Positions
Part time technical support
Position: Technical supportNumber of places: 12Applicants: 16 -
Single board computer maintainer
Position: Board maintainerNumber of places: 64Applicants: 76 -
Code reviewer
Position: Framework maintainerNumber of places: UnlimitedApplicants: 11 -
Test Automation Engineer
Position: Software integration test engineerNumber of places: 16Applicants: 10 -
Build framework maintainer
Position: Framework maintainerNumber of places: 16Applicants: 6
Chat | Social Media
#armbian at
irc.libera.chat or irc.oftc.net
Matrix or Discord
Mastodon | 𝕏 -
Popular Now
Activity Stream
1
Has anyone managed to get armbian to work on the HK1 Rbox K8s H618?
@Gwainer If you haven't bought a TV box yet, stay where you are. Direct your resources to supporting companies that keep open source running. Here is a list of where you should spend your resources. https://armbian.com/partners -
9
Radxa Rock 5B+ - Fan not working
this is my [fix plan](https://github.com/icecreamzhao/rock5b-plus-fan-fix) -
116
Radxa Cubie A7A/A7Z - Allwinner a733
@humanus I thought Nick was referring to version 6.6, but I must have misunderstood. Since I knew 6.18 was still in development, I assumed he meant 6.6. Turns out he was actually talking about 6.18. -
7
@ebin-dev good idea, I can try that. For the moment I seem to have a stable system running 25.11.2 with the 6.12.58 kernel and the l2-cache and op1-opp patches loaded as kernel overlays. My use case for the Helios64 is as a NAS with OMV8 and ZFS. Who is the maintainer of this board now ? I'm happy to test images on my hardware and it would be good if the latest builds worked out of the gate without having to patch them. -
1
I'm planning on buying said Tv box in order to make it as a klipper host for a 3d printer since pi alternatives are too expensive nowadays.
Member Statistics
