Petee Posted April 16, 2019 Posted April 16, 2019 Over the years have been using the Pine64 2Gb computer as an automation server running with original Xenial Base Image [20161218-1] by longsleep. This is a first generation Pine64 2Gb computer that I got during the start up of the company. Currently utilizing a 2 AMP 5VDC PS connected to the Euler bus, heatsinks on the top and bottom of the board and a boot up 100Mb mode. It would run fine for months then occassionally wouldn't start on boot. Recently redid the box using Armbian. | _ \(_)_ __ ___ / /_ | || | | |_) | | '_ \ / _ \ '_ \| || |_ | __/| | | | | __/ (_) |__ _| |_| |_|_| |_|\___|\___/ |_| Welcome to ARMBIAN 5.73 stable Ubuntu 18.04.2 LTS 4.19.25-sunxi64 System load: 0.36 0.44 0.33 Up time: 1:27 hour Memory usage: 31 % of 2001MB IP: 192.168.244.149 CPU temp: 42°C Usage of /: 20% of 30G Last login: Tue Apr 16 17:22:07 2019 from 192.168.244.232 Which works well except that every few days the time gets reset to some odd date a couple of hundred years from now and then shuts down the network port. Checking the RTC (with battery) the time is always right. Here using an NTP server plugin with PFSense. Particular about time. These issues are messing with my automation schedules. Should I update to a nightly build?
windysea Posted April 17, 2019 Posted April 17, 2019 The PineA64+ is actually based on an Allwinner A64. Yes it sounds like you will want a more recent kernel. This thread may be of some help: A64 date/time clock issue
martinayotte Posted April 17, 2019 Posted April 17, 2019 On 4/16/2019 at 11:48 PM, Petee said: Should I update to a nightly build? Expand Nightly Pine64 DEV 5.0.y builds just have been enabled for tomorrow's builds.
Petee Posted April 17, 2019 Author Posted April 17, 2019 Thank you Martin! Yesterday updated Pine64 with NTP and NTPDate and pulling the HWClock time on reboot first before network and configured local GPS server to have a host name and using hostname instead of IP for time now. The issue here was that I was running a MQTT application which would check on the OmniPro alarm panel and adjust the time on it if it was off. It would reset the time and date to 2219 or something like that and mess with the automation in the firmware of the panel. Will update to new Dev 5.0 builds in the next couple of days....TIA..
