thanks for the answers. I found a solution, by changing television. The problem of the first TV is that there is no "native" mode in its settings. Taking another TV always a 19-inch toshiba, at first I had the same problem because it was in cinema mode. I corrected. I tested samsung which was no problem with the latest hdmi.sh Link to comment Share on other sites More sharing options...
