  2. You can create an extension including something like unset armbian_kernel_config__force_pa_va_48_bits_on_arm64
  4. @Werner I re-checked all my patches and custom configurations and performed a clean rebuild. I found clear evidence in the logs that `CONFIG_ARM64_VA_BITS` is being explicitly overwritten during the build process: ### kernel_config_initialize.log --> (9) INFO: Configuring kernel [ linux-rk35xx-vendor ] --> (9) INFO: Using kernel config provided by user [ userpatches/linux-rk35xx-vendor.config ] --> (9) COMMAND: cp -pv /armbian/userpatches/linux-rk35xx-vendor.config /armbian/cache/sources/linux-kernel-worktree/6.1__rk35xx__arm64/.config '/armbian/userpatches/linux-rk35xx-vendor.config' -> '/armbian/cache/sources/linux-kernel-worktree/6.1__rk35xx__arm64/.config' --> (9) INFO: Considering available RAM for BTF build [ 13082 MiB ] --> (9) INFO: Enabling eBPF and BTF info [ for fully BTF & CO-RE enabled kernel ] --> (9) COMMAND: ./scripts/config --disable SECURITY_LOCKDOWN_LSM ... --> (10) COMMAND: ./scripts/config --enable ARM64_VA_BITS_48 ... --> (12) COMMAND: ./scripts/config --set-val ARM64_PA_BITS 48 --> (12) COMMAND: env -i CCACHE_BASEDIR="/armbian/cache/sources/linux-kernel-worktree/6.1__rk35xx__arm64" CCACHE_TEMPDIR="/armbian/.tmp/work-907ace63-1eb7-43dc-ac17-503d457007a8/ccache_tmp" PATH="/usr/bin:/armbian/cache/pip/base/bin:/armbian/.tmp/work-907ace63-1eb7-43dc-ac17-503d457007a8/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin" PYTHONPATH="/armbian/cache/pip/base/lib/python3.12/site-packages:" DPKG_COLORS=always XZ_OPT='--threads=0' TERM='xterm-256color' COLUMNS='248' COLORFGBG='' CCACHE_DIR='/armbian/cache/ccache' make '-j6' 'ARCH=arm64' 'LOCALVERSION=-vendor-rk35xx' 'CROSS_COMPILE= aarch64-linux-gnu-' 'KCFLAGS=-fdiagnostics-color=always -Wno-error=misleading-indentation ' 'SOURCE_DATE_EPOCH=1768563629' 'KBUILD_BUILD_TIMESTAMP=Fri Jan 16 11:40:29 UTC 2026' 'KBUILD_BUILD_USER=build' 'KBUILD_BUILD_HOST=armbian' 'KGZIP=pigz' 'KBZIP2=pbzip2' olddefconfig HOSTCC scripts/basic/fixdep LEX scripts/kconfig/lexer.lex.c YACC scripts/kconfig/parser.tab.[ch] HOSTCC scripts/kconfig/lexer.lex.o HOSTCC scripts/kconfig/parser.tab.o HOSTLD scripts/kconfig/conf .config:2755:warning: override: reassigning to symbol ARM64_VA_BITS_39 .config:2789:warning: override: ARM64_VA_BITS_48 changes choice state # # configuration written to .config # --> (14) INFO: Kernel configuration [ linux-rk35xx-vendor ] I traced this behavior to the following function in `lib/functions/compilation/armbian-kernel.sh`: function armbian_kernel_config__force_pa_va_48_bits_on_arm64() { if [[ "${ARCH}" == "arm64" ]]; then opts_y+=("ARM64_VA_BITS_48") opts_val["ARM64_PA_BITS"]="48" fi } I manually modified this function (changing `48` to `39`), and the resulting kernel deb finally compiled with `CONFIG_ARM64_VA_BITS=39` successfully. Obviously, modifying the build framework source is not the proper solution. Is this enforcement intended for all arm64 builds? Is there a standard way to bypass this function?
  5. Nevermind, got the answer from here.
  6. If you can get the unit in the proper state by shorting, you can flash an android img or custom one using this tool; https://github.com/natinusala/linux-amlogic-toolkit Other repos that you may find useful: https://github.com/mluis/aml-flash-tool https://github.com/Stane1983/aml-linux-usb-burn
  7. Hi While I thiknk your approach should have worked, a quick search revealed that something similar is done for a different family. Perhaps try this way:https://github.com/armbian/build/blob/9aa6e1e29ec2d397bbe223bebaa93bd13ef79818/patch/kernel/archive/filogic-6.16/patches.armbian/0007-build.sh-add-additional-build-script-config-defconfi.patch#L1909
  8. Description: Hello everyone, I am encountering an issue where kernel configuration changes do not take effect when building an image for the Rock 5B using the Armbian Build system. Environment: Board: Rock 5B Kernel: Vendor Release: Noble Build Mode: Mini Build Tag/Branch: v25.11 Specific Issue: To ensure compatibility with Redroid containers, I need to change the kernel's CONFIG_ARM64_VA_BITS from the default 48-bit to 39-bit. What I have tried: I have attempted the following three methods, but none have worked: Ran the kernel configuration tool to change CONFIG_ARM64_VA_BITS, then copied the generated .config to userpatches/linux-rk35xx-vendor.config. Took the default config/kernel/linux-rk35xx-vendor.config, manually modified/added CONFIG_ARM64_VA_BITS=39 and CONFIG_ARM64_VA_BITS_39=y, and copied it to userpatches/linux-rk35xx-vendor.config. Created a kernel source patch in userpatches targeting arch/arm64/configs/rockchip_linux_defconfig and arch/arm64/configs/defconfig to force CONFIG_ARM64_VA_BITS=39 and CONFIG_ARM64_VA_BITS_39=y. Result: Regardless of the method used, the final Armbian-generated kernel remains at VA_BITS=48. It seems my configuration changes are being overwritten or ignored during the build process. Request: Is there specific logic in the Vendor/RK3588 build configuration that forcibly locks VA_BITS? What is the correct way to modify this parameter for this specific board/kernel combination? Thanks for your help!
  9. Hi, I've read on here that you can apparently switch to a stable edge branch through Armbian Config, but the closest I can find is 'switch to rolling packages repository' and 'distribution upgrade to rolling unstable'. Are either of these correct? I'm running the Ubuntu Noble 6.12 kernel, btw. Many thanks.
  10. @Dangrain There is a paragraph Partecipation and debugging with the suggested operations to let other people help you in a proper way and perhaps improve support for your board in the mainline armbian codebase. You may want to go your own way, but then helping will be much harder.
  11. @HarleyyyuI don't have that exact model of board, mine's a ZQ01-V1.3 for which the unbricking pins are in a different place (but don't worry I figured it out). The issue I'm facing right now is that my frankenstein'd image is in pieces, pieces from two different OSes and Isn't in a single .img file so I'm not sure how to write it using multitool. Any help sure is appreciated.
  12. Please read my reply at https://github.com/torte71/InsideSovolKlipperScreen/issues/8#issuecomment-3796412735 In short: I think the screen on this device is a proprietary smart-device that can't be used as a standard display. Thus KlipperScreen (and any other X or Wayland app) will not be able to run.
  13. I would like to say thank you very much to @sicxnull for the latest images of X96Q V5.1. They work really well and allow me to install HA as well as use it like a PC. You really did a great job!
  14. Interested myself in the 3W in general, and if I can find them anywhere. They have the proper chip for a zero form factor board to use with the Radxa 5C and 5A, and several other boards. So I've looked, but they seem to have been outdated by the better zero form factor boards... which also seem to have a specific chip type, and aren't really compatable with the other chips if you're trying to give yourself some headroom to run clusters or offload some processes. I don't know too much about too many things yet, but I know that I need to stick with 1 chip, like a GPU arcitecture, and I can't find the 3W anywhere for any type of reasonable price. I think I found a few for like $300, but the dream of using this stuff at the top end of what it can be used for is looking grim as I am having troubles finding some of these parts for this more developed chip style. I'm sure in due time, it will all be replaced by the new Radxa zero form factor, along with the Pi form factor which will probably gravitate to this new more powerful model. The Zero board has twice the specs aprox. as the old 3W, which means likley the next Radxa board is comming out swinging to start with 32GB of RAM, and then it'll be updated with 64GB. As they seem to do that... Start half mast, then bring out a new twice as powerful model. Hoping to get my first arm project going, and I wish I knew more about ARM in general before I started focusing on 1 chip style. Radxa is cool, and they are buff as can be, but as ARM evolves, the specificity of board type to the different things you have to do is a big big pain in the ass that makes this whole adventure more painful then it should be... Eventually I'm sure it'll all come together into a standard.... But by then, you can't be a pioneer in the tiny computer parts projects. Hope this thread evolves some. I know just seeing a title on 3W caught my eye, and it's on the top of the list. I'll be getting more involved with all of this in the days to come. If you can message me, feel free. I am pretty Armtarted, and would love any information I can get.
  15. Hey shepper, this is great, I've been thinking of working on this myself but it looks like you have more practical experience. One of the issues I had run into with the OEM software packages was no support for wired ethernet, my preference is wired connections for my devices. Looks like there was no way to provide driver support for different manufacturers. Using Armbian would remedy this. One of the hurdles I have found online involves the probe sensing that Sovol has used with this specific printer. They created a custom function (kx711) for their toolhead, that supposedly hasn't been merged with the mainline klipper branch. Don't know how difficult it would be to implement. Maybe I'll try going down this rabbit hole. Now that I see someone else is giving this a go I feel more motivated to do something too. If I can help let me know. My printer is the SV06 Ace Plus.
  16. To anyone with and an mxq pro 4k v4.0 that has an eMCP memory module in it, If you ever you manage to soft brick your board to the point the maskrom button behind the AV port doesn't work here's the contact points for forcing it to enter maskrom mode. Note: After soldering to the pad indicated in the photo you can connect it to a 5V pad and do the same process and connect it to pc. Remove the connection once you detect that it entered maskrom mode (you might break the eMCP if you keep supplying 5V to it for a long time)
  17. @Dangrain To flash in an eMCP board you can either use the Multiboot image or flash via rkdevtool in linux. eMCP is basically just emmc memory and ram packaged into one chip so the process is almost the same with emmc flash guide and Multiboot flash guide (sd card flash) PS: i have the same type of memory and almost manage to brick it (thankfully i managed to find the eMCP pads to force it to maskrom mode)
  18. Yesterday
  19. Hey friends, I'm back. Well, good news. I got the box to boot from an SD card, specifically the 'Armbian_23.08.0-trunk_Rk322x-box_buster_edge_6.5.5_minimal.img' image, bad news I am not sure how to get it onto the eMCP and this is probably not the way you're supposed to boot armbian. I got the rk322x-box.dtb from the 'LibreELEC-RK322X.arm-11.0-nightly-20240218-d7324fb-rk322x.img' image (used by KanexMarcus in the comment here) and I had to add 'irqpoll' to extraargs in armbianEnv.txt, only after that did it boot. Ethernet works, wireless doesn't, using lsblk doesn't display the internal storage. Not sure what to do now, just figured I'd check in just to tell everyone what's going on and how I got it working.
  20. Hello, I had a similar problem - unbootable Rock64 after kernel upgrade from 6.6.x to 6.12.x (error: Wrong Ramdisk Image Format). You can look in this thread djurny found a solution, that works for me. Maybe it will help.
  21. I did establish a wifi connection and ssh sovol@IPaddress. Have the following: sovol@sovol:/$ ls -a -C . data lib opt run srv userdata .. dev lost+found packages sbin sys usr .resized etc media proc sdcard system var bin home mnt rockchip-test sha256sum.README tmp vendor boot info oem root sha256sum.txt udisk sovol@sovol:/$ uname -a Linux sovol 5.10.160 #54 SMP PREEMPT Mon Aug 5 22:22:56 CST 2024 aarch64 GNU/Linux Could not cd to root/ and tried to su using mks, makerbase, sovol and 1234 as root passwds. Edit: I can run root commands with sudo The boot/ directory only contained grub/, no hidden files and no *dtb. Edit: Regained wifi after changing channel ?congestion. I looked at the FCCid site and the photos submitted to the FCC show a Realtek rtk8189FTV chip. It looks like the Fn-Link chip was substituted perhaps due to Mainland/Taiwan tensions. Not sure the FCC knows about the chip substitution or if new wifi test data was generated. The wifi on this board is crippling in many ways, Crowsnest cam access saves me many trips up/down the stairs to check for print failures. Still, it does not look like Sovol will be providing any more firmware updates. The two that are available can only be installed by a wifi connection using OTA (Over The Air). Paranoia is high for wireless connections that you know nothing about. I'm wondering about replacing the mainboard with the mks-skipr and adding a wifi module with mainstream kernel support. May be a better path to MainStream klipper and reliable mainstream wifi. Edit: Was able to scp/pull the following files: config-5.10 gpio.txt ip_address.txt rockchip_config. Building my own image still may be an option but will need to deal with the wifi driver, a python script for crowsnest camera and the LED light. Edit: Armbian-mkspi has patches for rtl8189fs. Image building is doable - not sure if wifi will be improved but Mainline Klipper, a more recent kernel, packages with updates can be had on stock boards.
  22. I just downloaded both images available on the download page (minimal and xfce desktop) and both images had the install-aml.sh script in the /root directory. As far as your current state, I only know of the windows amlogic tool as being the only available way to restore an android image. I know nothing about the Khadas tools you are trying to use, whether they will work on non-khadas boards, or if they can be used for what you are trying to do.
  23. Ok. I don't mean to disrespect, but I did read the install instructions. It's just I couldn't find the /root/install-aml.sh script, I checked multiple times, reflashed it etc (even checked /boot ). Don't know if it makes any difference, I flashed my usb using dd, not balena. I did notice it makes two partitions (armbi_boot and armbi_root), but it worked anyway. If it does make a big difference, apologies for my ignorance. About ophub, I didn't really know - glad you pointed it out - that it's a fork that doesn't contribute and that uses the name without permission. Currently, I'm struggling trying to get the board in usb burn mode. I just don't know which pins to short, and don't want to short the wrong ones (even though I did play around). The mmc is ball-grid-array, so really hard to figure it out. I looked up the datasheet for the chip but I can't really figure it out. So I shorted something that looked shortable (I'm sorry, but I really didn't know what to short). It did allow me to enter usb burn mode once, but it stayed in usb burn for hours (I didn't want to unplug, since I knew I probably won't be able to get it there again). So I tried flashing the stock rom (official h96 website), but it timed out, then the board became unresponsive. I tried a couple of times, but nothing. Now I unplugged it, and can't get it back in usb-burn. It does have some reactions to shorting the same pins, looking at uart logs, but I just can't get it to enter that state anymore. Any help is greatly appreciated. Tools I have used: I'm running linux, so I can't use the standard usb burn amlogic tool. I clone the repo https://github.com/khadas/utils
  24. I don't believe you did. As the install instructions linked to from the download page don't mention any of the things you tried (like armbian-config, armbian-install, nand-sata-install, etc). These are the instructions for the amlogic s9xx tv box builds (again these are linked from the download page): https://forum.armbian.com/topic/33676-installation-instructions-for-tv-boxes-with-amlogic-cpus These instructions tell you to run /root/install-aml.sh which is not what you said you did. Now a further note is that ophub is a fork of Armbian. They do not contribute to Armbian development, do not participate in these forums and use the Armbian name without permission. So if you choose to use their software, you will need to discuss their software on their forums as we can't help you at all with ophub software.
  25. Hi, thank you for the quick reply. I did read the install instructions, but the thing is there was no install script. I downloaded the minimal iot image I think. I did try updating armbian-config but there was no options for install. And since I didn't find many tutorials on how-to-install, I used claude - sonnet 4.5 (I kinda trust it more than gpt 5, but it still hallucinates sometimes). I admit I don't really like relying on ai tools, but I really find them quite useful (and sometimes quite wrong). Anyway, I don't know if the image didn't include install script or maybe I accidentally removed it with apt autoremove (shouldn't be the case, since I only removed xfce and related components with apt autoremove). And I couldn't find it with apt search. I have now downloaded an image from https://github.com/ophub/amlogic-s9xxx-armbian/releases. It has quite a bigger footprint: ~750MB compressed, compared to ~300MB compressed I downloaded from this site (labeled minimal iot). I also have acquired a h96 air p2 firmware from the official h96 site. Will report how it works. I still would like to try to flash armbian to mmc after I hopefully get it booting from the usb. Do you know why I didn't have an install script in my image? I mean how does it work, can I maybe just download it from somewhere (for my exact box) or why isn't it added in apt? I will try to flash this other image downloaded from github to the usb and see if there is the install script.
  26. You should have followed the install instructions on the download page: https://www.armbian.com/amlogic-s9xx-tv-box Given where you are now, you need to find an original android image, flash that to return the board to a clean state, and then follow those instructions. The amlogic s9xx TV box builds use the android bootloader to bootstrap the boot process which at this point you have overwritten part of.
  27. Hi Chris, when I tried to install the headers on my pcduino3nano, there were two options: linux-headers-armmp (or equivalent for your board) and kernel-headers. This secong package name was incomplete, but apt suggested a list of possible matches for my system. Give that a try. Cheers, Gaetano.
  28. Thanks Werner. Meanwhile I have tried a minimal image and did not plug the ethernet cable it, the Armbian initial boot script installed the drivers and connected seamlessly to wifi. No need for the marrownr external driver, so the headers problem is no longer a problem. Now I am keeping my fingers crossed that the OTG will work (it didn't work with Johang's latest images. So I created my own using hte armbian compilation script. It doesn't have Trixie for pcduino3nano, but bookworm should work. Cheers, Gaetano.
