PDP11 Posted March 26, 2019 Posted March 26, 2019 ** EDIT - noise alert - already covered by F3 utility *** Is there a shell script that one could recommend for newbies that would work similarly to the H2TESTW program? And if so, should it be included in Armbian - perhaps on a first-run even throwing up a big warning to the op? Kudos to you guys for putting all that work into SD card knowledge and programming into Armbian in the first place. In fact, the good engineering of sd card preservation with Armbian is what drew me to it initially. Heck, for my use case, I may never really need an emmc. Anyway, I'm just not up on what an up to date alternative to h2testw is these days. Edit #2: For kicks, uninstalled ver 6.0 and compiled the latest ver 7.1 from source https://github.com/AltraMayor/f3/releases/ f3read, f3write compiled ok, but had to edit the Makefile to get f3probe as a target too. To get that to work, had to install libudev-dev package, and then it all went well.
Tido Posted March 26, 2019 Posted March 26, 2019 16 hours ago, PDP11 said: should it be included in Armbian usually, if you have a problem with the SDcard, armbian won't boot.
PDP11 Posted March 26, 2019 Author Posted March 26, 2019 Yeah, when I wrote that I had a bit too much caffeine. It was nice to see it as part of the standard image. At least the 6.0 version. Wonder what the holdups upstream are about V 7.1. ? Anyway, another discussion perhaps, and not a feature request any more.
Pander Posted February 17, 2021 Posted February 17, 2021 Is this still as issue? Ubuntu meanwhile offers f3 version 7, https://launchpad.net/ubuntu/+source/f3
