Z11ntal33r
3804 profile views
  1. I just want to say, c0rnelius, you are a lifesaver! I’ve spent several hours trying to figure out this issue, and it’s reassuring to see I’m not the only one dealing with it. This problem must be more common than it seems. I initially thought it was related to power management, as the external drives might be drawing too much power. In my case, I tried countless methods to disable USB power management and other tweaks, but it turns out the simple custom boot file was the ultimate solution! For reference, I’m running v24.11.1 on an Odroid N2 with Armbian Linux 6.6.63-current-meson64 Update This is a more widely issue it seems given there are other releated threads
  2. Same issue here. Upgraded from Armbian 23.8.1 Bookworm with Linux 6.1.63-current-rockchip and now my Tinkerboard won't boot Here is the log from the upgrade process. Unfortunately, I am not home and hence cannot debug any further with an UART for the next weeks
  3. Same issue here as well. I have ended up in this situation multiple times for the last year and I think it's time to move over to a more powerful board. Not sure yet which one I should pick up yet. One option might be Orange Pi 5. For everyone else with kernel issues, here is what I do when I use an. eMMC setup 1. Burn new raw image to SD (e.g. `Armbian_23.11.2_Odroidn2_jammy_current_6.1.68`) 2. Power it on and make sure it works and libs are fine. E.g `dm_mod` 3. Mounts eMMC partition 4. Move both boot folder and libs (E.g. folder `6.1.68-current-meson64` in /lib/modules to lib/modules) to eMMC 5. Run the following in both boot folders: `mkimage -A arm64 -O linux -T kernel -C none -a 0x1080000 -e 0x1080000 -n Linux -d vmlinuz-* uImage` 6. Reboot and verify that setup on eMMC works
  4. It seems that I am not able to boot directly from eMMC and use the second method Boot from eMMC from armbian-install. However, I am able to set mmcblk1 (eMMC) as SD and choose method 1 Boot from SD where I end up by booting from SD and using my eMMC as root. Prior I could boot without the SD carad, which is what I want, but at least this way I am able to use my eMMC. mmcblk0 is my SD card mmcblk1 is my eMMC ___ _ _ _ _ _ ____ / _ \ __| |_ __ ___ (_) __| | | \ | |___ \ | | | |/ _` | '__/ _ \| |/ _` | | \| | __) | | |_| | (_| | | | (_) | | (_| | | |\ |/ __/ \___/ \__,_|_| \___/|_|\__,_| |_| \_|_____| Welcome to Armbian 23.8.1 Jammy with Linux 6.1.50-current-meson64 No end-user support: community creations System load: 5% Up time: 1 min Memory usage: 5% of 3.69G IP: 192.168.45.19 CPU temp: 42°C Usage of /: 12% of 15G RX today: 154.5 MiB user@odroidn2:~$ sudo lsblk [sudo] password for gzjlspxwkh: NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS mmcblk0 179:0 0 14.8G 0 disk └─mmcblk0p1 179:1 0 14.7G 0 part /boot /media/mmcboot mmcblk1 179:32 0 14.6G 0 disk └─mmcblk1p1 179:33 0 14.4G 0 part /var/log.hdd / mmcblk1boot0 179:64 0 4M 1 disk mmcblk1boot1 179:96 0 4M 1 disk zram0 252:0 0 1.8G 0 disk [SWAP] zram1 252:1 0 50M 0 disk /var/log zram2 252:2 0 0B 0 disk
  5. I am actually not able to boot from eMMC at all after the upgrade earlier, even after a clean install to eMMC with either Armbian_23.8.1_Odroidn2_jammy_current_6.1.50 or Armbian_23.5.1_Odroidn2_jammy_current_6.1.30. Not sure if I should delete /dev/mmcblk1boot0/1 as well before each clean install or what to do to be able to boot from eMMC again
  6. Same issue here with Odroid N2 as the kernel did not update successfully it seems, but armbian-config did (from 6.1.11-meson64 and armbian 23.02). I ended up with re-installing from a clean image. However, after upgrading packages, the welcoming message now says: "No end-user support: community creations". Not sure why I would receive it as I only have ran apt update and upgrade after booting up before doing a restart. Image: Armbian_23.8.1_Odroidn2_jammy_current_6.1.50
