Rui Ribeiro Posted September 16, 2016 Share Posted September 16, 2016 Hi, Did today a kernel update...upon reboot, has no connectivity. I have lost swconfig; copied the one that comes with the sdcard/img download, it booting the switch by default, but does not allow to do much more...the reset and set operations are giving an error. What could I do? 1 Link to comment Share on other sites More sharing options...
zador.blood.stained Posted September 16, 2016 Share Posted September 16, 2016 Please install this swconfig (and remove the one you copied manually to be sure that you are using the new one): http://apt.armbian.com/pool/utils/s/swconfig/swconfig_15.04-1~armbian5.20%2B1_armhf.deb After that, please post exact output/error messages that you have. Link to comment Share on other sites More sharing options...
Rui Ribeiro Posted September 16, 2016 Author Share Posted September 16, 2016 Thanks Zador.b.s, it has got exactly the same behaviour. root@ruir:/etc/network# swconfig dev eth0 set reset 1 failed root@ruir:/etc/network# swconfig dev eth0 set enable_vlan 1 root@ruir:/etc/network# swconfig dev eth0 vlan 101 set ports '3 8t' root@ruir:/etc/network# swconfig dev eth0 set apply 1 failed root@ruir:/etc/network# uname -r 4.7.3-sunxi root@ruir:/etc/network# swconfig list Found: switch0 - eth0 Link to comment Share on other sites More sharing options...
zador.blood.stained Posted September 16, 2016 Share Posted September 16, 2016 And output of swconfig dev eth0 help please Link to comment Share on other sites More sharing options...
wildcat_paris Posted September 16, 2016 Share Posted September 16, 2016 @zador.blood.stain thanks, I thought I had a problem 2 days ago when I compiled the kernel (I copy/paste the swconfig binary from older debs) [gr@bpi:~] $ sudo dpkg -i swconfig_15.04-1~armbian5.20+1_armhf.deb [sudo] password for gr: Selecting previously unselected package swconfig. (Reading database ... 181437 files and directories currently installed.) Preparing to unpack swconfig_15.04-1~armbian5.20+1_armhf.deb ... Unpacking swconfig (15.04-1~armbian5.20+1) ... Setting up swconfig (15.04-1~armbian5.20+1) ... [gr@bpi:~] $ whereis swconfig swconfig: /sbin/swconfig /usr/local/bin/swconfig [gr@bpi:~] $ ll /sbin/swconfig /usr/local/bin/swconfig -rwxr-xr-x 1 root root 14036 Sep 14 18:25 /sbin/swconfig* -rwxr-xr-x 1 root root 34868 Apr 2 2015 /usr/local/bin/swconfig* [gr@bpi:~] $ /sbin/swconfig list Found: switch0 - eth0 so I need to delete the old /usr/local/bin/swconfig edit: not yet thanks Link to comment Share on other sites More sharing options...
wildcat_paris Posted September 16, 2016 Share Posted September 16, 2016 [gr@bpi:~] $ /usr/local/bin/swconfig dev eth0 help switch0: eth0(BCM53125), ports: 9 (cpu @ 8), vlans: 4096 --switch Attribute 1 (int): enable_vlan (Enable VLAN mode) Attribute 2 (string): ports (Available Ports (as bitmask)) Attribute 3 (int): reset_mib (Reset MIB counters) Attribute 4 (int): enable_jumbo (Enable Jumbo Frames) Attribute 5 (int): allow_vid_4095 (Allow VID 4095) Attribute 6 (none): apply (Activate changes in the hardware) Attribute 7 (none): reset (Reset the switch) --vlan Attribute 1 (ports): ports (VLAN port mapping) --port Attribute 1 (string): mib (Get port's MIB counters) Attribute 2 (int): pvid (Primary VLAN ID) Attribute 3 (string): link (Get port link information) [gr@bpi:~] $ /sbin/swconfig dev eth0 help switch0: eth0(BCM53125), ports: 9 (cpu @ 8), vlans: 4096 --switch Attribute 1 (int): enable_vlan ((null)) Attribute 2 (string): ports ((null)) Attribute 3 (int): reset_mib ((null)) Attribute 4 (int): enable_jumbo ((null)) Attribute 5 (int): allow_vid_4095 ((null)) Attribute 6 (unknown): apply ((null)) Attribute 7 (unknown): reset ((null)) --vlan Attribute 1 (ports): ports ((null)) --port Attribute 1 (string): mib ((null)) Attribute 2 (int): pvid ((null)) Attribute 3 (string): link ((null)) not sure about the "((null))" and the binary size is very short Link to comment Share on other sites More sharing options...
Rui Ribeiro Posted September 16, 2016 Author Share Posted September 16, 2016 Here it is Zador. I only have one swconfig, unlike goldfish #swconfig dev eth0 help switch0: eth0(BCM53125), ports: 9 (cpu @ 8), vlans: 4096 --switch Attribute 1 (int): enable_vlan ((null)) Attribute 2 (string): ports ((null)) Attribute 3 (int): reset_mib ((null)) Attribute 4 (int): enable_jumbo ((null)) Attribute 5 (int): allow_vid_4095 ((null)) Attribute 6 (unknown): apply ((null)) Attribute 7 (unknown): reset ((null)) --vlan Attribute 1 (ports): ports ((null)) --port Attribute 1 (string): mib ((null)) Attribute 2 (int): pvid ((null)) Attribute 3 (string): link ((null)) 1 Link to comment Share on other sites More sharing options...
zador.blood.stained Posted September 16, 2016 Share Posted September 16, 2016 not sure about the "((null))" and the binary size is very short Probably default compiler settings for packaging are wrong, I'll have to tweak these and make some versions for testing. 1 Link to comment Share on other sites More sharing options...
Rui Ribeiro Posted September 16, 2016 Author Share Posted September 16, 2016 root@ruir:/sbin# ls -la swconfig -rwxr-xr-x 1 root root 14036 Sep 14 2016 swconfig Link to comment Share on other sites More sharing options...
wildcat_paris Posted September 16, 2016 Share Posted September 16, 2016 @Rui check if you still have the old binary in /usr/local/bin/ whereis swconfig test it then overwrite the /sbin/swconfig so Zador has spare time to fix this problem 1 Link to comment Share on other sites More sharing options...
Rui Ribeiro Posted September 16, 2016 Author Share Posted September 16, 2016 @goldfich_paris Even I had checked earlier with find, I checked again after your post. I do not have it. Thanks. root@ruir:/sbin# whereis swconfig swconfig: /sbin/swconfig Link to comment Share on other sites More sharing options...
wildcat_paris Posted September 16, 2016 Share Posted September 16, 2016 ok, I uploaded my working binary, not a clean way but should be working http://guillaume.romagny.free.fr/swconfig.zip Link to comment Share on other sites More sharing options...
zador.blood.stained Posted September 16, 2016 Share Posted September 16, 2016 @goldfish_paris Please test this package (you may have to remove old first): https://dl.dropboxusercontent.com/u/5385968/swconfig_15.04-1_armhf.deb Link to comment Share on other sites More sharing options...
wildcat_paris Posted September 16, 2016 Share Posted September 16, 2016 @zador.blood.stain [gr@bpi:~] $ wget https://dl.dropboxusercontent.com/u/5385968/swconfig_15.04-1_armhf.deb --2016-09-16 21:13:43-- https://dl.dropboxusercontent.com/u/5385968/swconfig_15.04-1_armhf.deb Resolving dl.dropboxusercontent.com (dl.dropboxusercontent.com)... 45.58.70.5 Connecting to dl.dropboxusercontent.com (dl.dropboxusercontent.com)|45.58.70.5|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 7376 (7.2K) [application/x-debian-package] Saving to: ‘swconfig_15.04-1_armhf.deb’ 100%[==================================================================================================>] 7,376 --.-K/s in 0s 2016-09-16 21:13:45 (95.4 MB/s) - ‘swconfig_15.04-1_armhf.deb’ saved [7376/7376] You have new mail in /var/mail/gr [gr@bpi:~] $ ll /sbin/swconfig -rwxr-xr-x 1 root root 34868 Sep 16 21:01 /sbin/swconfig* [gr@bpi:~] $ sudo dpkg -i swconfig_15.04-1_armhf.deb (Reading database ... 181441 files and directories currently installed.) Preparing to unpack swconfig_15.04-1_armhf.deb ... Unpacking swconfig (15.04-1) over (15.04-1~armbian5.20+1) ... Setting up swconfig (15.04-1) ... [gr@bpi:~] $ ll /sbin/swconfig -rwxr-xr-x 1 root root 11444 Sep 16 21:10 /sbin/swconfig* [gr@bpi:~] $ /sbin/swconfig swconfig list swconfig dev <dev> [port <port>|vlan <vlan>] (help|set <key> <value>|get <key>|load <config>|show) [gr@bpi:~] 1 $ /sbin/swconfig list Found: switch0 - eth0 [gr@bpi:~] 1 $ /sbin/swconfig dev eth0 help switch0: eth0(BCM53125), ports: 9 (cpu @ 8), vlans: 4096 --switch Attribute 1 (int): enable_vlan ((null)) Attribute 2 (string): ports ((null)) Attribute 3 (int): reset_mib ((null)) Attribute 4 (int): enable_jumbo ((null)) Attribute 5 (int): allow_vid_4095 ((null)) Attribute 6 (unknown): apply ((null)) Attribute 7 (unknown): reset ((null)) --vlan Attribute 1 (ports): ports ((null)) --port Attribute 1 (string): mib ((null)) Attribute 2 (int): pvid ((null)) Attribute 3 (string): link ((null)) it may look the binary has not been linked properly edit: the following doesn't mean anything (sorry) [gr@bpi:~] $ nm /sbin/swconfig nm: /sbin/swconfig: no symbols [gr@bpi:~] $ nm /usr/local/bin/swconfig U abort@@GLIBC_2.4 0000ab40 t ack_wait_handler 0000a090 t add_attr 0000a050 t add_id 0000a450 t add_port_map 0000a564 t add_switch 0000bd90 t __alloc_socket U __assert_fail@@GLIBC_2.4 U atoi@@GLIBC_2.4 U bind@@GLIBC_2.4 000155e0 A __bss_end__ 000155e0 A _bss_end__ 000154e4 A __bss_start 000154e4 A __bss_start__ 000154f4 b cache 0001555c b cache_ops [...] edit2: I am using Ubuntu 14.04.05 the deb files sounds like it is Ubuntu 15.04 edit3: I looked at objdump -D -M intel /sbin/swconfig but it is ASM and I don't read ASM fluently Link to comment Share on other sites More sharing options...
Rui Ribeiro Posted September 16, 2016 Author Share Posted September 16, 2016 @goldfish, your binary restored my switch 1 Link to comment Share on other sites More sharing options...
wildcat_paris Posted September 16, 2016 Share Posted September 16, 2016 @Rui Cool, so we have a workaround solution for others Lamobo-R1 Armbian users 1 Link to comment Share on other sites More sharing options...
Rui Ribeiro Posted September 16, 2016 Author Share Posted September 16, 2016 @zador, last binary still problematic. swconfig dev eth0 help switch0: eth0(BCM53125), ports: 9 (cpu @ 8), vlans: 4096 --switch Attribute 1 (int): enable_vlan ((null)) Attribute 2 (string): ports ((null)) Attribute 3 (int): reset_mib ((null)) Attribute 4 (int): enable_jumbo ((null)) Attribute 5 (int): allow_vid_4095 ((null)) Attribute 6 (unknown): apply ((null)) Attribute 7 (unknown): reset ((null)) --vlan Attribute 1 (ports): ports ((null)) --port Attribute 1 (string): mib ((null)) Attribute 2 (int): pvid ((null)) Attribute 3 (string): link ((null)) Link to comment Share on other sites More sharing options...
zador.blood.stained Posted September 16, 2016 Share Posted September 16, 2016 @Rui Ribeiro Thanks, I hope this will be sorted out in next release, meanwhile we need to find and test working sources for swconfig and use precompiled one before that. 1 Link to comment Share on other sites More sharing options...
Rui Ribeiro Posted September 16, 2016 Author Share Posted September 16, 2016 @Rui Cool, so we have a workaround solution for others Lamobo-R1 Armbian users Yep, specially problematic for me as the R1 is my home router... Link to comment Share on other sites More sharing options...
Rui Ribeiro Posted September 16, 2016 Author Share Posted September 16, 2016 @Rui Ribeiro Thanks, I hope this will be sorted out in next release, meanwhile we need to find and test working sources for swconfig and use precompiled one before that. No problem, I am using the one from golfish. Link to comment Share on other sites More sharing options...
wildcat_paris Posted September 16, 2016 Share Posted September 16, 2016 @Mikhail if it can help the "old" swconfig has (with readelf) 0x00000001 (NEEDED) Shared library: [libdl.so.2] 0x00000001 (NEEDED) Shared library: [libc.so.6] the new one test1 0x00000001 (NEEDED) Shared library: [libnl-3.so.200] 0x00000001 (NEEDED) Shared library: [libnl-genl-3.so.200] 0x00000001 (NEEDED) Shared library: [libc.so.6] 0x00000001 (NEEDED) Shared library: [ld-linux-armhf.so.3] test2 0x00000001 (NEEDED) Shared library: [libnl-3.so.200] 0x00000001 (NEEDED) Shared library: [libnl-genl-3.so.200] 0x00000001 (NEEDED) Shared library: [libc.so.6] so as I am using Ubuntu 14.04 and the binary "looks like" for Ubuntu 15.04 Maybe there is a library issue. edit: I have the libnl-3 [gr@bpi:~] $ dpkg -l "libnl*" Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name Version Architecture Description +++-=============================-===================-===================-=============================================================== ii libnl-3-200:armhf 3.2.21-1ubuntu3 armhf library for dealing with netlink sockets ii libnl-3-dev 3.2.21-1ubuntu3 armhf development library and headers for libnl-3 un libnl-dev <none> <none> (no description available) ii libnl-genl-3-200:armhf 3.2.21-1ubuntu3 armhf library for dealing with netlink sockets - generic netlink ii libnl-genl-3-dev 3.2.21-1ubuntu3 armhf development library and headers for libnl-genl-3 ii libnl-route-3-200:armhf 3.2.21-1ubuntu3 armhf library for dealing with netlink sockets - route interface ii libnl1:armhf 1.1-8ubuntu1 armhf library for dealing with netlink sockets un libnl2-dev <none> <none> (no description available) un libnl3-dev <none> <none> (no description available) looking more closely I have libnl 3.2.21 it seems I would need libnl (network library) 3.2.24 maybe it is not related. Link to comment Share on other sites More sharing options...
Rui Ribeiro Posted September 17, 2016 Author Share Posted September 17, 2016 Old swconfig # ldd swconfig linux-vdso.so.1 (0xbee4d000) libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xb6f6b000) libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6e7a000) /lib/ld-linux-armhf.so.3 (0x7f601000) new swconfig # ldd swconfig linux-vdso.so.1 (0xbef88000) libnl-3.so.200 => /lib/arm-linux-gnueabihf/libnl-3.so.200 (0xb6f11000) libnl-genl-3.so.200 => /lib/arm-linux-gnueabihf/libnl-genl-3.so.200 (0xb6f04000) libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6e14000) libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xb6df1000) libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xb6d7d000) /lib/ld-linux-armhf.so.3 (0x7f628000) The pthread library seems out of place here. @goldfish the difference in size is because the new is stripped Even then, after stripping root@ruir:/sbin# ls -la swconfig -rwxr-xr-x 1 root root 23276 Sep 17 04:30 swconfig root@ruir:/sbin# ls -la swconfig.new -rwxr-xr-x 1 root root 11444 Sep 16 20:10 swconfig.new 1 Link to comment Share on other sites More sharing options...
zador.blood.stained Posted September 17, 2016 Share Posted September 17, 2016 @goldfish_paris @Rui Ribeiro Difference in size and used libraries suggests that the old binary was statically linked with libnl* and stuff, the newer one wasn't. 1 Link to comment Share on other sites More sharing options...
wildcat_paris Posted September 17, 2016 Share Posted September 17, 2016 (edited) @Mikhail while this one (generating swconfig*15.04*.deb) seems to be broken https://github.com/jekader/swconfig this one (also doing debian packaging "debuild -uc -us" and closer to openwrt) works ok https://github.com/xypron/swconfig edit: before using debuild -uc -us ./autogen.sh has to be launched (if not there is no binary) Edited September 17, 2016 by goldfish_paris note about building xypron/swconfig 1 Link to comment Share on other sites More sharing options...
wildcat_paris Posted September 17, 2016 Share Posted September 17, 2016 @Rui please can you check? http://guillaume.romagny.free.fr/swconfig_0.1.0_armhf.deb (or https://github.com/xypron/swconfig) Link to comment Share on other sites More sharing options...
dobriloff Posted September 18, 2016 Share Posted September 18, 2016 Guys, Problem comes from switch.h Build with https://raw.githubusercontent.com/openwrt-mirror/openwrt/master/target/linux/generic/files/include/uapi/linux/switch.h switch0: eth0(BCM53125), ports: 9 (cpu @ 8), vlans: 4096 --switch Attribute 1 (int): enable_vlan ((null)) Attribute 2 (string): ports ((null)) Attribute 3 (int): reset_mib ((null)) Attribute 4 (int): enable_jumbo ((null)) Attribute 5 (int): allow_vid_4095 ((null)) Attribute 6 (unknown): apply ((null)) Attribute 7 (unknown): reset ((null)) --vlan Attribute 1 (ports): ports ((null)) --port Attribute 1 (string): mib ((null)) Attribute 2 (int): pvid ((null)) Attribute 3 (string): link ((null)) Build with https://raw.githubusercontent.com/Bananian/openwrt/master/target/linux/generic/files/include/uapi/linux/switch.h switch0: eth0(BCM53125), ports: 9 (cpu @ 8), vlans: 4096 --switch Attribute 1 (int): enable_vlan (Enable VLAN mode) Attribute 2 (string): ports (Available Ports (as bitmask)) Attribute 3 (int): reset_mib (Reset MIB counters) Attribute 4 (int): enable_jumbo (Enable Jumbo Frames) Attribute 5 (int): allow_vid_4095 (Allow VID 4095) Attribute 6 (none): apply (Activate changes in the hardware) Attribute 7 (none): reset (Reset the switch) --vlan Attribute 1 (ports): ports (VLAN port mapping) --port Attribute 1 (string): mib (Get port's MIB counters) Attribute 2 (int): pvid (Primary VLAN ID) Attribute 3 (string): link (Get port link information) My solution apt-get purge -y swconfig wget -O /usr/include/linux/switch.h https://raw.githubusercontent.com/Bananian/openwrt/master/target/linux/generic/files/include/uapi/linux/switch.h git clone https://github.com/jekader/swconfig.git cd swconfig bash build.sh cd .. dpkg -i swconfig_15.04-1_armhf.deb rm -rf swconfig* PS: Nice people developers, please test your code that working on 100% before to release new versions Link to comment Share on other sites More sharing options...
wildcat_paris Posted September 18, 2016 Share Posted September 18, 2016 @dobriloff Guys, Problem comes from switch.h Build with https://raw.githubusercontent.com/openwrt-mirror/openwrt/master/target/linux/generic/files/include/uapi/linux/switch.h Build with https://raw.githubusercontent.com/Bananian/openwrt/master/target/linux/generic/files/include/uapi/linux/switch.h PS: Nice people developers, please test your code that working on 100% before to release new versions the Bananian switch.h has the same xypron/swconfig switch.h but looking at the diff of the 2 files (openwrt-mirror vs. Bananian), I am surprised the compilation can even work, there are many more enum-ed attributes. I am thinking of a conspiracy of Bananian over Lamobo-R1 users Link to comment Share on other sites More sharing options...
zador.blood.stained Posted September 18, 2016 Share Posted September 18, 2016 PS: Nice people developers, please test your code that working on 100% before to release new versions Except that This is not "our code", this is wrong configuration for someone else's code This is not "core functionality" and can easily be fixed by replacing a single file We don't have all the boards that are listed on download page, some boards are just assumed to work since they are similar to others Even if we wanted to extensively test all the images, it would probably take several weeks and a box of microSD cards to do it 2 Link to comment Share on other sites More sharing options...
tkaiser Posted September 18, 2016 Share Posted September 18, 2016 This is not "core functionality" This is not even 'known to work' functionality: http://linux-sunxi.org/Lamobo_R1#Security_Implications (trying to use a dumb switch for routing/security purposes is just wrong) Link to comment Share on other sites More sharing options...
Rui Ribeiro Posted September 18, 2016 Author Share Posted September 18, 2016 @Rui please can you check? http://guillaume.romagny.free.fr/swconfig_0.1.0_armhf.deb (or https://github.com/xypron/swconfig) It works. Link to comment Share on other sites More sharing options...
