lanefu Posted March 28, 2019 Share Posted March 28, 2019 Any good recommendations for espressobin powersupplies for NAS applications? Link to comment Share on other sites More sharing options...
Technicavolous Posted March 30, 2019 Share Posted March 30, 2019 I did a LOT of study on these modular power supplies. Some are junk, most are actually, but if you know what you're dealing with it can work out well for you. I found my way to a Mean Well RD65A On Amazon that meets its specifications. I used a couple of electronic loads to test the voltage and current ratings and it held them for hours several times without excessive heating. I had other similar units from other manufacturers that failed miserably. Voltage dropped before coming close to their current ratings. For the price this is a decent supply. If you look at it with an O'scope under load it's a little messy but not terrible. There is a little RF emission but shielding and bypassing should solve any problems that might cause unless you're using it for weak signal communication devices. I'm using mine with a ClearfogPro and a 4 bay hotswappable 2.5 inch SSD array since Christmas. Link to comment Share on other sites More sharing options...
lanefu Posted April 5, 2019 Author Share Posted April 5, 2019 On 3/30/2019 at 3:04 PM, Technicavolous said: I did a LOT of study on these modular power supplies. Some are junk, most are actually, but if you know what you're dealing with it can work out well for you. I found my way to a Mean Well RD65A On Amazon that meets its specifications. I used a couple of electronic loads to test the voltage and current ratings and it held them for hours several times without excessive heating. I had other similar units from other manufacturers that failed miserably. Voltage dropped before coming close to their current ratings. So somehow I failed and missed your post until now... but ironically I did end up going with an RD65A! Thanks for the validation. Now I need to assemble my 3d printer so that I can print a terminal block cover for it Link to comment Share on other sites More sharing options...
