Lion Wang
1 Follower
6855 profile views
  1. SpacemiT K1 8 core RISC-V chip (Banana Pi BPI-F3) RISC-V IME set Specification public on github https://github.com/space-mit/riscv-ime-extension-spec
  2. the Banana Pi BPI-M7 review https://taoofmac.com/space/blog/2024/06/16/1800
  3. Banana Pi BPI-M7 with Rockchip RK3588, 8/16/32G,RAM 64/128G eMMC,wifi6 support . 2x2.5G port ,1xHDMIout ,2x USB3.0,2xTYPE-C,2x MIPI CSI interface and 1x MIPI DSI interface, 1x M.2 KEY M interface,40 PIN GPIO ,Mini size just 92x62mm. Hardware interface: online documents: https://docs.banana-pi.org/en/BPI-M7/BananaPi_BPI-M7
  4. wiki page: https://docs.banana-pi.org/en/BPI-M5/BananaPi_BPI-M5_Pro
  5. Banana Pi BPI-M5 Pro adopts the second-generation 8nm high-performance AIOT platform Rockchip RK3576, with a 6 TOPS computing power NPU and support for up to 32GB of large memory. It supports 8K video encoding and decoding, offers rich interfaces including dual gigabit Ethernet ports, WiFi 6 & BT5, and various video outputs. Compatible with multiple operating systems, it is suitable for ARM-based PCs, edge computing devices, personal mobile internet devices, and other digital multimedia applications. Key Parameter SoC: Rockchip RK3576 CPU: Integrated with four Cortex-A72 cores @ 2.2GHz and four Cortex-A53 cores @ 1.8GHz, along with a separate NEON co-processor. GPU: ARM Mali G52 MC3 GPU NPU: Up to 6 TOPs computing power (INT8), supports INT4/INT8/INT16 mixed operations. VPU/Encoding & Decoding: Hardware Decoding: Supports H.264, H.265, VP9, AV1, and AVS2 up to 8K@30fps or 4K@120fps. Hardware Encoding: Supports H.264 and H.265 up to 4K@60fps, high-quality JPEG encoder/decoder supports up to 4K@60fps. RAM: 8/16GB 32-bit LPDDR4x, default is 16GB. RK3576 supports a maximum of 16GB. Flash: 32/128GB eMMC, default is 128GB eMMC. Operating Voltage: Wide input voltage range, from 4.5V to 23V (voltage error ±5%). Operating Temperature: 0°C to 80°C Operating Systems: Official Rockchip Support: Android 14, Debian 11, Buildroot Third-party Support: Armbian PCB: 8-layer PCB board design Weight: 43g Dimensions: 92mm × 62mm
  6. BananaPi BPI-CM4 new design with Amlogic A311D Quad core ARM Cortex-A73 and dual core ARM Cortex-A53 CPU ,ARM G52 MP4(6EE) GPU,NPU for AI at 5.0 TOPS, support Camera and MIPI-CSI interface ,HDMI output,2 Gigabit port . 4G RAM and 16 GB eMMC flash. BPI-CM4 hardware interface: BPI-CM4 IO baord interface
