@C127I forgot to ask. Is USB3 port working for you in your kernel ? -
@Igor@amazingfate Can someone look at this issue please ? I am wondering if this is possibly affecting a large number targets or whether its just BananaPi-M7 / rockchip64 ? I have tried on another monitor also and am getting a black screen. On doing an `apt-get upgrade` on ssh terminal I happened to loose by HDMI display. AFAICT It looks like Ubuntu 'backgraded' gnome v46 (in Nobel release, and also in my older unofficial image) to v44. https://armbian.atlassian.net/jira/software/c/projects/AR/issues/AR-2702?jql=project %3D "AR" ORDER BY created DESC
Sure. I am here to test it when you send. Next week I will be off for about 7 days, but we can test until that after that. -
You are right, I was too focused on the eMMC. The fact that sdio is used for WiFi/BT on this board suggests a more complex problem with the main SDHCI controller in U-Boot. This means my U-Boot patch is still in a very early stage, and I need to do a deeper analysis of how all these interfaces are powered and configured. I will continue working on it and will let you know when I have a new patch to test. -
Actually the 0.4 was trying to boot from MMC1 and the 0.5 from MMC2. is this expected ? -
@C127 Tested, same problem DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18 ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 ch0 ttot7 LPDDR5, 2400MHz channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch1 ttot7 channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch2 ttot7 channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch3 ttot7 channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB Manufacturer ID:0xff DQS rds:h1,l0 CH0 RX Vref:24.6%, TX Vref:23.0%,22.0% DQ rds:h5 h2 h1 h2 h1 h5 l0 h7, h1 h1 h3 h3 h1 h1 h7 l0 DQS rds:l0,h2 CH1 RX Vref:27.9%, TX Vref:21.0%,21.0% DQ rds:h5 l0 h2 h2 h6 l0 h7 l0, h7 h5 h4 h4 l1 h1 h6 h7 DQS rds:l0,h2 CH2 RX Vref:25.4%, TX Vref:22.0%,21.0% DQ rds:h1 l0 h2 l2 h1 h1 h5 h1, l1 h7 l2 h4 l2 h1 h1 h3 DQS rds:l0,h1 CH3 RX Vref:27.9%, TX Vref:21.0%,21.0% DQ rds:h3 h1 h1 h1 h4 h1 h1 h1, h5 h6 h2 h2 h3 h5 l0 h5 stride=0x2, ddr_config=0x6 hash ch_mask0-1 0x20 0x40, bank_mask0-3 0x0 0x2400 0x44800 0x89000, rank_mask0 0x2000 change to F1: 534MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F2: 1320MHz ch0 ttot8 ch1 ttot8 ch2 ttot8 ch3 ttot8 change to F3: 1968MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F0: 2400MHz ch0 ttot7 ch1 ttot7 ch2 ttot7 ch3 ttot7 out U-Boot SPL 2024.04-armbian-2024.04-S2504-Pdd14-H29de-Vbf83-Bb703-R448a (Jul 11 2025 - 23:38:46 +0000) Trying to boot from MMC2 Card did not respond to voltage select! : -110 spl: mmc init failed with error: -95 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### -
Hello @salas, Thank you for the incredibly detailed testing and analysis! You are absolutely right, the problem is entirely aligned with U-Boot. Your observation that the kernel can see the eMMC after booting from the SD card is the key. It proves the hardware is fine and the kernel's eMMC driver is working correctly. The issue is that the U-Boot SPL (Secondary Program Loader) is not initializing the eMMC interface properly at boot time. Based on this, I've created a new patch (v0.5) that specifically targets this U-Boot initialization problem. I have adjusted the U-Boot device tree in an attempt to correctly enable the eMMC interface during the SPL phase. I have just updated the pre-compiled image in the "Releases" section of my build repository to v0.5. Thanks again for your amazing help! - Yesterday
Post not related to 0.4! Since yesterday I've been doing a few tests on your kernel patch against mainline kernel 6.16-rc5. here what I found out. I am testing against Johsua's ubuntu because this is my goal ( newer kernel on that image ) 1) Kernel compile and works , but I get a few warnings on the dtbs compilation DTC arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dtb arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dts:235.3-13: Warning (reg_format): /mmc@fe2d0000/wifi@1:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1) arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dtb: Warning (pci_device_reg): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dtb: Warning (pci_device_bus_num): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dtb: Warning (i2c_bus_reg): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dtb: Warning (spi_bus_reg): Failed prerequisite 'reg_format' arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dts:233.17-241.4: Warning (avoid_default_addr_size): /mmc@fe2d0000/wifi@1: Relying on default #address-cells value arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-pro.dts:233.17-241.4: Warning (avoid_default_addr_size): /mmc@fe2d0000/wifi@1: Relying on default #size-cells value 2) Your patch works and makes the system bootable from the SDCARD. U-boot reads the /boot from the sdcard, since it can not find the EMMC, but after booting I can have to / on the EMMC and that works. 3) Curiously after the uboot handoff to the linux kernel, emmc is available but the sdcard fails to initialize emmc initialize just fine with the / [ 10.225763] mmc2: new HS400 Enhanced strobe MMC card at address 0001 [ 10.228424] mmcblk2: mmc2:0001 A3A564 233 GiB [ 10.233239] mmcblk2: p1 p2 [ 10.234373] mmcblk2boot0: mmc2:0001 A3A564 4.00 MiB [ 10.237884] mmcblk2boot1: mmc2:0001 A3A564 4.00 MiB So I basically have a working system but it requires the sdcard to boot and I can not mount the sdcard after boot root@pi5pro1:~# uname -r 6.16.0-rc5 root@pi5pro1:~# cat /etc/os-release PRETTY_NAME="Ubuntu 24.04.1 LTS" NAME="Ubuntu" VERSION_ID="24.04" VERSION="24.04.1 LTS (Noble Numbat)" VERSION_CODENAME=noble ID=ubuntu ID_LIKE=debian HOME_URL="https://www.ubuntu.com/" SUPPORT_URL="https://help.ubuntu.com/" BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/" PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy" UBUNTU_CODENAME=noble LOGO=ubuntu-logo -
destroyedlolo replied to Shakai2's topic in Allwinner sunxi
Hi, I'm facing the same issue with my BananaPI-M1 running ARMbian and I have another one bPI-M1 running ArchARM which is suffering exactly for the same issue (bPI is not supposed to be supported but it working pretty well but this HDMI issue and the miss of AXP209 exposition). I'm a bit lost about the current status : is the upstream 6.15 (or upcoming 6.16) already patched/corrected ? @eselarm The link seems dead 🙂 -
@C127 0.4 output. Still no boot DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18 ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 ch0 ttot7 LPDDR5, 2400MHz channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch1 ttot7 channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch2 ttot7 channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch3 ttot7 channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB Manufacturer ID:0xff DQS rds:h1,l0 CH0 RX Vref:24.6%, TX Vref:21.0%,21.0% DQ rds:h4 h2 h1 h2 h1 h5 l0 h7, h1 h1 h3 h3 h1 h1 h7 l0 DQS rds:l0,h2 CH1 RX Vref:27.9%, TX Vref:21.0%,21.0% DQ rds:h4 l0 h2 h3 h7 l0 h7 l0, h6 h5 h4 h5 l1 h1 h6 h6 DQS rds:l0,h2 CH2 RX Vref:25.0%, TX Vref:21.0%,21.0% DQ rds:h1 l0 h2 l3 h1 h2 h5 h1, l1 h7 l1 h4 l2 h1 h1 h3 DQS rds:l0,h1 CH3 RX Vref:27.5%, TX Vref:21.0%,21.0% DQ rds:h3 h1 h2 h1 h4 h1 h1 h1, h5 h6 h2 h2 h4 h4 l0 h5 stride=0x2, ddr_config=0x6 hash ch_mask0-1 0x20 0x40, bank_mask0-3 0x0 0x2400 0x44800 0x89000, rank_mask0 0x2000 change to F1: 534MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F2: 1320MHz ch0 ttot8 ch1 ttot8 ch2 ttot8 ch3 ttot8 change to F3: 1968MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F0: 2400MHz ch0 ttot7 ch1 ttot7 ch2 ttot7 ch3 ttot7 out U-Boot SPL 2024.04-armbian-2024.04-S2504-P83ae-H29de-Vbf83-Bb703-R448a (Jul 03 2025 - 17:49:57 +0000) Trying to boot from MMC1 Card did not respond to voltage select! : -110 spl: mmc init failed with error: -95 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### -
I will flash the new image now and let you know what happens, -
I will gladly help you to test it. Just to let you know, on 0.3 apparently If i boot from the sdcard, after booting the emmc is available. So the kernel knows about it. just uboot does not ? -
No HDMI after upgrading the system
destroyedlolo replied to destroyedlolo's topic in Allwinner sunxi
Thanks, I'll pursue with the thread you mentioned. -
MXQ MBX Model M201 amlogic s805
s-petersen replied to s-petersen's topic in TV Boxes running Armbian
If you guys want Bionic, I can remove stretch, and link it. You should try to download stretch again, and try a different SD card before anything else. -
radioarica replied to s-petersen's topic in TV Boxes running Armbian
Ricardo Martin Mantelli seria bueno saber que equipo estas usando, porque en mi caso con una MXQ 4K con Amlogic S805 me anduvo sin problemas. -
Hello @salas Thanks a lot for testing and for the eMMC boot log! That's super helpful. I'm ready to tackle the eMMC boot issue. As you saw, it's failing very early in the U-Boot SPL, so it's definitely a hardware initialization problem. I'm creating a new fork to add a patch for this (Patch >=v0.4). Since I can't test it myself (I don't own an eMMC module), I would need your help to flash and test the new images. With a bit of luck and your feedback, we should be able to get it working. -
@re.ADW You can generate and share the "SHA256" hash of the image that was used on your board, please...
Hello, One of my BananaPI is used to display a graphical dashboard. But after a system upgrade (apt update / apt upgrade), the HDMI output seems disabled after reboot : - the boot process is displayed, but it seems it's disabled as soon as the DRM driver is loaded. Any tips, help ? Thanks # uname -a Linux TdB 6.12.30-current-sunxi #1 SMP Thu May 22 12:29:54 UTC 2025 armv7l GNU/Linux # cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=bananapi BOARD_NAME="Banana Pi" BOARDFAMILY=sun7i BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=1a8daf0 VERSION=23.02.2 LINUXFAMILY=sunxi ARCH=arm IMAGE_TYPE=nightly BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=Image BRANCH=current
eselarm replied to Shakai2's topic in Allwinner sunxi
i do not use armbian-config normally, but there is a 6.12.35 here http://beta.armbian.com/pool/main/l/linux-6.12.35/ (fix or edit or follow path/mirror youself) -
Ryzer replied to Shakai2's topic in Allwinner sunxi
@eselarm ok thats interesting. Is it not even listed if looking for alternative kernels via armbian-config? Scrolling through the collection of community creation builds does not appear to list anything for the M1 only for the Pro Model. -
Just noticed I was not up to date, I did a armbian-upgrade and still no change. Here is an updated paste : https://paste.armbian.de/loderavavi
@Ryzer just started it, was updated a week ago or so: root@banlipi:~# uname -a Linux banlipi 6.12.30-current-sunxi #1 SMP Thu May 22 12:29:54 UTC 2025 armv7l GNU/Linux root@banlipi:~# dmesg | grep drm [ 0.996620] sun4i-drm display-engine: bound 1e00000.display-frontend (ops 0xc0bb0c8c) [ 0.996924] sun4i-drm display-engine: bound 1e20000.display-frontend (ops 0xc0bb0c8c) [ 0.997494] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0bb03f8) [ 0.997999] sun4i-drm display-engine: bound 1e40000.display-backend (ops 0xc0bb03f8) [ 0.998903] sun4i-drm display-engine: No panel or bridge found... RGB output disabled [ 0.998973] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0bae8e8) [ 0.999936] sun4i-drm display-engine: No panel or bridge found... RGB output disabled [ 1.000015] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops 0xc0bae8e8) [ 1.002143] sun4i-drm display-engine: bound 1c16000.hdmi (ops 0xc0bb1688) [ 1.004289] [drm] Initialized sun4i-drm 1.0.0 for display-engine on minor 0 [ 1.004495] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes [ 1.032416] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes [ 6.475086] [drm] Initialized lima 1.1.0 for 1c40000.gpu on minor 1 [ 11.323101] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... [ 12.107664] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 12.124764] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. no newer kernel available via apt now I see when running update. -
Hello. I have no Xorg installed, so no xorg config. I'm checking the correct resolution on the command line. xrandr is not available either, I'd rather not install it if possible. Here is the log paste : https://paste.armbian.de/nitibagujo Thanks for having a look!
Hi, can you provide logs with: PASTE_SERVER_HOST=paste.armbian.de armbianmonitor -u Also, take a look at this thread how to force a mode using boot parameters and Xorg config. https://forum.armbian.com/topic/46932-5-inch-hdmi-display-not-working/#comment-206059 I suggest you connect your monitor to a linux system which supports it and gather the modelines there with: xrandr --verbose Then you can try to force that missing mode. Cheers
