Mafer Posted April 11, 2019 Posted April 11, 2019 I installed Armbian on an Orangepi Plus 2e. I have set it as Plex server, Tvheadend and Samba enabled from armbian-config softy. All perfect until I activate the wifi access point also from armbian-config. Plex deconfigures me and I can no longer access it. Is there any incompatibility?
Igor Posted April 11, 2019 Posted April 11, 2019 On 4/11/2019 at 4:25 PM, Mafer said: Is there any incompatibility? Expand If you want to run multiple applications at once, this is quite common situation. Container initiatives (Docker, Snap, ...) started because of such problems. If you want to avoid this, each application have to be isolated, especially complex ones. And those are. You can play with starting an AP first and then the rest. Or running Plex inside a Docker container - this will require some manual interventions (google for "Debian docker plex") But no warranty that it will be a plug and play.
Mafer Posted April 12, 2019 Author Posted April 12, 2019 Thank you very much for answering. I was able to make it work by changing the installation order. First Samba, then Plex, Tvheadend and finally the access point. It works but Tvheadend does not work in a fluid way. Keep investigating. Very thankful.
