KhanhDTP
  1. @chaitan3 It depends on the games; I have to try around to find what is best. I usually try 1.7.3, 1.10.3, 1.6.1 then 2.x versions.
  2. @Alex Ling I haven't tried mainline kernel 7.x so I can't tell. Can you check the GPU clock is capped at 850 Mhz bug is fixed?
  3. @Alex Ling yeah, I have noticed it too. With Mesa (PanVk) recent updates, DX9 games can be played with Dxvk without dgVoodoo2 wrapper.
  4. I was able to run Steam games with GPU accelerated ofc. But since my Opi5 only has 8Gb, I mainly run non-Steam games. I can see your SBC has 32Gb, so you are good. I assume your game is 64-bit DX11. Change the Steam Play compatible layer to "GE-proton". Download Dxvk-stripped here: https://github.com/khanh-it/dxvk/releases/tag/releases Copy x64/d3d11.dll, x64/dxgi.dll to the <<game>>.exe folder. Then run the game with a command like so:
  5. I can see it has already set: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum Mali-G610 MC4
  6. @xiboliyadongtu So, you were able to play the game with Dxvk (or Zink) now? How is the performance I wonder?
  7. @xiboliyadongtu Then copy x64/d3d11.dll, x64/dxgi.dll files to the same folder as blackdesert64.exe and try to run it without the launcher.
  8. @xiboliyadongtu Can this game be started without a launcher? Is there an executable file besides BlackDesertLauncher.exe (like BlackDesert.exe)? The BlackDesertLauncher.exe is definitely a 32-bit file. So, you might need to run it with GE-Proton10-32 in WoW64 mode. Delete the created GE-Proton10-32's prefix to make sure. Then start it again with envs If everything is right, you will see the Dxvk output log with something like below:
  9. @xiboliyadongtu as your ss, the launcher is 32-bits. So, can you copy x32/d3d11.dll, x32/dxgi.dll files to the game folder and try again?
  10. @xiboliyadongtu Your log seems normal. The problem is that the game is ~100Gb. I don't have that much free disk space to try. It looks like the game is running, but it's just not using the proper GPU renderer. By default, it will use the WineD3D renderer on top of OpenGL (panfrost). 1) You can try Zink by setting those vars: 2) Try Dxvk-stripped: Download Dxvk-stripped here: https://github.com/khanh-it/dxvk/releases/download/releases/dxvk-v1.6.1-stripped-msvc-output.zip and copy the files x64/d3d11.dll, x64/dxgi.dll to the game's folder (/media/xiboliyadongtu/固态/BlackDesert/) setting those vars: Start the game, and see how it goes?!
  11. Armbian 26.2.1 Noble XFCE (BSP Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + Box64 arm64 v0.4.1 4474ac0f1 (https://ryanfortner.github.io/box64-debs/) + ge-proton10-32 (https://github.com/GloriousEggroll/proton-ge-custom/releases/tag/GE-Proton10-32) + DXVK-stripped v1.7.3 ~40fps@720p (mixed settings) Metal Gear Solid V - The Phantom Pain - v.1.01 (denuvoless version) (Tpp_steam_mst_en_0803_2200)
  12. @xiboliyadongtu Did you try Hangover (which is Fex-emu)? https://github.com/AndreRH/hangover I saw someone had a problem with a similar online game with Box64 before. https://github.com/ptitSeb/box64/issues/3073#issuecomment-3689810679
  13. Armbian 25.11.2 Noble XFCE (BSP Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + Box64 arm64 v0.4.1 ed9827920 (https://ryanfortner.github.io/box64-debs/) + wine-11.3-staging-tkg-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/11.3) + vkd3d-1.19 (wine's built-in) ~60fps@1024x576 (medium settings) Hades 2
  14. GTA V OG on Orange Pi 5+ 1080p Low DXVK / PanVK / Debian13
