royk
  1. @JohnU Which kernel version of the desktop installation and which with the minimal?
  2. Post the UART log.
  3. Did you also install the dtb that belongs to that kernel version? You could check if the dtbo is compatible with your dtb with: fdtoverlay -v -i /boot/dtb/current.dtb -o /tmp/test.dtb your-overlay.dtbo It would be better to compile the dts with armbian-add-overlay your-overlay.dts so it will automatically install it to /boot/overlay-user and added to your armbianEnv.txt. In this way it also won't get overwritten when you update the dtb. And of course like Werner said, check the debug serial console, you'll see much more detailed information. And check if the symlinks are correctly linked to your kernel version. ls -l /boot
  4. @Werner I agree that it's more convenient for everyone, but it took me some time to find out how and testing it in an image. https://github.com/armbian/build/pull/8707/commits
  5. I had some difficulties to make my sata disk work and found out that the regulator had to be switched on. So here a dtbo and source to make it hopefully a bit easier for some others. Easiest way to install is "sudo armbian-add-overlay orangepi-5-sata.dts" orangepi-5-sata.dtbo orangepi-5-sata.dts
  6. You could try to write the bootloader again to the SD-card, it seems like it's mixed up. Old with new. not sure if the names are exactly like this but something like this: cd /usr/lib/linux-u-boot-vendor-orangepi-5 sudo dd if=u-boot-rockchip.bin of=/dev/sdx seek=64 conv=fsync sudo sync Or is ls -l /boot to see if the symlinks are correct. The correct dtb in armbianEnv.txt? The correct dtb for your current kernel version?
  7. Maybe try another power adapter Or add to /boot/armbiEnv.txt extraargs=pcie_aspm=off nvme_core.default_ps_max_latency_us=0 pci=pcie_bus_safe Otherwise you could try an image of Radxa first, if that works then it might be an issue with the dtb
  8. It's enabled by default. I believe that you have the wires swapped. There's a topic here about it where I also added a overlay to adjust what speed at which temperature. I'm not sure if the overlay is still compatible, but since you've already found the source you can change it accordingly.
  9. @Chris C In case going's suggestion doesn't help, the kernel should be compatible with the Rock 5b. I don't think that you need to install the dtb if you're already running Armbian with vendor kernel 6.1.x. So just install with "sudo apt install ./linux-image*.deb and the headers if you need them to compile drivers that you need for testing. To be sure if the install went correct you should look if the symlinks are all to the correct kernel. "ls -l /boot" otherwise "sudo ln -sf correct-vmlinuz Image" and so on But adding a log is always helpful indeed. Send it after the nvme stopped working.
  10. @Chris C In the past there was a commit to fix sata issues with the Rock 5a, but this gave problems for nvme with Orange Pi. After that I also read some problems with nvme and the Rock 5B although I don't know if that was related. https://forum.armbian.com/topic/46601-2484-latest-apt-upgrade-breaks-multiple-things-including-the-gnome-desktop/?do=findComment&comment=204829 This is a bit older kernel with RT patch where I reverted that commit. If that works you could compile a "normal" kernel with that commit reverted. https://drive.google.com/drive/folders/1r76sUsfG_F8pq0pkzzPgEyzqdRG6fGcz?usp=drive_link
  11. You could try to add one of these in armbianEnv.txt extraargs=pci=pcie_gen2 extraargs=nvme_core.io_timeout=4294967295 extraargs=nvme_core.default_ps_max_latency_us=0
  12. Try to upload the old and new driver to an AI with you overlay included. Here it gives some suggestions for what you can try. The power sequence seems to be changed with the new driver and it might be too fast for your display. It suggests to put some parameters in the overlay to delay some parts, with higher chance with the first 3: Under "dsi0_panel: panel@0 {" prepare-delay-ms = <120>; reset-delay-ms = <50>; init-delay-ms = <150>; enable-delay-ms = <50>; disable-delay-ms = <50>; unprepare-delay-ms = <120>;
  13. What does the following command show? sudo fdtoverlay -v -i /sys/firmware/fdt -o /dev/null /path/to/your_overlay.dtbo panel-simple-dsi ... Expected bpc in {6,8} but got: 0 So possibly the default with the older kernel was by accident correct and now you should define it. And it seems that you use an overlay meant for the 5a on a 5c?
  14. @laibsch It seems that if you set the pixel clock or refresh rate too high that you can shorten its lifespan. But when you use extreme values and the display doesn't have any protection in rare cases you can even damage it. A bigger chance is driver instability or a distorted display.
  15. There is no overlay for that, but at your own risk you can edit the current overlay with some help of AI. But it will need the exact data of the data sheet. Just upload the data sheet, overlay and relevant dts/dtsi files (some of the includes and includes of the includes of rk3588/rk3588s) and ask to make an overlay for this display for Armbian.
