adib Posted April 7, 2019 Posted April 7, 2019 Hi, I use Armbian Stretch 4.19 on an OrangePi Zero Plus2 board with 512MB of memory, cat /proc/meminfo shows: MemTotal: 460224 kB I assume that the missing amount of memory is reserved for the GPU. I do not use the GPU, how can I decrease the amount of reserved memory?
guidol Posted April 7, 2019 Posted April 7, 2019 Did you use a server or desktop image? I didnt know any GPU-setting (like at the Raspberry Pi config-file). My OPi Zero Plus2 H5 does show the follwing memory-values: root@opi-zplus2-h5(192.168.6.26):/home/guido# cat /proc/meminfo MemTotal: 490828 kB MemFree: 195680 kB MemAvailable: 421708 kB top KiB Mem : 490828 total, 195380 free, 58268 used, 237180 buff/cache KiB Swap: 245412 total, 245412 free, 0 used. 421408 avail Mem Welcome to ARMBIAN 5.77 user-built Debian GNU/Linux 9 (stretch) 5.0.6-sunxi64 package bsp-kernel[5.77] u-boot[5.77] dtb[5.77] firmware[5.77] config[5.77] Memory usage: 13 % of 479MB
guidol Posted April 7, 2019 Posted April 7, 2019 its 2 years old, but maybe this would help?https://github.com/armbian/build/issues/651#issuecomment-292714029 Quote igorpecovnik commented on 8 Apr 2017 • Ahaa. You can pass kernel parameters in boot script. Check this, it's self explanatory:https://github.com/igorpecovnik/lib/blob/master/config/bootscripts/boot-sunxi.cmd#L40 So you can add disp_mem_reserves=on to /boot/armbianEnv.txt ... yes, we have wrong/reversed logic here. Other just edit boot.cmd, save and convert to boot.scr when done and reboot.
adib Posted April 7, 2019 Author Posted April 7, 2019 I added "disp_mem_reserves=on" in the /boot/armbianEnv.txt file. Same result. I also tried the minimal desktop image. In all of them cat /proc/meminfo shows: MemTotal: 460224 kB
adib Posted April 7, 2019 Author Posted April 7, 2019 adi@orangepizeroplus2:~$ free total used free shared buff/cache available Mem: 460224 84952 199060 2784 176212 363532 Swap: 230096 0 230096 adi@orangepizeroplus2:~$
guidol Posted April 7, 2019 Posted April 7, 2019 thats my free-output, BUT I deinstalled/removed NetworkManager from my System. Maybe thats the around 20MB less memory-usage? root@opi-zplus2-h5(192.168.6.26):/boot# free total used free shared buff/cache available Mem: 490828 62880 156776 1668 271172 416788 Swap: 245412 0 245412 I do use ifupdown and /etc/network/interfaces and /etc/resolv.conf
adib Posted April 7, 2019 Author Posted April 7, 2019 38 minutes ago, guidol said: My OPi Zero Plus2 H5 does show the follwing memory-values: What armbian image do you use? I have the same board.
guidol Posted April 7, 2019 Posted April 7, 2019 Just now, adib said: What armbian image do you use? I have the same board. ARMBIAN 5.77 user-built Debian GNU/Linux 9 (stretch) 5.0.6-sunxi64 Its the dev-image out of the armbian-build-system: Armbian 5.77 with Kernel 5.0.6 in stretch/server flavour https://docs.armbian.com/Developer-Guide_Build-Preparation/
adib Posted April 7, 2019 Author Posted April 7, 2019 I also uninstalled the NetworkManager from the system to save memory The "MemTotal" field should show the total amount of available memory in the system, and should not be affected by NetworkManager de-installation.
adib Posted April 7, 2019 Author Posted April 7, 2019 Thanks, I'm on ARMBIAN 5.75 stable Debian GNU/Linux 9 (stretch) 4.19.20-sunxi64. I'll try to move to the dev image. 1
adib Posted April 7, 2019 Author Posted April 7, 2019 I've upgraded the kernel to 5.0.5 using armbian-config, now I have 2MB less than before ARMBIAN 5.77.190404 nightly Debian GNU/Linux 9 (stretch) 5.0.5-sunxi64 System load: 0.26 0.17 0.07 Up time: 1 min Memory usage: 18 % of 447MB IP: 192.168.1.112
adib Posted April 9, 2019 Author Posted April 9, 2019 I discovered that if I boot without the HDMI display connected the MemTotal is 481MB. With the HDMI display connected MemTotal is 449MB. So it seems that not the GPU but the HDMI or the Frame buffer are to blame. It's not too much 32MB reserved for a 800x480 display?
guidol Posted April 9, 2019 Posted April 9, 2019 1 hour ago, adib said: So it seems that not the GPU but the HDMI or the Frame buffer are to blame. It's not too much 32MB reserved for a 800x480 display? Ahh - yes - I only use the SSH-Console, so no HDMI connected here. 32MB is way to much for 800x480, BUT for FullHD (1920x1080) it should fit The memory seems to be automatically reserved for the HDMI-Output.
