  2. before: Orange Pi Zero (H+), CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 512 MiB TF card is Samsung Evo Plus 64GB; After writing the TF card with Win32DiskImager, the same issue occurred: normal boot-up and shutdown, but when executing a reboot, it gets stuck at the final stage of service termination before restarting. ...... [ OK ] Reached target shutdown.target - System Shutdown. [ OK ] Deactivated swap dev-zram0.swap - /dev/zram0. [ OK ] Reached target umount.target - Unmount All Filesystems. [ OK ] Reached target final.target - Late Shutdown Services. [ OK ] Finished systemd-reboot.service - System Reboot. [ OK ] Reached target reboot.target - System Reboot. [44967.125952] systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argument systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argument [44967.761002] reboot: Restarting system This is where it starts to lose responsiveness! after: Following someone's guidance, I was told to install or update u-boot: run armbian-install, then selected “Install/Update the bootloader on SD card (/dev/mmcblk0)”. After the update completed, needed to shut down the system and disconnect the power (the first time I performed a reboot here, but it got stuck again at the final stage of stopping services before restarting, just like before). so I had to disconnect the power, then plug it back in for an automatic boot-up. After that, performing a reboot worked normally without getting stuck). ...... [ OK ] Reached target shutdown.target - System Shutdown. [ OK ] Deactivated swap dev-zram0.swap - /dev/zram0. [ OK ] Reached target umount.target - Unmount All Filesystems. [ OK ] Reached target final.target - Late Shutdown Services. [ OK ] Finished systemd-reboot.service - System Reboot. [ OK ] Reached target reboot.target - System Reboot. [44967.125952] systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argument systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argument [44967.761002] reboot: Restarting system U-Boot SPL 2024.01-armbian-2024.01-S866c-P7738-Ha5c2-Vd711-Bb703-R448a (Aug 16 2025 - 02:09:48 +0000) DRAM: 512 MiB Trying to boot from MMC1 ns16550_serial serial@1c28000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2024.01-armbian-2024.01-S866c-P7738-Ha5c2-Vd711-Bb703-R448a (Aug 16 2025 - 02:09:48 +0000) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 512 MiB Core: 69 devices, 18 uclasses, devicetree: separate WDT: Not starting watchdog@1c20ca0 MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial,usbkbd Out: serial Err: serial Net: eth0: ethernet@1c30000 starting USB... Bus usb@1c1a000: sun4i_usb_phy phy@1c19400: External vbus detected, not enabling our own vbus USB EHCI 1.00 ...... You can see that immediately after the log entry "[44967.761002] reboot: Restarting system", the system begins booting.
  4. Hello @Going, I mean If uboot is available on a sdcard plugged in, it will boot on it else on emmc, Sometimes when UUID are the same, it is the last device discovered that overlaps. Wehen cloning emmc UUID back to sdcard do'nt change. My mind was to have a multiboot like refind or ventoy that helps if a system crashed. having a failsafe system aside to fix it graphically can be a must. Changing /boot/boot.cmd that affect u-boot may do the work
  5. Yesterday
  6. Apologies for being late to the party, and please excuse me for commenting on something which may already have been fixed. What is the difference between enabling the flag, and allowing whatever apps to work if they can, and disabling it so they certainly can't work? Seems to me that enabling it would make most sense, since H3 SOCs support it.
  7. Thank you all for your input. And a big thank to @djurny I will double check if end user can add static route on their Windows machine or whatever PC1 is. route add 10.10.10.2 mask 255.255.255.255 192.168.100.101 As this solution appears to work. Alternative way is bridging the NICs however Device1 requires separate subnet from NIC1.... Thank you again.
  8. Summary Update: A Look At Pure Ubuntu (no Armbian) --> The bug was there, then it was not! Initial Observation: Debian 13 (Trixie) The Bug Is Present Operating System: Debian GNU/Linux 13 KDE Plasma Version: 6.3.6 KDE Frameworks Version: 6.13.0 Qt Version: 6.8.2 Kernel Version: 6.16.4-edge-rockchip64 (64-bit) Graphics Platform: Wayland Ubuntu 25.04 The Bug Is Present Distributor ID: Ubuntu Description: Ubuntu 25.04 Release: 25.04 Codename: plucky Operating System: Ubuntu 12 KDE Plasma Version: 6.3.4 KDE Frameworks Version: 6.12.0 Qt Version: 6.8.3 Kernel Version: 6.16.0-17-generic (64-bit) Graphics Platform: Wayland Ubuntu 25.10 The Bug Is Gone! Distributor ID: Ubuntu Description: Ubuntu Questing Quokka (development branch) Release: 25.10 Codename: questing Operating System: Ubuntu 13 KDE Plasma Version: 6.4.5 KDE Frameworks Version: 6.17.0 Qt Version: 6.8.3 Kernel Version: 6.16.0-17-generic (64-bit) Graphics Platform: Wayland Conclusion The bug was in Ubuntu. Then it wasn't. So the answers to how to fix it are likely in the changes made in or by Ubuntu.
  9. I have a question regarding the configuration of the /etc/asound.conf file... are there any changes in the new kernel that prevent this from happening? I've noticed that my USB audio card no longer loses its settings and its position doesn't change. However, to be sure, I tried editing the /etc/asound.conf file... but it turns out to be impossible 🙂 That is, after saving the settings in /etc/asound.conf... ALSA doesn't work! 🙂 Moreover, the blocking for certain selected devices doesn't work either. In my case, the blocking is: HDMI Audio... in the file: /etc/modprobe.d/blacklist.conf blacklist sun9i_hdmi_audio blacklist snd_soc_simple_card Are these changes related to the detection/blocking, etc., of block devices in Linux?
  10. Any progress on this?
  11. just 2 cents : if PC1 can access "Rocky Liinux" , if what you need is to access a particular UDP or TCP port on Device 1 10.10.10.2, you can try port forwarding normally done with iptables, nftables, ufw etc also called NAT (netowork address translation) e.g. https://wiki.nftables.org/wiki-nftables/index.php/Performing_Network_Address_Translation_(NAT)#Destination_NAT this needs to be done on "Rocky Linux"
  12. Yes. This is an example of a rk3588 based board of mine: overlay_prefix=rockchip-rk3588 overlays=panthor-gpu opp-oc-24ghz The overlay names come from /boot/dtb/*/ find an overlay matching your soc and needs and enable by putting its name to overlays=. Then reboot. Having a serial console to read uboot logs can show if it has been loaded properly or in case it did not why.
  13. This is the default configuration: verbosity=1 bootlogo=false console=both extraargs=cma=256M overlay_prefix=rk35xx fdtfile=rockchip/rk3566-radxa-zero3.dtb rootdev=UUID=526007c3-3a0f-451d-a7a7-6d896d15f910 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  14. Update: I just ran Ubuntu 13 (25.10 (development branch)), downloaded from their site (not Armbian), running their kernel. There I installed KDE Plasma 6.. Wayland performance was excellent. The bug I described here didn't show up at all. This version of Ubuntu seems more similar to Trixie than Bookworm. And some of their related package names, like Trixie's, did seem to mention porting from QT5 to QT6. So whatever bug is existing in Trixie was either not created, skipped, or solved by Ubuntu. Operating System: Ubuntu 13 KDE Plasma Version: 6.4.5 KDE Frameworks Version: 6.17.0 Qt Version: 6.8.3 Kernel Version: 6.16.0-13-generic (64-bit) Graphics Platform: Wayland
  15. Hi there, Then I would advise to try to: bridge NIC1 and NIC2, then configure the resulting bridge interface br0 to 192.168.100.101/24 configure 'device 1' to 192.168.100.102/24 or some other IP address that does not overlap/conflict with any other device on the 192.168.100.0/24 network. This setup should present "one interface" to the 192.168.100.0/24 network, pulling 'device 1' into the network as it were. I'm not sure if you have to enable ip forwarding in case you create a bridge, my experience with bridge (both networking and card wise) is limited. Groetjes, Btw, there has to be a reason why PC1 and the gateway/router in the red box are not able to be changed 😉 Perhaps the people that set it up that way were actively trying to prevent fanning out into different additional networks. (I know many employers do not allow this on their office network for example, for very good reasons...)
  16. Last week
  17. Well I was able to build by changing the docker image with this option : DOCKER_ARMBIAN_BASE_IMAGE=ubuntu:jammy The two other images (debian:bookworm and ubuntu:noble) simply do not work
  18. Hey Sam, busy week so only getting around to replying - yes there are pre-built images for it but we took them down because I wasn't happy with the state it was in. We have a patch we're cleaning up that add the packages for GPU Acceleration and Wifi/BT that we're going to merge today/this weekend so I will re-enable the image generation and it will show up under Supported boards tomorrow/Sunday. If you do end up getting it and trying it out feel free to reach out here or on discord and let me know if you run into anything.
  19. sha256sum Armbian_25.5.1_Rock-5b_noble_vendor_6.1.115_gnome_desktop.img.xz 1b5b3f8e9f136772dd0e3b80990f7cd2ed305e34db7510ea4f4fd83d3f40b5f0 cat Armbian_25.5.1_Rock-5b_noble_vendor_6.1.115_gnome_desktop.img.xz.sha 8ebcc156f53bf8a826bba4291e8ff3fce8037be64c02b4ca59f6befbe361586c xz -t Armbian_25.5.1_Rock-5b_noble_vendor_6.1.115_gnome_desktop.img.xz xz: Armbian_25.5.1_Rock-5b_noble_vendor_6.1.115_gnome_desktop.img.xz: Unexpected end of input I tried many mirrors. It has been like this since it's May release. Torrent download also fails keeps rejecting fragments presumably due mismatching checks. Is suspect the file got corrupted somehow
  20. endgoal is Device 1 is reachable from PC1 - with PC1 settings all can NOT be changed and ideally Device1 on completely different subnet...
  21. Not to forget this: What is your endgoal here? You just want to ping 'device 1' from PC1 ? Or you want to connect to 'device 1' from PC1 using some protocol? Gr,
  22. I am pleased to confirm that DSI is now working with the official images (Tested Armbian 25.8.1 Trixie minimal). 👍
  23. Hi there, You could try to change 10.10.10.0/24 to 192.168.100.0 but this can cause IP overlap if you do not have control over the 192.168.100.0/24 network. If NIC1 and NIC2 are part of the same network, you will have to make sure that all traffic to the default gateway will exit via NIC1, `ip route` should show the device it will use. I do not have any experience with setting up bridge networks, perhaps someone else can help with that - using bridge containing both NIC1 and NIC2 might be the easiest way, but you will have to fix/work the IP address overlap it will create. (link: https://www.baeldung.com/linux/bridging-network-interfaces) Hope that helps, Groetjes,
  24. Nothing I can change on PC1 - Also PC1 could be a master device with pre-defined IP settings beyond my control hence Im using PC1 as an example. I have altered the diagram abit however the IP settings for PC1 can NOT be adjusted... does this allow any further options we can think off ?
  25. Hi there, In this setup with these networks you specified, it is really PC1 - or the gateway/router in the red box that need to know where to send packets to for 10.10.10.0/24. This is usually done by a static route on the gateway/router, or by adding a hop in the routing on PC1. If neither know where packets for 10.10.10.0/24 need to go to, they will be forwarded to the default route of firstly PC1 (which is the gateway) and on the gateway/router's default route. If you can change neither, you will need to think about more exotic solutions, like setting up an ssh tunnel from PC1 and using rocky linux as a jumphost. Or, as you also imply, perhaps bridging 192.168.100.0/24 with 10.10.10.0/24, which (i think) will chaning 10.10.10.0/24 to a subnet of 192.168.100.0/24. What are your options/abilities in PC1 here? What can you change and what not? Do you have administrator rights for example? Can you run/install cygwin or any windows flavor of ssh for example? What is the WAN side of the gateway/router? The internets or some other network? What can also work is to put 'device 1' in that network, if all you need is to ping it. Groetjes,
  26. Hi djurny, Appreciate your replies and assisting. regards to #1 - I can not add any routes on this Windows machine - its managed by others, I only have user access with only limited access. Points for #2 - tried those no luck. I was thinking what if i was to change NIC2 within the subnet as NIC1 - will this work ? Or am i really missing something in terms of static routing on the Linux Box... ?
  27. @maça dev Try extract multitool.img.xz first, after that, burn multitool.img using balenaEtcher, dd, or any other burning tool
  28. Overlays can be added manually as well. Check /boot/armbianEnv.txt
  29. wich OS system Windows balenaEtcher, linux "dd" , do you perform checksum
