  1. Tap the 3-dot menu (โ‹ฎ) in the top-right corner of the browser.
Kuba
  1. Thank you @Igor It works right only at 60Hz, tried 100Hz ,80Hz - same result as 120Hz Memory clock: kuba@uefi-arm64-dt:~$ sudo cat /sys/kernel/debug/clk/emc/clk_rate 204000000 Regards Kuba PS. Once again thanks for help. I am ready to test anything in future. BTW. Is there any set of (unit)tests one should use when testing new Armbian builds for example? What I already tested is USB/BT, USB/Z-wave, WiFi, ETH, DP (as above), HDMI (with manual config, ...) - all work from start. PWM works as well (tested under stress test). From the other hand serial console on pins 6/8/10 does not wake up (even I added extra support into kernel (7.3), extra grub config,, tested loops with pins 8/10 connected together, .... - guess it's a device tree config thing) Main purpose of my production device is to host about 20 containers covering different home automation processes - that also works fantastically well from the very beginning (docker installed by apt as standard), migration to Armbian went without issues.
  2. Hi @Igor It works much better! - monitor switches to 120MHz. It is stable if no changes on the screen but if I start to print a lot ... - it starts to be "cryptographic monitor" (screens attached) debug_modes_fix.log debug_dmesg_fix.log debug_armbian-debug_fix.log IMG_4380.HEIC IMG_4381.HEIC
  3. Hi @Igor If you are willing to help, I am more than happy to test as many times as needed . All the data included Cheers Kuba debug_uname.log debug_modes.log debug_dpkg.log debug_dmesg.log debug_armbian-debug.log
  4. Hi @Igor Downloaded from % cat .git/HEAD ref: refs/heads/tegra-sor-dp-mode-valid Unfortunately same result https://paste.armbian.com/oyuboketug
  5. Compiling . I will test tomorrow and share results.
  6. Thanks @Igor ! Here it is 1. video option removed / jetson nano restarted 2. https://paste.armbian.com/jabemeteno 3,4 attached (+ example how DP screen looks like, HDMI shows just black) Kuba HDMI_DP_debug.txtIMG_4377.HEIC
  7. Hi all First of all big thank you to everyone who worked on adding nvidia Jetson nano back to list of supported boards. I was able to do upgrade to Ubuntu 24.04 by myself but still on old kernel. Now, after recent changes to Armbian - the little board received new live!! Thanks! Kuba Hint: Somehow my LG monitor required extra grub config before DisplayPort & HDMI ports started to work properly (frequency was an issue). If anyone faced similar problems - here is what worked for me. GRUB_CMDLINE_LINUX="video=DP-1:2560x1440@60 video=HDMI-A-1:1920x1080@60e"
  8. Kuba replied to balbes150's topic in Other families
    can this be a problem? [๐Ÿณ|๐Ÿšธ] Kernel DTB-only for development [ Copying preprocessed version of nvidia/tegra210-p3450-0000.dtb ] '/armbian/cache/sources/linux-kernel-worktree/6.1__arm64__arm64/arch/arm64/boot/dts/nvidia/.tegra210-p3450-0000.dtb.dts.tmp' -> '/armbian/output/nvidia-tegra210-p3450-0000.dtb--6.1-legacy.preprocessed.dts' arch/arm64/boot/dts/nvidia/tegra210.dtsi:1874.15-1885.4: Warning (unique_unit_address): /usb@7d000000: duplicate unit-address (also used in node /usb-phy@7d000000) arch/arm64/boot/dts/nvidia/tegra210.dtsi:1912.15-1923.4: Warning (unique_unit_address): /usb@7d004000: duplicate unit-address (also used in node /usb-phy@7d004000) arch/arm64/boot/dts/nvidia/tegra210.dtsi:410.37-421.4: Warning (interrupt_provider): /interrupt-controller@50041000: Missing #address-cells in interrupt provider arch/arm64/boot/dts/nvidia/tegra210.dtsi:442.37-453.4: Warning (interrupt_provider): /interrupt-controller@60004000: Missing #address-cells in interrupt provider arch/arm64/boot/dts/nvidia/tegra210.dtsi:488.22-503.4: Warning (interrupt_provider): /gpio@6000d000: Missing #address-cells in interrupt provider arch/arm64/boot/dts/nvidia/tegra210-p3450-0000.dts:174.17-416.5: Warning (interrupt_provider): /i2c@7000d000/pmic@3c: Missing #address-cells in interrupt provider arch/arm64/boot/dts/nvidia/tegra210.dtsi:841.26-948.4: Warning (interrupt_provider): /pmc@7000e400: Missing #address-cells in interrupt provider also defined at arch/arm64/boot/dts/nvidia/tegra210-p3450-0000.dts:419.15-428.4 arch/arm64/boot/dts/nvidia/tegra210.dtsi:1420.39-1430.5: Warning (interrupt_provider): /aconnect@702c0000/interrupt-controller@702f9000: Missing #address-cells in interrupt provider also defined at arch/arm64/boot/dts/nvidia/tegra210-p3450-0000.dts:618.33-620.5 [๐Ÿณ|๐Ÿšธ] Kernel DTB-only for development [ Preprocessed FDT dest: /armbian/output/nvidia-tegra210-p3450-0000.dtb--6.1-legacy.preprocessed.dts ] [๐Ÿณ|๐Ÿšธ] Kernel DTB-only for development [ Preprocessed FDT normalized: /armbian/output/nvidia-tegra210-p3450-0000.dtb--6.1-legacy.preprocessed.normalized.dts ] [๐Ÿณ|๐Ÿšธ] Kernel DTB-only for development [ Preprocessed FDT normalized, no phandles: /armbian/output/nvidia-tegra210-p3450-0000.dtb--6.1-legacy.preprocessed.normalized.nophandles.dts ]
  9. Kuba replied to balbes150's topic in Other families
    Hi friends Anyone being able to run any of the newest Armbian builds on Jetson Nano + HDMI and/or DisplayPort? PS. I have updated bootloader, system starts itself. It's simply super frustrating that the board lost support even it's still fine to play with. Happy to test any ideas - I have 3 jetson nano devices (one running docker + home assistant and few services organizing IoT home stuff on custom build ubuntu 22), 2 ready for any tests, quite power-full laptop so I can do builds in minutes and some knowledge. Need someone to team-up with so maybe we can finally get the Armbian's build fully functional?
  2. Tap Permissions โ†’ Notifications.
