prahal
176 -
Other groups
Contributor/Maintainer
Profile Information
Gender
Male
Location
France
Interests
NAS, media center, Kernel
Contact Methods
Mastodon
@abws
IRC
#abws
Github
prahal
Discord
prahal
I did not detect the fancontrol issue sooner as I had not tested the trixie image. Indeed PrivateDevices=no should be set because helios64 and helios4 points fancontrol tu /dev symlinks prepared via udevs rules to sysfs files. I don't know if I can get rid of these udev rules, ie if I have persistend access to the proper sysfs directories for thermal and hwmon required by fancontrol on helios64. I also question why only 3 boards uses fancontrol in armbian. I had a thermal policy patch for the dts, it has the added bonus that it works when the kernel start and until it stops thus no uneeded high fan speed before fancontrol start and after it stops. But I am still wondering why kobol team chossed fancontrol and thus what are the pros and cons of fancontrol vs dts thermal policy. https://github.com/armbian/build/pull/8928 PR to set PrivateDevices=no when one upgrades armbian-bsp-cli-helios64-current or edge is in the pipe.
armbian-config : System > Storage > "STO001 - Install" or directly nand-sata-install You will get │ │ 1 Boot from SD - system on SATA, USB or NVMe │ │ │ │ 2 Boot from eMMC - system on eMMC │ │ │ │ 3 Boot from eMMC - system on SATA, USB or NVMe │ │ │ │ 4 Boot from MTD Flash - system on SATA, USB or NVMe │ │ │ │ 5 Install/Update the bootloader on SD card (/dev/mmcblk1) │ │ if you select boot from eMMC I think the installer will replace RoobiOS u-boot (and I guess Roobi Boot Menu) with Armbian U-Boot. I still need to experiment with Roobi OS (i.e. if there is a bootloader in SPI flash like on PC instead of only on eMMC). But you might want to try "boot from SD - system on NVME" and keep the Armbian bootloader on SD with the SD card kept plugged. If you install the bootloader on the eMMC likely you won't get the Roobi Boot menu anymore. About the boot priority, I guess it is written in the Radxa doc. It depends on how they configured their U-Boot.
Well no. I meant what you did. Install on an SD card and boot. The thing is the RoobiOS menu, as far as I understand, is the EMMC Radaxa OS U-boot. My EMMC was shipped empty, and I have no Roobi Menu. U-Boot is the first thing to load, so if you get a Roobi menu you are not booting from SD card u-boot.
I have no experience installing to NVME yet, but I guess you have to write the image to an SD card then move the install with armbian-config to the NVME. Also I don't know if Radxa u-boot is OK for Armbian images. You might be booting from Radxa U-boot on emmc to Armbian Linux kernel. I hope if an Armbian install SD card is inserted, its u-boot takes precedence over the EMMc one, but I am not confident it does for an NVME install. I cannot test a RoobiOS setup until mid September to confirm if that is the issue. You should provide the serial console output so I can investigate.
@justanothernoob the images with "current" instead of "vendor" in the name have very limited hardware support (no HDMI, no sound, etc). You should peek the "vendor" images. Mind I noted to use the images dated 16th of August or post as otherwise your pcie sata connected drives won't work most of the time. So you should try bookworm_vendor or noble_vendor with xfce,cinnamon,gnome,kde-neon if you want a graphical interface and minimal for serial console/ssh only. You will only get black screen from HDMI with "current" images, that is expected (the HDMI support is not in the linux kernel, only in linux-rockchip kernel, ie vendor as of yet). ie the image you told using https://fi.mirror.armbian.de/incoming/prahal/rock-5-itx/archive/Armbian_25.8.1_Rock-5-itx_bookworm_current_6.12.41_minimal.img.xz is such a linux kernel without HDMI support for rock-5-itx. https://fi.mirror.armbian.de/incoming/prahal/rock-5-itx/archive/Armbian_25.8.1_Rock-5-itx_bookworm_vendor_6.1.115_xfce_desktop.img.xz has HDMI support. you should be able to install form serial console with both vendor and current images. Mind I still need to read about installing RoobiOS on my emmc as sadly my board was shipped with an empty EMMC. So I cannot yet guide you through RoobiOS boot selection.
@laibsch, this is the Radxa Custom Debian OS that is shipped on the emmc. @justanothernoobCould be I did not have this issue because my board was delivered with an empty emmc (no RoobiOS installed). Though i doubt it. Do you have the serial console full output? Also is it a typo or is the error really about `/dev/mount/mmcblk0p1` not `/dev/mmcblk0p1`. Mind `/dev/mmcblk0p1` is the emmc partition while you should be booting from the SD card. I tet installed Note also that 25.2.2 linux (current) images area lacking most devices support, while vendor 25.2 has an issue with PCIe SATA detection. THe vendor PCIe detection is fixed in latest 25.08 vendor. But that does not explain your current issue... Can you try https://fi.mirror.armbian.de/incoming/prahal/rock-5-itx/archive/ vendor images dated after 16th of August (the ones before did not have the fix for PCIe SATA detection)? Like https://fi.mirror.armbian.de/incoming/prahal/rock-5-itx/archive/Armbian_25.8.1_Rock-5-itx_noble_vendor_6.1.115_xfce_desktop.img.xz
Armbian doesnt seem to see sata harddrives.
prahal replied to DontMindMe's topic in Radxa Rock 5 ITX
Commit a1fe1eca0d8be69ccc1f3d615e5a529df1c82e66 in upstream tells that "rxX_cmn_refclk_mode" RX common reference clock mode for lane X. This mode should be enabled only when the far-end and near-end devices are running with a common reference clock. The link training either fails or is highly unstable (link state will jump continuously between L0 and recovery) when this mode is enabled while using an endpoint running in Separate Reference Clock with No SSC (SRNS) mode or Separate Reference Clock with SSC (SRIS) mode. I applied this patch and set `rockchip,rx-common-refclk-mode = <0 0 0 0>;` for `&pcie30phy` in rk3588-rock-5-itx.dtb as upstream does and SATA detection is stable now. To all: I still have that patch for upstream 6.12 to avoid having the ASM Sata PCIe controller hang when the M.2 PCIe controller is initialized first, pending. However, there were no reports of Armbian sata detection failure with 6.12 in this thread. Please report if I should bring it sooner. -
@Popolon indeed this issue rot for a long time. I cleaned up my backlog to have more time for armbian. Also I still have quite a few processes to learn about armbian board maintenance still to this day. But you confirm that with mainline 6.12 all is fine ? But, indeed no HDMI out and no audio. I still have a patch for mainline 6.12 in the pipe about a race condition between SATA chip and nvme as far as I remind. I will prioritize data vendor kernel debugging if this mainline patch is not required (and indeed mainline still lacks any multimedia capability, this might be a showstopper for most users) even though I am close to complete testing and send PR for this one. As of now I have confirmed that this mainline patch set does not help vendor as the vendor branch has a hack that workaround the issue that mainline faces about this SATA/nvme race. -
Install non-vendor image (kernel 6.12+)
prahal replied to Jurgen.Schober's topic in Radxa Rock 5 ITX
Mainline audio is not working. Vendor audio is working but not activated by default yet -
Sorry took so long: workaround is to set the two mixer controls via cli: amixer -c 4 sset 'Left Headphone Mixer Left DAC' on amixer -c 4 sset 'Right Headphone Mixer Right DAC' on they are off on armbian and on the initial image I was testing with which you properly sorted out was Radxa default Debian image. Edit: note you can increase the sound output by increasing "Headphone Mixer", via amixer or interactively via "alsamixer -c 4". Edit 2: note that this only works for the vendor kernel. I don't get audio out with the mainline one (replace -c 4 by -c 0 there as there is only one audio device available with mainline)
Sorry for the late reply. Note the baud rate is set in U-Boot to 1.5Mbps (and your device tells max 1Mbps).
This is for rock 5b. The U-boot requirements is for rock 5b only as it seems to be due to rock 5b being powered via this usb-c port (and talks about the USB-PD negociation needing to happen in u-boot). So this patch to rock 5b dts will not fix rock-5-itx support. Edit: Mind I have not checked yet if the rock-5-itx dts already has this code or not.
Thanks, @Alex T, for your hindsights. Would plugging an ATX power supply instead of the original external power supply help sort this out? What kind of ATX PSU would be required? I had measured the voltage on the board with a voltmeter and got a little above 12V fine, but I believe to phase out transient voltage drops an oscilloscope is required (I got a portable oscilloscope a few months ago). Also, I have a test case (attached cpufreq-switching-2.c) that always crashes the big CPUs (even when I set a 5 milliseconds delay between transitions, with #define TRANSITION_DELAY 5000). I believe if the power supply is at fault, I should be able to see small voltage drops on the 12V rail on the board with the oscilloscope? cpufreq-switching-2.c
I landed the restoration of the eMMC hs400 support and the fix for the helios64-heartbeat-led.service that I had broken in a previous commit. The upped voltages are not in. Though these upped voltage seems to help a lot of people, they are not the endgame. Ie I tried setting all the CPU b voltages to max 1.2, and I believe I can still crash the CPUs b with my test case... Also, I am onboarding on another board maintenance. Fixed an issue with a PL2303 USB serial adapter that it did not support 1.5Mbps but only 1.2Mbps.... In the meantime, I nailed down an issue on edge 6.14 that might also affect other version but not tested yet. I fixed it locally by setting the startup time for HDD rail a and rail b to have them not start at the same time by the kernel. Ie the upstream Linux kernel have the HDD rails defined, and it seems it restarts them when the kernel load thus draining too many amps on my board and I repeatedly had: Internal error: synchronous external abort: 0000000096000210 [#1] PREEMPT SMP (...) [ 3.890774] Call trace: [ 3.891012] rockchip_pcie_rd_conf+0xf4/0x1e8 (P) [ 3.891461] pci_bus_read_config_dword+0x7c/0xdc [ 3.891906] pci_bus_generic_read_dev_vendor_id+0x34/0x1b4 [ 3.892428] pci_scan_single_device+0xa0/0x108 [ 3.892857] pci_scan_slot+0x68/0x1c4 [ 3.893216] pci_scan_child_bus_extend+0x44/0x2cc [ 3.893668] pci_scan_bridge_extend+0x320/0x60c [ 3.894104] pci_scan_child_bus_extend+0x1b8/0x2cc [ 3.894564] pci_scan_root_bus_bridge+0x64/0xe4 [ 3.895000] pci_host_probe+0x30/0x108 [ 3.895367] rockchip_pcie_probe+0x43c/0x5e4 [ 3.895777] platform_probe+0x68/0xdc I cannot reproduce this PCIe failure after adding the 10 seconds delay that Kobol devs put in the u-boot between rail a and rail b startup. Though, 10 seconds seems a lot, but I have no clue why the Kobol team chose such a huge value.
I "believe" that a board can only ship one DTB armbian wise. I will have to study that to be confident though. If the board is not the same hardware wise, it could be it requires its own "board" config in armbian. It being close won't help (except it will make it easier for this board maintainer as most of the work will already have been done). I have no experience in adding a new board to armbian, but I believe cloning the armbian/build repository and creating a new config/boards/ is the first step. And having a new tag for this board on the forum. As a local hack (I believe this is not a proper fix but I might be wrong), you might be able to create an override dtb file to remove existing nodes and add new ones to an existing board dtb.
