              Initially my Armbian_5.75_Orangepilite_Ubuntu_bionic_next_4.19.20 was booting fast. After the apt-get upgrade it boots very slowly:
[    7.747226] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
[    7.747259] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
[    7.752757] [drm] Initialized lima 1.0.0 20170325 for 1c40000.gpu on minor 1
I wait for 10 minutes from the above row to the login below:
Ubuntu 18.04.2 LTS homesystem ttyS0
homesystem login:
Any idea what could be the issue? This is already with loglevel 7 on boot debug.
Regards
Actually dmesg, returns a couple more rows:
[    8.820618] zram: Added device: zram0
[    8.821346] zram: Added device: zram1
[    8.822184] zram: Added device: zram2
[    8.822872] zram: Added device: zram3
[    8.823426] zram: Added device: zram4
[    8.823959] zram: Added device: zram5
[    8.892129] zram1: detected capacity change from 0 to 64516096
[    9.915956] random: crng init done
[    9.915965] random: 7 urandom warning(s) missed due to ratelimiting
[    9.944798] Adding 63000k swap on /dev/zram1.  Priority:5 extents:1 across:63000k SSFS
[    9.954371] zram2: detected capacity change from 0 to 64516096
[    9.977844] Adding 63000k swap on /dev/zram2.  Priority:5 extents:1 across:63000k SSFS
[    9.980549] zram3: detected capacity change from 0 to 64516096
[   10.004868] Adding 63000k swap on /dev/zram3.  Priority:5 extents:1 across:63000k SSFS
[   10.006954] zram4: detected capacity change from 0 to 64516096
[   10.031167] Adding 63000k swap on /dev/zram4.  Priority:5 extents:1 across:63000k SSFS
[   10.131826] zram0: detected capacity change from 0 to 52428800
[   10.290412] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[   18.085851] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   32.048549] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   45.040395] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   46.809320] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
None without
armbianmonitor -u
and what do you use it for?
2 minutes ago, Igor said:
None without
armbianmonitor -u
Thank you very much for the tip!
I just found out that this was a dhclient timeout issue.
Timeout 300, which is too much, but was not reported.
Set it to 20 and now is much better.
I don't need need Network manager and prefer my own scripts for networking, as the PI will be hostapd or client depending on the situation.
Regards,
Todor
