dma
  1. Also Simple Orange Pi 5 plus ubuntu image from Orange pi web site solved my limited resolution issues: Orangepi5plus_1.0.8_ubuntu_jammy_desktop_xfce_linux6.1.43.7z Since installing it - 1440p 60 fps youtube video is runnig smoothly for long time with only 5% dropped frames. No freezing or crashing. Max resolution available: 3440x1400.
  2. Last Joshua image just did it for me Ubuntu 24.04 LTS Desktop with Linux 6.1 Topic closed
  3. From my memory - there are not only one video on tube with 4k on that board. Some of them are already 1y old...
  4. Probably will be promptly fixed by installing older image or from some other project. But OK, appeal noted - I'll check later how I can help the project
  5. Calm down, the question was on resolution, not on my imagined greeding, wrong decisions, experiences and expectations. Know nothing about me, my goals, budget, exlerience , etc... Question was to community, not for you. You kindly would have save time/resources you complain not have too much and just not to produce your post above
  6. Hi all , Just installed last supported version: Armbian 24.8.1 Noble Gnome, MESA / VPU, Kernel: 6.1.75, Size: 1.5 GB, Release date: Aug 26, 2024 I have 2 dell monitors : u2515h ultrasharp 1440p, and more modern P3424WE with 3440x1440 max resolution. With both - armbian max resolution in display settings is always 1920x1080. My previous experience here was with radxa zero D1 and 1440p was working here smoothly out of box on different armbian images. I also tried Ubuntu 22.04 (Jammy)KDE NeonMESA / VPU https://dl.armbian.com/orangepi5-plus/Jammy_current_kde-neon-kisak with same results: no resolution higher then 1080p Rdp session to that installations normally propose 2560 and 3440x1440 resolutions available and usable. So I suppose it is some config but not driver/hardware issue. Rdp installed via: sudo apt install xrdp xorgxrd sudo systemctl enable xrdp The WEB is exploding with tons of guides with dozens of approaches, of course first tried not working... Can somebody save me from that many hours try and fail circus and guide me on short way to troubleshoot resolution on that new armbian images?
  7. Wake-on: d means it disabled you shoud change for g and test again
  8. Hi all Cannot make usable wol on my orange pi 5 plus. Os: Armbian 24.5.1 Bookworm with Linux 6.1.75-vendor-rk35xx WOL tested in magic or unicast settings or all flags enabled (phy, unicast, multicast, broadcast, arp, magic) Test sending wol packets with running tcpdump -i enP3p49s0 '(udp and port 7) or (udp and port 9)' show that orange pi successfully receive wol packets on speeds 1000 or even 10 mbps while powered on. But after sending orange pi to suspend or power off I cannot bring it online via WOL. So I suppose network component outside orange pi is ok and it is something wrong with orange pi. Any ideas?
  9. Ad blocker + home file server/nas based on nvme + torrent server + security cam solution based on ispy or motioneye
