@lex Posted April 11, 2016 Posted April 11, 2016 Hi, I updated the gc2035 driver, kernel 3.4.x. The driver can be loaded with parameter, so you can choose to have different window size and/or image quality on the fly (well, kind of). Parameter: hres=[0,1,2] hres=0 (default without parameter) 640x480, 15 fps, good quality (fps with good light condition) 1280x720, 13 fps, poor quality (fps with good light condition) 1600x1200, 10 fps, poor quality (fps with good light condition) hres=1 800x600, 12 fps, good quality (fps with good light condition) 1600x1200, 8 fps, medium quality (fps with good light condition) hres=2 320x240, 20 fps, poor quality (fps with good light condition) 640x480, 18 fps, medium quality (fps with good light condition) 800x600, 18 fps, medium quality (fps with good light condition) Loading the driver (manually): modprobe gc2035 hres=1 modprobe vfe_v4l2 or add it to /etc/modules Unloading the driver: modprobe -r -v vfe_v4l2 modprobe -r -v gc2035 and loading with other window size and performance: modprobe gc2035 hres=2 modprobe vfe_v4l2 PS: Light condition does affect fps performance! github: https://github.com/avafinger/gc2035 Cheers, @lex
tkaiser Posted April 12, 2016 Posted April 12, 2016 Did you try it out on top of Armbian's kernel sources? I still think we miss phelum's patches (that are included in loboris' kernel).
@lex Posted April 12, 2016 Author Posted April 12, 2016 I did not try it, but i don't see any reason to fail or break it. I am not aware of any work done on gc2035 by phelum, can you point to the patches? I does incorporate the work done by Leonardo Lontra in order to get ~20 fps. Just checked loboris' kernel and it is 6 months old, untouched. I don't use Loboris' kernel. If you would like to conduct some benchmarking you could use v4l2loopback (http://www.sistemasembarcados.org/2016/04/orange-pi-camera-with-v4l2loopback-vidcopy.html) as a base, just for fun.
tkaiser Posted April 12, 2016 Posted April 12, 2016 Hmm... I thought in the kernel sources we use some basic adjustments are missing (see phelum's work/comments). Now http://phelum.net/temp/gc2035/is empty... O my... just tried it using web.archive.org: http://web.archive.org/web/20150928225142/http://phelum.net/temp/gc2035 http://web.archive.org/web/20150928225220/http://phelum.net/temp/include And this here is most probably all the stuff that's missing: http://web.archive.org/save/_embed/http://phelum.net/temp/gc2035patch or as an archive (at least in Armbian's sun8i kernel sources there is no drivers/media/video/sun4i_csi/ at all which is most probably taken from linux-sunxi sources). What do you think? Or does it work for you with Armbian's kernel already?
@lex Posted April 12, 2016 Author Posted April 12, 2016 You are right, he worked on linux-sunxi 3.4.103. We need those patch and see if it will work. Some work is required, the include headers must reflect the sun4i csi headers. Can you try it?
tkaiser Posted April 12, 2016 Posted April 12, 2016 We need those patch and see if it will work. Some work is required, the include headers must reflect the sun4i csi headers. Can you try it? Nope, especially not now since it seems Igor's busy exchanging our sun8i legacy kernel sources The only ressources I scheduled on the camera issue is testing (especially if we can simply use GC2035 also together with BPi M2+ -- I ordered 2 camera modules and am willing to see one of them and/or M2+ passing away )
@lex Posted April 14, 2016 Author Posted April 14, 2016 OK. I just tried against armbian legacy kernel 3.4.111 without any modifications and have build the driver and kernel with some warnings and errors (fixed). Unless sunxi-vfe (sunxi video front end) is not working yet on this kernel version, you can just create a patch as you did before. I got the following Warning / Errors with my eabihf: arm-linux-gnueabihf-gcc (Ubuntu/Linaro 4.6.3-1ubuntu5) 4.6.3 CC drivers/base/firmware_class.o drivers/base/firmware_class.c: In function ‘firmware_data_read’: drivers/base/firmware_class.c:631:9: error: implicit declaration of function ‘kobj_to_dev’ [-Werror=implicit-function-declaration] drivers/base/firmware_class.c:631:23: warning: initialization makes pointer from integer without a cast [enabled by default] drivers/base/firmware_class.c: In function ‘firmware_data_write’: drivers/base/firmware_class.c:726:23: warning: initialization makes pointer from integer without a cast [enabled by default] cc1: some warnings being treated as errors make[2]: *** [drivers/base/firmware_class.o] Error 1 make[1]: *** [drivers/base] Error 2 make: *** [drivers] Error 2 make: *** Waiting for unfinished jobs.... Fix: /* * firmware_class.c - Multi purpose firmware loading support * * Copyright © 2003 Manuel Estrada Sainz * * Please see Documentation/firmware_class/ for more information. * */ #include <linux/capability.h> #include <linux/device.h> #include <linux/genhd.h> <= missing header #include <linux/module.h> And the final warning: WARNING: could not find drivers/media/video/sunxi-vfe/lib/.libisp.cmd for drivers/media/video/sunxi-vfe/lib/libisp WARNING: modpost: Found 5 section mismatch(es). To see full details build your kernel with: 'make CONFIG_DEBUG_SECTION_MISMATCH=y' AS arch/arm/boot/compressed/piggy.gzip.o LD arch/arm/boot/compressed/vmlinux OBJCOPY arch/arm/boot/zImage Kernel: arch/arm/boot/zImage is ready UIMAGE arch/arm/boot/uImage Image Name: Linux-3.4.111+ Created: Thu Apr 14 13:49:26 2016 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 4479224 Bytes = 4374.24 kB = 4.27 MB Load Address: 40008000 Entry Point: 40008000 Image arch/arm/boot/uImage is ready libisp is pre-built somewhere? vfe_v4l2-y += lib/libisp If sunxi video front end is not working, i think Igor should drop this and i can try to apply phelum's work.
@lex Posted April 14, 2016 Author Posted April 14, 2016 https://github.com/avafinger/gc2035/blob/master/gc2035_armbian_k3.4.111.patch
@lex Posted April 18, 2016 Author Posted April 18, 2016 Update: * little fix to hres=0 * added hres=3 (320x240|352x288|640x480 with low quality cropped image) - CIF image size Best performance/quality you can get is 640x480 ~25* fps (hres=0). load driver with this parameters: modprobe gc2035 hres=0 mclk=34 * good ambient light
phelum Posted May 15, 2016 Posted May 15, 2016 Hmm... I thought in the kernel sources we use some basic adjustments are missing (see phelum's work/comments). Now http://phelum.net/temp/gc2035/is empty... O my... just tried it using web.archive.org: Hi, I just checked and the link http://phelum.net/temp/gc2035/ is still valid. I did get the gc2035 working with my 3.4.103+ kernel on my OPi A20. There was a problem with frame queueing that I fixed. But it sounds like the new driver mentioned here is better. I reported my changes on the Orange Pi forum but no-one seemed interested so I lost interest. Cheers, Steven
tkaiser Posted May 15, 2016 Posted May 15, 2016 I reported my changes on the Orange Pi forum but no-one seemed interested so I lost interest. Thx for the feedback. I was really interested but got my OPi PC with camera module in Dec 2015 so you weren't active any longer (same with me now -- last login as 'bronco' in orphaned Orange Pi forums might've been in 2015 or early 2016). At the moment I've no access to my H3 boards to check the current driver situation. But we clearly need to add this stuff to our basic Armbian builds.
phelum Posted May 15, 2016 Posted May 15, 2016 I remember you wrote some very good posts on that forum. I worked on the gc2035 driver while I was overseas last June. I still have my OPi A20 board and it has some nice features (e.g. pads for RTC battery, good screen printing on board, onboard Wi-Fi). But it is extinct now which is a shame. I gave up on their first H3 board although sooner or later I'm going to have to upgrade from A20s and wheezy. I do hope someone can get some value from the gc2035 driver. Cheers, Steven
DigY Posted March 1, 2017 Posted March 1, 2017 Is there a way to put a camera to standby and back ON?
