Banana Pi BPI-M2-Ultra with armbian stops load after "Scanning for Btrfs filesystems"
If the boot log (serial console or dmesg) shows sunxi-mmc 1c11000.mmc: data error, sending stop command before the hang, it may be the eMMC clock rather than Btrfs: the Btrfs scan in the initrd reads all block devices, including the eMMC, and on this board the eMMC can hang on these errors, which would stop the boot right there. On my M2U, limiting the eMMC clock to 40 MHz with a small device-tree overlay fixed it (full 8-bit bus, ~61 MB/s read). Details and the overlay: https://forum.armbian.com/topic/28215-banana-pi-m2-ultra-boot-freezing-trying-to-scan-the-emmc/?do=findComment&comment=244287
Banana Pi M2 Ultra boot freezing trying to scan the EMMC
Hi all, another data point and an alternative to the 1-bit overlay. I had exactly this error on my M2U (sunxi-mmc 1c11000.mmc: data error, sending stop command / send stop command failed, then the eMMC host hangs). I run LibreELEC (kernels 6.6 and 6.16), but the device tree is mainline, the same as Armbian's. In my case the problem is the clock, not the bus width: the stock dts has no max-frequency on the eMMC node, so it runs 8-bit DDR52 at 50 MHz. Capping it at 40 MHz (the driver ends up at 37.5 MHz) fixed it with the full 8-bit DDR bus: 50 MHz: fails within 0.5 s, every time 37.5 MHz: 0 errors in a 33 min soak (6× full read + write/sha256 verify across the whole eMMC), and the system has run from eMMC since 25 MHz: also passes Speeds at 37.5 MHz: read ~61 MB/s, write ~25 MB/s. A 1-bit bus would be a fraction of that. eMMC: Samsung 8WPD3R (eMMC 5.0), close to the 8GTF4R in goosnarrggh's log. You can test this live without changing anything permanently (as root, booted from SD): mount -t debugfs none /sys/kernel/debug cat /sys/kernel/debug/mmc*/ios # find the host showing "bus width: 3 (8 bits)" echo 40000000 > /sys/kernel/debug/mmcN/clock dd if=/dev/mmcblkX of=/dev/null bs=4M # watch dmesg (Note: if 50 MHz already hung the controller, you need a cold power-off first. A reboot doesn't reset it.) Overlay (the same overlay, without the compatible line, runs on my board under LibreELEC, loaded by U-Boot; this version is checked with fdtoverlay but not tested on Armbian itself, so feedback welcome). For Armbian it should go in as a user overlay with armbian-add-overlay sun8i-r40-bananapi-m2-ultra-emmc-40mhz.dts: /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-r40"; fragment@0 { target-path = "/soc/mmc@1c11000"; __overlay__ { max-frequency = <40000000>; }; }; }; Remove the 1-bit overlay when you try this one. If 40 MHz isn't stable on your board, try 25000000. That fits 赵凌's observation that 4-bit works where 8-bit doesn't: both lower the load on the bus, but the clock cap keeps 8-bit speed.
msubasic
