accordingly, one can remove Netplan if one don't like it https://www.baeldung.com/linux/etc-network-interfaces-netplan-switch and that actually even with Netplan one can configure a different renderer, e.g. Network-Manager https://docs.armbian.com/User-Guide_Networking/ or for that matter, I think it is feasible to remove Netplan altogether and just use Network Manager, if one prefers that or even for that matter switch back to the raw lowest level /etc/network/interfaces as described in the 1st link In addition show the detailed sequence of events and provide details that
The Tall Man replied to ずっと一人's topic in Orange Pi 5 Plus
Additional Info: The "Current" Kernel I found the equivalent code in the Current kernel. It is a clearly a different version of the file, but it looks like the same error is present. I have not tested it. Snippet Source: ./build/cache/sources/linux-kernel-worktree/6.12__rockchip64__arm64/arch/arm64/boot/dts/rockchip/rk3588-orangepi-5-plus.dts &analog_sound { pinctrl-names = "default"; pinctrl-0 = <&hp_detect>; simple-audio-card,aux-devs = <&speaker_amp>, <&headphone_amp>; simple-audio-card,hp-det-gpios = <&gpio1 RK_PD3 GPIO_ACTIVE_LOW>; // This line here: Change GPIO_ACTIVE_LOW to GPIO_ACTIVE_HIGH simple-audio-card,widgets = "Microphone", "Onboard Microphone", "Microphone", "Microphone Jack", "Speaker", "Speaker", "Headphone", "Headphones"; The "Vendor" Kernel Last time I tried the Vendor kernel, the ES8388 analog audio (headphones) wasn't working either. I found the equivalent code in the Vendor kernel's devicetree. It is also a clearly different version of the file from the other two kernel trees. But it looks like this particular coding error is not present here. I also checked the Vendor gpio.h that's #included, and it agrees with the Edge kernel's gpio.h for #defines for GPIO_ACTIVE_LOW and GPIO_ACTIVE_HIGH. But glancing at this code, knowing the audio isn't working, could there be some things conflicting? Snippet Source: ./build/cache/sources/linux-kernel-worktree/6.1__rk35xx__arm64/arch/arm64/boot/dts/rockchip/rk3588-orangepi-5-plus.dts es8388_sound: es8388-sound { status = "okay"; compatible = "rockchip,multicodecs-card"; rockchip,card-name = "rockchip-es8388"; hp-det-gpio = <&gpio1 RK_PD3 GPIO_ACTIVE_HIGH>; // Look Here #1 io-channels = <&saradc 3>; io-channel-names = "adc-detect"; keyup-threshold-microvolt = <1800000>; poll-interval = <100>; spk-con-gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_HIGH>; hp-con-gpio = <&gpio3 RK_PA7 GPIO_ACTIVE_HIGH>; // Look Here #2 rockchip,format = "i2s"; rockchip,mclk-fs = <256>; rockchip,cpu = <&i2s0_8ch>; rockchip,codec = <&es8388>; rockchip,audio-routing = "Headphone", "LOUT1", "Headphone", "ROUT1", "Speaker", "LOUT2", "Speaker", "ROUT2", "Headphone", "Headphone Power", "Headphone", "Headphone Power", "Speaker", "Speaker Power", "Speaker", "Speaker Power", "LINPUT1", "Main Mic", "LINPUT2", "Main Mic", "RINPUT1", "Headset Mic", "RINPUT2", "Headset Mic"; pinctrl-names = "default"; pinctrl-0 = <&hp_det>; play-pause-key { label = "playpause"; linux,code = <KEY_PLAYPAUSE>; press-threshold-microvolt = <2000>; }; }; rk_headset: rk-headset { status = "disabled"; compatible = "rockchip_headset"; headset_gpio = <&gpio1 RK_PD3 GPIO_ACTIVE_HIGH>; // Look Here #3 (same values as #1 above) pinctrl-names = "default"; pinctrl-0 = <&hp_det>; io-channels = <&saradc 3>; }; - Today
Thanks, i will tear it down and see what axp chip mine is using - Yesterday
Well that's one thing that confuses me with Linux source code - is having so many different versions of the same file, how to tell which one: location, version type, and especially which repository. Thanks so much for acting right away to get this fix into the Armbian!! -
laibsch replied to ずっと一人's topic in Orange Pi 5 Plus
Thank you for having a look and catching my mistake. I have marked the PR as still work-in-progress for now while I look into where to patch this correctly in Armbian itself. -
What is purpose of /dev/mmcblk2boot devices?
greenais replied to greenais's topic in Allwinner sunxi
Using included in image armbian-config script as many times for other boards before. I have no idea what was there and I didn't care because Script formats emmc before transfer (with "Warning! All data will be destroyed - proceed?") So there is no chance to leave any trails of anything rested on emmc before -
Awesome! Thanks so much!! You're welcome! The kernel.org audio patch by Maud Spierings is as follows: Source: https://patchwork.kernel.org/project/linux-rockchip/patch/20250823-orangepi5-v1-1-ae77dd0e06d7@hotmail.com/ ./arch/arm64/boot/dts/rockchip/rk3588-orangepi-5-plus.dts &analog_sound { pinctrl-names = "default"; pinctrl-0 = <&hp_detect>; simple-audio-card,aux-devs = <&speaker_amp>, <&headphone_amp>; - simple-audio-card,hp-det-gpios = <&gpio1 RK_PD3 GPIO_ACTIVE_LOW>; + simple-audio-card,hp-det-gpios = <&gpio1 RK_PD3 GPIO_ACTIVE_HIGH>; simple-audio-card,widgets = "Microphone", "Onboard Microphone", "Microphone", "Microphone Jack", -
How was this transfered? What was on the eMMC before the transfer? Was the eMMC wiped before the transfer? My guess is that your eMMC has Android loaded on it, you didn't wipe it and now you have partitions left over from the Android install.
still on windows , but microsoft suggests 11 so looking for linux 11
I didn't mention, sorry, probably it matters somehow - my bookworm is already transferred to emmc, so system boots and runs from there, not from SD-card -
WSL might be easier if you're on windows
" Either of those," i'm one step closer OK, i 'll get Ubunto on vm and will look deeper. Thanks for now
Not joking at all. 1st point Supported Architectures: x86_64, aarch64, riscv64 board is armhf Next 3 points from this readme: System: VM, container, or bare-metal with: ≥ 8GB RAM (less with KERNEL_BTF=no) ~50GB disk space Operating System: Armbian / Ubuntu 24.04 (Noble) for native builds Any Docker-capable Linux for containerized setup Windows: Windows 10/11 with WSL2 running Armbian / Ubuntu 24.04 Are they alternate to each other
Either of those, I personally used Ubuntu running in ESXi VM
Are you joking? Open readme.md in GitHub repo, read it and explore links therein
Thanks for answering. Couple things: "As per documentation, run on a compatible host". Which documentation? can you provide link you define by this word? Define pls compatible host as it is very unclear in comparison to what i was reading ( it was unclear too) , or it is defined in docs you mentioned... banana pi pro is not supported as I understood. Igor Pecovnik was supporting this device for years. Maybe he can deliver more info in this subject. 2 points in reqs: - Armbian / Ubuntu Noble 24.04.x for native building or any Docker capable Linux for containerised - Windows 10/11 with WSL2 subsystem running Armbian / Ubuntu Noble 24.04.x Both required?
Thank you for your report, @DanflashX So, your audio is working out of the box and the change in https://github.com/armbian/build/pull/8568 is not necessary for the Opi 5 Pro?
Anybody here with the Opi 5 Pro? Does it need the same change? https://github.com/armbian/build/pull/8568 -
RPi5 Armbian_25.2.x upgrade: Unsupported initramfs version
mihanson replied to ChrisO's topic in Raspberry Pi
I just wanted to interject that I ran into the same (non?)-issue on the 25.8.1 trixie minimal image using a rpi400. armbianmonitor -u -
I have only ever seen mmcblk?boot? Partitions on media that was setup for Android as the A/B is part of how Android installs updates and can fall back to the previous version. I've never seen them on an Armbian created media.
Wow, I didn't know those command and mechanism even exist... Thank you for your tip! Any ideas regarding main (mmcblk2boot) topic question, perhaps? -
Create custom partition tables
tabrisnet replied to Alexander iLminsky's topic in Framework and userspace feature requests
It's worth noting that you don't have to necessarily change anything in the build process. As long as you plan to not insert partitions in the middle, you can: write the image to the card with parted, resize the root partition to whatever you want make a new partition If you want to have more than 4 partitions total, this works best with GPT partition table, but legacy msdos works too with a little more effort `fsck.ext4 -f /dev/foo` where foo is the root partition `resize2fs /dev/foo` after you have the machine booted, you can then mkfs the new partition [you could probably do it in advance of booting the system too] I do this regularly, b/c I typically only partition about 1/2 or 1/4 of the SD card to leave the rest for wear-leveling. Are you trying to do this as a one-off or are you trying to do it for a dozen or more SBCs of the same type? -
not everything is mounted, at least not in the way you expect it. check "swapon -s"
As per documentation, run on a compatible host: git clone https://github.com/armbian/build cd build ./compile.sh Follow screen menus. Build system will download necessary toolchain, sources, patches, etc and build an image. Whether or not it will work depends on whether sources/patches for a particular board deviated from the hardware due to time or bugs. If someone is regularly testing then image likely will be ok, if not then image might work or not. If the board has community maintained status, then it is up to its users to test/develop/send patches in GitHub. If necessary, it is possible to play with sources, configs, develop and place extra patches, etc. At times it looks not that straightforward, so there will be a learning curve.
