mydeardiary
  1. Hi, I would like this m7 as replacement for my low-cost build of Armbian rk322x-box, currently serving a self hosted webspace. Looking forward to have my id as the giveaway winner.
  2. Greetings, Currently running a low cost rk322x-box as self hosted webspace and another s905x-box as low budget network attached storage, serving files from a usb-attached hdd over smb and sftp. While both systems are operational, I would like to have this mini itx radxa to taste the power of rk3588 which is one of top performing cpu on the sbc world. Will be performing more transcoding with more cpu power.
  3. Update: glmark2-es2-wayland scores for lima mali400 gpu running on sway headless session is around 115. ======================================================= glmark2 2023.01 ======================================================= OpenGL Information GL_VENDOR: lima GL_RENDERER: Mali400 GL_VERSION: OpenGL ES 2.0 Mesa 22.3.6 Surface Config: buf=32 r=8 g=8 b=8 a=8 depth=24 stencil=0 samples=0 Surface Size: 800x600 windowed ======================================================= [build] use-vbo=false: FPS: 144 FrameTime: 6.952 ms [build] use-vbo=true: FPS: 185 FrameTime: 5.430 ms [texture] texture-filter=nearest: FPS: 212 FrameTime: 4.737 ms [texture] texture-filter=linear: FPS: 207 FrameTime: 4.838 ms [texture] texture-filter=mipmap: FPS: 226 FrameTime: 4.435 ms [shading] shading=gouraud: FPS: 123 FrameTime: 8.195 ms [shading] shading=blinn-phong-inf: FPS: 109 FrameTime: 9.250 ms [shading] shading=phong: FPS: 84 FrameTime: 11.953 ms [shading] shading=cel: FPS: 60 FrameTime: 16.719 ms [bump] bump-render=high-poly: FPS: 49 FrameTime: 20.620 ms [bump] bump-render=normals: FPS: 202 FrameTime: 4.973 ms [bump] bump-render=height: FPS: 171 FrameTime: 5.853 ms [effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 56 FrameTime: 18.176 ms [effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 22 FrameTime: 46.372 ms [pulsar] light=false:quads=5:texture=false: FPS: 281 FrameTime: 3.561 ms [desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 29 FrameTime: 34.857 ms [desktop] effect=shadow:windows=4: FPS: 92 FrameTime: 10.950 ms [buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 40 FrameTime: 25.293 ms [buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 40 FrameTime: 25.563 ms [buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 52 FrameTime: 19.344 ms [ideas] speed=duration: FPS: 64 FrameTime: 15.756 ms [jellyfish] <default>: FPS: 62 FrameTime: 16.169 ms [terrain] <default>: Unsupported [shadow] <default>: FPS: 57 FrameTime: 17.550 ms [refract] <default>: FPS: 10 FrameTime: 100.697 ms [conditionals] fragment-steps=0:vertex-steps=0: FPS: 219 FrameTime: 4.579 ms [conditionals] fragment-steps=5:vertex-steps=0: FPS: 117 FrameTime: 8.591 ms [conditionals] fragment-steps=0:vertex-steps=5: FPS: 221 FrameTime: 4.540 ms [function] fragment-complexity=low:fragment-steps=5: FPS: 159 FrameTime: 6.322 ms [function] fragment-complexity=medium:fragment-steps=5: FPS: 77 FrameTime: 13.067 ms [loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 153 FrameTime: 6.570 ms [loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 150 FrameTime: 6.690 ms [loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 57 FrameTime: 17.550 ms ======================================================= glmark2 Score: 115 ======================================================= The cpu temperature hits 75 degree during glmark2-es2-wayland test run.
  4. Update: this box is now running Linux 6.6.17-current-rockchip Dtb applied: overlays=emmc led-conf7 The cpu speed is now capped at 1 GHz with better stability and hdmi output works (via usb to hdmi viewed on another laptop using ffplay). Excelent. Installed sway and lima gpu is being utilized. But before I can access the lima gpu, I have to add my login to render group. `sudo usermod -a -G render $LOGNAME` Well done!
