Murat Demirtas
Profile Information
  • Gender
    Male
  • Location
    istanbul
Contact Methods
  • Github
    https://github.com/muratdemirtas
1354 profile views
  1. i modified the dts file. There was a boot error when use both vopl and vopb and when not use both in linux kernel. the example boot sequence mipi video i will upload who interest. There is a flicker when load kernel from uboot that i am on the solve. rk3399-orangepi.dts
  2. thank you very much guys, both two method is works. i successfully patched.
  3. Should i edit the python scripts that creates that patches? or is there another way with build system?
  4. In latest build system, the board configuration file https://github.com/armbian/build/blob/main/config/boards/orangepi4-lts.conf using fdt file as BOOTCONFIG="orangepi-rk3399_defconfig" BOOT_FDT_FILE="rockchip/rk3399-orangepi-4-lts.dtb" how can i patch that file?. Because this file is not existing in mainline kernel, and creating with patches. interesting.
  5. Hello, thank you for reply. I'm using build system v24.11 and latest, kernel version v6.6 and v6.12. Created fresh installation and trying to create patches with command ./compile.sh kernel-patch BOARD=orangepi4-lts BRANCH=current KERNEL_GIT=shallow ARTIFACT_IGNORE_CACHE=yes and that file exist in /home/oem/Desktop/ananki/build/cache/sources/linux-kernel-worktree/6.12__rockchip64__arm64/arch/arm64/boot/dts/rockchip You are right, because the series of patch files in build system creates this file. I patched non existent file but created with a older patches .
  6. Hello, previously, after creating a patch file, (v24.11) I used to save it in the userpatches directory as zzzz_xxxx_whatever.patch to ensure it was processed at the bottom of the current patch list. But now, it seems that this no longer works, and therefore, I cannot apply the patch.zzzz_panel_mipi_dsi.patch thank you. here is the log file: https://paste.armbian.com/horamafuru Edit: tested with(trunk.239) latest armbian build( https://github.com/armbian/build/tree/v25.5.0-trunk.239 with zzz-patch-test.patch here is the log file: https://paste.armbian.eu/joyalusado zzzz_panel_mipi_dsi.patch
  7. Hello, friends... The current MIPI DSI driver provided by Rockchip Inc. in older U-Boot versions (v2023 and earlier) is not compatible with U-Boot’s uclass subsystems.(a waste of time if you want to develop). I have done extensive research and made modifications to several files to make it work with the latest U-Boot versions. I have tested it with U-Boot 2023.10, 2024.10 and v2025.rc3 on orange pi 4 lts, and it works perfectly. I'm attaching the necessary files for those who need them. This u-boot driver is nearly identical to Rockchip's Linux kernel driver, uses same driver file but there some limitations because of u-boot system, but it correctly displays the splash image when vidconsole0 probed by u-boot.. Additionally, i want to say that, in linux kernel side, the same dw-rockchip-dsi driver in latest armbian distribitions works with from kernels 5.18 to latest kernel v6.6 and v.6.12. I tested it. Tested with custom 400x1200 60hz 4 lane standart mipi dsi panel from chinese panel manufacturer. I attached all modified files as attachment. Good lucks. dm tree command output from u-boot is reset 1 [ + ] rockchip_reset | `-- reset syscon 27 [ + ] rk3399_syscon |-- syscon@ff770000 nop 3 [ + ] rockchip_iodomain | `-- io-domains video 0 [ + ] rk3399_vop |-- vop@ff8f0000 vidconsole 0 [ + ] vidconsole0 | `-- vop@ff8f0000.vidconsole0 video 1 [ + ] rk3399_vop |-- vop@ff900000 vidconsole 1 [ + ] vidconsole0 | `-- vop@ff900000.vidconsole0 video_brid 0 [ + ] dw-mipi-dsi-rockchip |-- dsi@ff960000 dsi_host 0 [ + ] dw_mipi_dsi | |-- dsihost panel 0 [ + ] rm68200_panel | `-- panel@0 pinctrl 0 [ + ] rockchip_rk3399_pinc |-- pinctrl U-Boot 2024.10-armbian-2024.10-Sf919-Pbfb2-H3d34-Vade7-Bb703-R448a-dirty (Mar 03 2025 - 06:16:04 +0300) SoC: Rockchip rk3399 Reset cause: RST Model: Orange Pi 4 LTS Board DRAM: 4 GiB (effective 3.9 GiB) PMIC: RK808 Core: 285 devices, 32 uclasses, devicetree: separate MMC: mmc@fe320000: 1, mmc@fe330000: 0 Loading Environment from MMC... Reading from MMC(0)... *** Warning - bad CRC, using default environment rm68200_panel_of_to_plat() rm68200_panel panel@0: reset pin set done rm68200_panel_probe() rm68200_panel panel@0: Initializing MIPI DSI Panel Driver rm68200_panel_probe() rm68200_panel panel@0: Reset sequence done rm68200_panel_probe() rm68200_panel panel@0: dsi set 4 lane, video-burst, RGB 24-bit mode rm68200_panel_enable_backlight() rm68200_panel panel@0: Panel set backlight func(), initializing panel rm68200_panel_enable_backlight() rm68200_panel panel@0: attaching mipi dsi panel rm68200_panel_enable_backlight() rm68200_panel panel@0: perform panel initialization sequence rm68200_panel_enable_backlight() rm68200_panel panel@0: panel initialization sequence done, panel probed! rm68200_panel_enable_backlight() rm68200_panel panel@0: Panel set backlight func(), initializing panel rm68200_panel_enable_backlight() rm68200_panel panel@0: attaching mipi dsi panel rm68200_panel_enable_backlight() rm68200_panel panel@0: perform panel initialization sequence rm68200_panel_enable_backlight() rm68200_panel panel@0: panel initialization sequence done, panel probed! In: serial@ff1a0000 Out: serial@ff1a0000 Err: serial@ff1a0000 Model: Orange Pi 4 LTS Board Net: Could not get PHY for ethernet@fe300000: addr 1 eth_initialize() No ethernet found. Hit any key to stop autoboot: 0 => dcdcddcdcdcdc<INTERRUPT> => setenv splashimage 0x82000000 => setenv splashfile /boot/splash.bmp => load mmc 0:1 ${splashimage} ${splashfile} 1920138 bytes read in 61 ms (30 MiB/s) => bmp display ${splashimage} => <INTERRUPT> => uclass_get_device_by_ofnode() Looking for clock-controller@ff760000 uclass_find_device_by_ofnode() Looking for clock-controller@ff760000 uclass_find_device_by_ofnode() - checking reset uclass_find_device_by_ofnode() - checking reset uclass_find_device_by_ofnode() - result for clock-controller@ff760000: reset (ret=0) uclass_get_device_by_ofnode() - result for clock-controller@ff760000: reset (ret=0) rm68200_panel_enable_backlight() rm68200_panel panel@0: Panel set backlight func(), initializing panel rm68200_panel_enable_backlight() rm68200_panel panel@0: attaching mipi dsi panel rm68200_panel_enable_backlight() rm68200_panel panel@0: perform panel initialization sequence rm68200_panel_enable_backlight() rm68200_panel panel@0: panel initialization sequence done, panel probed! dsi_phy_post_set_mode() dw-mipi-dsi-rockchip dsi@ff960000: Set mode 00000000f4f3b4a0 enable 1 device_bind_common() Bound device vop@ff900000.vidconsole0 to vop@ff900000 notify_dynamic() Sending event 5/(unknown) to spy 'efi_disk add' notify_dynamic() Sending event 5/(unknown) to spy 'efi_disk add' In: serial@ff1a0000 Out: serial@ff1a0000 Err: serial@ff1a0000 Model: Orange Pi 4 LTS Board raydium-rm68200.c dw_mipi_dsi.c rk_vop.c dw_mipi_dsi_rockchip.c clk_rk3399.c .config rk3399-orangepi.dts
  8. hello, i'm trying to run latest uboot v2025.03 rc2 with kernel 6.6 on orange pi 4 lts. i have same error :). In the unofficial image from armbian-build with latest Armbian Edge Kernel version(6.12), I see that this module gives many error messages to the dmesg output. setenv bootargs "root=/dev/mmcblk0p1 rw rootwait console=ttyS2,1500000 modprobe.blacklist=sprdwl_ng" saveenv is only solution for now.
  9. Thank you again, the lcd panel works.. Have a good days!!!.. armbian v25.02 rolling for Orange Pi 4 LTS running Armbian Linux 6.12.13-current-rockchip64 Linux orangepi4-lts 6.6.62-current-rockchip64 #1 SMP PREEMPT Tue Feb 11 11:37:33 +03 2025 aarch64 GNU/Linux
  10. Hello @Werner, you are right, i changed name of the patch file to zzz-kernel-patch-nv3051f1-lcd-panel.patch and its worked. thank you very much.
  11. Hello, I'm trying to make a change for kernel panel driver for custom mipi dsi panel and orangepi-4-lts dts file. I could successfully flashed my armbian and bringed on our orangepi-4-lts board. I have configured to. debian minimal server rootfs and current linux kernel git tree in menuconfig with that command. sudo apt-get -y install git git clone --depth=1 --branch=v24.11 https://github.com/armbian/build cd build/ ./compile.sh ./compile.sh KERNEL_GIT=shallow After bring up, i tried to change existing linux kernel driver to our customized one using userpatches and that worked well. But i forgot the change dts file of orangepi4-lts and i have changed necessary lines in the existing orangepi-4-lts.dts file and linux kernel driver and used same command with kernel patch, but no luck, i got errors. Command for kernel patching, ./compile.sh kernel-patch BOARD=orangepi-4-lts BRANCH=current After changed, the patch file generated successfully. I moved it to userpatches kernel directory with that command sudo mv /home/oem/Desktop/build/output/patch/kernel-rockchip64-current.patch userpatches/kernel/archive/rockchip64-6.6/kernel-rockchip64-current.patch Command for building only kernel, ./compile.sh kernel BOARD=orangepi4-lts BRANCH=current the command works well if i patch only panel-newvision-nv3051d.c in /Desktop/build/cache/sources/linux-kernel-worktree/6.6__rockchip64__arm64/drivers/gpu/drm/panel/panel-newvision-nv3051d.c. If the patch file include changes both panel-newvision-nv3051d.c and rk3399-orangepi-4-lts.dts files then armbian build shows me error message. [🔨] Patch ->kernel-rockchip64-current(:1) (+97/-2)[2M] {rk3399-orangepi-4-lts.dts, panel-newvision-nv3051d.c}<- needs fixing: can't find file to patch. [🔨] Problem with ->kernel-rockchip64-current(:1) (+97/-2)[2M] {rk3399-orangepi-4-lts.dts, panel-newvision-nv3051d.c}<-: Failed to apply patch /home/oem/Desktop/build/userpatches/kernel/archive/rockchip64-6.6/kernel-rockchip64-current.patch those two file is exists in the directory and i will share full log as attachment in here(tried to upload log via armbian-build but it doesnt work). I tried everything and couldnt found a root issue. My host environment is fresh installed ubuntu 22-04 jammy on amd64. Thank you for your help and suggestions. kernel-rockchip64-current.patch build.log
