Weekly developers meetup
Igor
Community Calendar
This week's meeting topics:
- Check remaining Jira tickets https://www.armbian.com/participate/
- Review issues https://github.com/armbian/build/issues
- Review pull requests https://github.com/armbian/build/pulls
The general goal of weekly meetings:
- To discuss the three (3) issues of the week
- Discussions will be documented to respective Jira tickets so they can be tracked
- Three (3) new issues will be selected from Jira for the next meeting
A weekly developers' meeting aims to coordinate the development of the build engine, continuous integration, operating system features, and low-level support. Meetings are hosted on Jitsi (Video), IRC, and Discord (Text). While we would prefer you attend on Jitsi when possible, we will also monitor text chat during the call for those unable to join Jitsi.
Please RSVP either way.
Do you want to participate or help in some way?
Meetings are focused on developers' top-level topics, and it's expected that they understand embedded software development, software testing, or operating system management. Knowledge of at least BASH & Python is expected in terms of programming languages.
Since meetings are held in public, any registered community member can join and listen. If you want to suggest issues for the next week, you have to be recognized Armbian contributor. If you want to become one, resolve at least one intermediate-level issue and tell us something about yourself. This is needed to communicate efficiently and to give you access to our organization infrastructure Jira, Github, hardware lab, and servers.
@Contributor/Maintainer
Recommended Comments
schwar3kat
Hi developers,  I'm missing the video's, since July.  Any chance that you can record and post the video?
Igor
Sorry! We'll do best ... today we almost couldn't produce it for technical reasons. Will be published once tomorrow.
Igor
Meeting held, didn't record. It was just @Tearran and me discussing armbian-config related issues. Next week are vacations for many people, so I guess we could just skip it.
Igor
On 11/16/2023 at 2:17 AM, schwar3kat said:
Winter, Spring, Summer, Autumn.
This can only apply in northern hemisphere countries.  Southern hemisphere is the opposite months.
First quarter, second quarter, third quarter, fourth quarter are possible alternate options.
We forgot on you guys down there :)  Good catch!
Also good task for those who complain they are not contribution as they are not software developers.
https://armbian.atlassian.net/browse/AR-1933
schwar3kat
7 hours ago, Igor said:
I watched this week's video, and have a question about Joey's configng presentation.
If my understanding is correct then the directory/folder that contains the script function determines the menu group, and the script header description determines the menu item wording.
How can we include/exclude a script in the menu based on a runtime condition, like it is possible in armbian config?  E.g. depending on a file or executable existing.
How can we include/exclude a script group in the menu based on a runtime condition like it is possible in armbian config?
Tearran
:) , Great point,  @Igor  Pointed out a probable solution to the concept, &  https://github.com/armbian/configng/blob/main/bin/armbian-configng#L25
community direction is needed. Such as use cases for what to show or hide, and what to checks to make the determination.  @Igor  Pointed out a probable solution to the concept, Basic consept logic https://github.com/armbian/configng/blob/main/bin/armbian-configng#L25
The current armbian-config has much of the said "runtime conditions" covered, To progress development, a generalized approach has been taken, keeping current armbian-config compatibility has been a priority.
As for general condition checking. There are a some working examples of approach. With some limitations. Arguably $args. :D Sorry, I mean "options".
To progress a more focused approach development. Community direction is needed.  GIven my choice alone I would continue Focus on Developing ... ,  More accurately playing with a text editor and flat file UI UX elements, svg, html etc. for the project
schwar3kat
@Tearran Bear in mind I'm not experienced with bash, so expect some ignorance 😄
Perhaps some kind of standard initialization function if it exists, could be triggered first as each script is parsed,  setting initialization variables could be included as a standard part of any function script.  And a similar menu folder initialization script could be included in any folder.
One of those variables could set visibility.  Another could set menu text, allowing dynamic menu text based on runtime requirements and possibly other options could be added if required.
Any logic could be used to set those variables.
To illustrate with an example of what I am imagining.  Maybe something like this:
(excuse my bash if it is bad or not feasible)
# @description Do something useless.
# @exitcode 0  If successful.
# @options none
# menu_init function triggered first by menu creation routines if it exists
function menu_init(){
    # Only display menu option if internet connection is available
    wget -q -t 1 --timeout=5 --spider http://github.com
    if [[ $? -ne 0 ]]; then
        menu_item=false
    else
        menu_item=true
    fi
    menu_text='Do something useful' # this could override the description as the menu text if it exists
function group::string() {s
    echo "Doing something"
    return 0
Tearran
@schwar3kat  Bear in mind you have clearly the advantage of specialised knowledge here.:D
Clearly proven by that pattern  😅 , it is brilliant. For one its set context for🤯.... before I get distracted again 😅
This does not seem to be the place to continue expanding. I am unsure!  Do you have collaborative insight you could share? Could you suggest a better place to expand on this topic?
schwar3kat
@Tearran I changed the function name in my example to menu_init (because that would be a more accurate description).
I have opened an issue on https://github.com/armbian/configng/issues/26 where the discussion could continue.
Also feel free to pm me.
Regards
Kat
Igor
From user perspective - it should function approximately the same. We need to come up with better code (style) as existing one, then upgrade and move further.
For now, this community its me and @schwar3kat I am sure more ideas will come on the way ...  Yeah, lets continue this directly at PR.
Igor
Skipped. Next week is holiday season and we are skipping it too. Next one, next year!
Add a comment...
