Hello ,
I'm new to Armbian, I'm trying to create an SD image for an Olimex A13 Som card (https://www.olimex.com/Products/SOM/A13/A13-SOM-512/) + A13 Som WIfi (https: //www.olimex.com/Products/SOM/A13/A13-SOM-WIFI/open-source-hardware). After successfully executing the build and transferring the image to SD with Etcher, the boot starts correctly but hangs on Starting Kernel ...
Do you have any idea how to solve the problem?
Thanks in advance!
Board: Not on the list
This is usually the symptom of wrong DT.
Also, make sure to have "verbosity=7" and "console=serial" and use USB-TTL Serial Debug to look the details of boot process.
Thanks for the reply,
I tried again to make a build but the result is always the same!
I noticed, however, that the card that is called from the config file is Model: Olimex A13-Olinuxino
and at the start there is an error!
U-Boot SPL 2019.04-armbian (Apr 17 2019 - 17:05:21 +0200)
DRAM: 512 MiB
Failed to set core voltage! Can't set CPU frequency
Trying to boot from MMC1
I have not made any changes I have only set Olimex A13 Som as the type of card ... is there a problem with the DT of origin?
I searched a bit in the various folders and I don't see any other references to the SOM A13 but only to the A13 olinuxino and olinuxino micro board.
The boot log:
DRAM: 512 MiB
U-Boot 2019.04-armbian (Apr 17 2019 - 17:05:21 +0200) Allwinner Technology
CPU:   Allwinner A13 (SUN5I)
I2C:   ready
DRAM:  512 MiB
MMC:   mmc@1c0f000: 0
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
Setting up a 1024x768 vga console (overscan 0x0)
Error: no valid bmp image at 66000000
In:    serial
Out:   vga
Err:   vga
Allwinner mUSB OTG (Peripheral)
Net:
Warning: usb_ether using MAC address from ROM
eth0: usb_ether
** Reading file would overwrite reserved memory **
There is no valid bmp file at the given address
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
scanning bus 0 for devices... 2 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3798 bytes read in 3 ms (1.2 MiB/s)
U-boot loaded from SD
Boot script loaded from mmc
155 bytes read in 2 ms (75.2 KiB/s)
4927321 bytes read in 648 ms (7.3 MiB/s)
7481128 bytes read in 980 ms (7.3 MiB/s)
23300 bytes read in 8 ms (2.8 MiB/s)
2266 bytes read in 4 ms (552.7 KiB/s)
Applying kernel provided DT fixup script (sun5i-a13-fixup.scr)
## Executing script at 44000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    4927257 Bytes = 4.7 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
   Loading Ramdisk to 49b4d000, end 49ffff19 ... OK
   Loading Device Tree to 49ade000, end 49b4cfff ... OK
Starting kernel ...
I don't think this error is the source of the problem.
Unfortunately, searching in the forum did not reveal any people getting success with this Olimex A13 Som.
Since I don't have such board, I can't even trying it myself ...
Your chances are tiny, maybe you should stick with Legacy image provided by Olimex.
Unfortunately I had also tried a solution on the forum but with a negative result.
I will try to experiment the same in case I have to come to a solution I will put it here at the disposal of the community.
Thanks anyway for the answers Martinayotte. Thanks to the Armbian team for the wonderful job.
