  2. Unfortunately i do not have this board to compile/test on
  3. Yesterday
  4. by the way i can ssh into armbian while it’s stuck on a black screen so i can provide any logs you want
  5. Also, in a quick google search, the TX60 Pro generally has an Allwinner H313 CPU. Are you sure your box has an amlogic s905l cpu?
  6. What image are you using? What uboot and dtb are you using?
  7. I have bought a TX60 Pro with S905L CPU, 16 GB RAM and 256 GB eMMC. I tried to run Armbian on it: wrote several images on microSD, but since it does not have a microSD reader, I plug it in in a microSD reader. Unfortunately, it does not boot from it, not even when I start it with the Reset button pressed. Is there any chance I can run Armbian on this box?
  8. Appreciate the quick replies! Turns out im just an idiot, and completely forgot to freeze the kernel. have a great evening!
  9. Armbian-unofficial_25.05.0-trunk_X96q-ddr3_bookworm_edge_6.12.11_server.img This works for my 1.1 board
  10. What happens after this is needed. make sure loglevel is 7 in armbianEnv.txt Hopefully yo have a serial console cable so you can copy and paste the text here on the forum, is better than pictures on imgur (site is blocked in UK by the way)
  11. How to debug boot issues: https://debug.armbian.de
  12. sven-ola
    I operate an Odroid HC4, that has 4 x A55@1.8 and the board discussed here has 8 x X60@1.?. A fast sysbench says: single thread on OpiRv2 is slower (792 vs 1034) , multithreaded is faster (6342 vs 4151). Compiling a current kernel on RV2 needs 3 hours, nothing one would do do regularly. If you really need speed buy a Radxa Rock 5 (see platinum support devices on this site). Edit1: NPU -> Opi Wiki, USB and SPI yes, for MIPI DSI/CSI you need to test yourself. Edit2: Just remembered that I have a H618 (Opiz3). Single=708, Multi=2828 with the same Trixie sysbench. HTH + LG // Sven-Ola
  13. I just updated, and upgraded the image I installed via ssh. After a reboot nothing happens. If I then kill the power and boot it again, I get this very brief video output, where the last line is “starting kernel” and then it crashes. I managed to get a video of it, and took a few screenshots. https://imgur.com/a/COaD6lb any assistance is appreciated!
  14. I just had to take the service offline, and on boot it failed again. I had the updates installed, but not applied through a reboot. When i boot the device, i just get a few blinks on the heartbeat LED, and then nothing. Not even a display output. The only thing i can think of, is to try to reinstall the OS on the SD card, and then update through the CLI before i install OMV and see if i can get a different result. Any other advice? Thanks.
  15. robertoj
    Thank you guys for the work toward this RiscV SBC The website http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/details/Orange-Pi-RV2.html claims 130% faster than ARM A55 (which is 25% slower than my H618)... have you tested that? Are the USB, GPIO, SPI and MIPI DSI working? Are there any NPU examples provided by Orange Pi?
  16. Hello, I have installed a tinkerboard 2S and used it without problems for more than a year now. Today I started Armbian-upgrade to upgrade the system.I use a M2 WIFI card. What happens right after the reboot when the upgrade was done; the system boots normally, showing all information on the monitor, and about 5 seconds after the login prompt is displayed, it completely freezes. That is; the system doesn't react to keypresses on my USB keyboard, and SSH access isn't reacting. I can ping the device however and I know it is not dead as my .NET core application is running normally and I can access it externally! I use a wifi hotspot configuration; the wifi network is also not available after boot. Now, I have a NanoPI R3C also with M2 wifi and configured exactly the same; it also behaves the same: console freeze, no ssh access. When I remove the Wifi card it does not freeze so it looks like related to the wifi card/configuration. I bought a R67S with wifi as I though it was a hardware failure but now, after upgrading my tinker it appears it's software related. As my Tinkerboard 2S was working flawlessly before I upgraded; are there any known issues in Debian Trixie minimal installation? I use this on both devices. Regards, Frans
  17. @sicxnullI was curious if you would be able to make an image for v1.1 boards? I ask because v1.3 doesnt work for these older 1.1 boards and I am not as skilled as you at making images haha
  18. Why do you ask? The instructions linked to above don't have that as one of the steps for a normal install.
  19. You use a Desktop/Xfce installation, and it is for a low-power ARM64 computer. So I would not be surprised if in modern Xfce, the Power Management default to suspends after 30 minutes or so. Last time I used Xfce was when Debian Buster, also then in then I remember in the GUI there should be some system setting where you can configure power settings. So there you can make sure that it never enters suspend state. I do not know how to configure that from command line, but that should also be possible, maybe search internet. You can also look into the journal and see what happened, maybe something is wrong. 7 Watts is way too high for suspend state at least, but maybe things connected on USB still draw power and is it only the CPU that is halted. Other option is not to use a Desktop image/installation, but a CLI for server/IoT variant. Those images should have suspend disabled.
  20. This might help you: https://github.com/nyecov/roobi-config-anyOS It details how install basically any OS via Roobi
  21. Just confirmed. Running bookworm on the same RockPi-S, it "just works". Any suggestions on what happened in Trixie and if there's a fix?
  22. Can't seem to get bluetooth working with trixie and pipewire. I can pair & trust, just can't connect. Failed to connect: org.bluez.Error.Failed br-connection-profile-unavailable Anyone else had this issue? Was working fine on a cubie running bullseye, so next maybe I'll try and older os and see...
  23. Gave up after half an hour or more unplugged it for 10 secs, booted normally on power up but slow due to fchecking every drive in it, around 25Tb found the settings and turned that excrement off. Ignoring it to check. fix dinner, need a new cook, but I'd have to fire me. I think I've got it from here. Thank you, a bunch, eselarm.
  24. Last week
  25. However above that is a whole slew of failures "network unreachable" and ip a or ip r both show the help screen. Let me run armbian-config again, from here. Did, network didn't survive a reboot. Went to its own monitor and reran armbian-config, no net settings. reset them again. ping yahoo.com, worked. Ran sudo apt update, got 181 pkgs to update, did sudo apt upgrade -y & watched it for half an hour. Completed this time. rebooted, network survived. So I should be able to restore it from its own backups once I get it to mount the /raid6. Found it had a /raid6 dir for a mount point snooped thru /dev/disk/ to the by-id, found the file with myraid in its name, mounted it, ran df to see a normal report, then it suspended. Never did that before. Ever. Now, whats the magic potion that un-suspends it?, it went into suspension while I was logged in from here, and nothing I can do to the keyboard or mouse, local or remote wakes it up again. Power draw is down to about 7 watts. I need to totally disable that, how do it?
  26. Using Network-manager as a slave to armbian-config, no root pw. sudo for everything. Let me see if I can login from "ssh -X gene@amanda" using the ip in my hosts file. Yes, so I can copy/paste: This is the final screen of a "sudo apt update" commend. Had to nuke my local keys first. E: The repository 'http://ports.ubuntu.com noble Release' no longer has a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'http://ports.ubuntu.com noble-security Release' no longer has a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'http://ports.ubuntu.com noble-updates Release' no longer has a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'http://ports.ubuntu.com noble-backports Release' no longer has a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'https://apt.armbian.com noble Release' no longer has a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'https://github.armbian.com/configng stable Release' no longer has a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. Same thing I'm seeing on its own monitor.
