sovking
2795 profile views
  1. Ok. So I should not try to upgrade this package. Then, if I wish, to keep the system updated, I could upgrade from bullseye to Debian 12 (Bookworm), probably following the procedure illustrated here ? The kernel is Linux 6.6.31-current-sunxi, while the specific armbian packages installed are: armbian-bsp-cli-orangepipc/now 22.02.1 armhf [installed,upgradable to: 24.5.1] armbian-config/bullseye,bullseye,now 24.5.5 all [installed] armbian-firmware/bullseye,bullseye,now 24.5.6 all [installed] armbian-zsh/bullseye,bullseye,now 24.5.5 all [installed] hostapd/now 3:2.10-6~armbian22.02.3+1 armhf [installed,local] htop/now 3.1.0-0~armbian20.08.2+1 armhf [installed,local] This procedure could work to keep the system upgraded with armbian distribution ? Thanks!
  2. I was updating packages on a host running on board "Orange PI PC", running Armbian bullseye version 22.02.1. There is only one package left: The following packages have been kept back: armbian-bsp-cli-orangepipc and if I try to run: sudo apt install armbian-bsp-cli-orangepipc I get: The following packages have unmet dependencies: armbian-bsp-cli-orangepipc-current : Depends: base-files (>= 24.5.1) but 11.1+deb11u10 is to be installed E: Unable to correct problems, you have held broken packages. If I look at my installation of base-files I see that that's is right. How I can fix this ?
