Alex83
  1. I would love to get this or support with the devices I own. I think we should continue developing Mini-AndroidTV-PCs as easy as possible and give that junk devices a sensful feasible life.😃
  2. @SteeMan It is not easy to take an UART-Cable every time when I wanna check what's wrong with the device... - So am I the only unhappy person with the HDMI-bug?
  3. Hi. Sorry for my wrong information. It is a banana pi m1. - Is there also a solution? I think it has an A10 processor.
  4. Hey, I have a Banana PI M1 root@192.168.178.193's password: _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| v25.5.1 for Banana Pi running Armbian Linux 6.12.30-current-sunxi Packages: Ubuntu stable (noble) IPv4: (LAN) 192.168.178.193 (WAN) 87.160.68.42 Performance: Load: 20% Up time: 26 min Memory usage: 11% of 959M CPU temp: 47°C Usage of /: 5% of 29G Commands: Configuration : armbian-config Monitoring : htop I installed the latest image, since I had trouble to boot my old configuration. After I installed it at my TV for debuging I just saw the first boot-sequence until usually the ubuntu-boot starts in a new screen. There came no screen an the device was not available via ssh or ping. - So I decided to check the SD-Card in my ubuntu laptop. There were errrors which have been fixed. Afterwards I had still the same black screen after boot-prompt. So I was sure copied all of my files via nautilus and thought, why not starting from beginning. So I installed the latest image. - This image bootet perfect. There were a screen and I installed the user and admin credentials. - After a system update unfortunately I have the same black-screen after boot-prompt. The device is avaliable via ssh. So if we have to do debuging there is no chance without HDMI... So I think it is essential to solve this issue... @Igor Unfortunately the problem has to get solved, even when just one person is doing the HDMI-stuff. But if we don't get it resloved I see no debug-possiblities anymore if there is no ssh! - So w
  5. Hi, Unfortunately I always get an error when upgrading my Banana Pi. <code> Do you want to continue? [Y/n] Y Setting up linux-headers-current-sunxi (24.11.1) ... Armbian 'linux-headers-current-sunxi' for '6.6.62-current-su nxi': 'postinst' starting. Compiling kernel-headers tools (6.6.62-current-sunxi) using 2 CPUs - please wait ... YACC scripts/kconfig/parser.tab.[ch] Bus error make[2]: *** [scripts/Makefile.host:17: scripts/kconfig/pars er.tab.h] Error 135 make[1]: *** [/usr/src/linux-headers-6.6.62-current-sunxi/Ma kefile:699: oldconfig] Error 2 make: *** [Makefile:234: __sub-make] Error 2 dpkg: error processing package linux-headers-current-sunxi ( --configure): installed linux-headers-current-sunxi package post-installa tion script subprocess returned error exit status 2 Errors were encountered while processing: linux-headers-current-sunxi E: Sub-process /usr/bin/dpkg returned an error code (1) root@bananapi:~# lsb_release -ar No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 22.04.5 LTS Release: 22.04 Codename: jammy root@bananapi:~# </code> Can anyone help to self the issue?
