Booting Cubietruck hangs: "A Start Job is running for LSB: Raise network interfaces"
using newest Legacy Image Armbian_5.04_Cubietruck_Debian_jessie_3.4.110 there is still a wifi problem while booting. Correct?
For more than one minute the boot process hangs showing following error message:
After one minute the boot process continues. The wlan0 connection gets somehow established. But it is slowly und not really stable.
root@cubietruck:~$ cat /etc/network/interfaces
auto eth0
    iface eth0 inet dhcp
auto wlan0
    iface wlan0 inet dhcp
    wpa-ssid My-SSID
    wpa-psk My-Password
auto lo
    iface lo inet loopback
root@cubietruck:~$ lsmod
Module                  Size  Used by
cpufreq_userspace       3524  0
sg                     23765  0
ap6210                625672  0
sunxi_ir                4037  0
hidp                   17640  0
rfcomm                 58686  0
hci_uart               25000  0
bluetooth             264185  5 hidp,hci_uart,rfcomm
dmesg:
[    5.651519] systemd[1]: Starting Syslog Socket.
[    5.656508] systemd[1]: Listening on Syslog Socket.
[    5.660963] systemd[1]: Starting Journal Service...
[    5.692171] systemd[1]: Started Journal Service.
[    5.702433] input: sunxi-ir as /devices/virtual/input/input4
[    5.704280] IR Initial OK
[    5.804250] [ap6210] select wifi ap6210
[    5.815858] [ap6210] Initializing ap6210.
[    5.822280] [ap6210] platform device registered successfully.
[    5.826606] [ap6210] Using ap6210 configuration.
[    5.944254] [mmc-msg] sdc3 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.958970] [mmc-msg] sdc3 power on
[    5.984883] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    5.989811] [mmc-msg] sdc3 set round clock 400000, src 24000000
[    6.070155] [ap6210] WLAN placed in POWER ON
[    6.082203] [mmc-err] smc 3 err, cmd 52,  RTO
[    6.086349] [mmc-err] smc 3 err, cmd 52,  RTO
[    6.094725] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.106362] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.114847] [mmc-err] smc 3 err, cmd 8,  RTO
[    6.123881] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    6.127901] systemd-udevd[105]: starting version 215
[    6.147256] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    6.160363] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    6.172289] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    6.179640] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    6.209152] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    6.221414] [mmc-msg] sdc3 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    6.226696] [mmc-msg] sdc3 set round clock 42857143, src 600000000
[    6.290586] [mmc-msg] sdc3 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    6.300506] mmc1: new high speed SDIO card at address 0001
[    6.304969] [ap6210] Linux Kernel SDIO/MMC Driver
[    6.324122] [ap6210] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[    6.816813] [ap6210] WLAN placed in RESET
[    7.217988] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    7.628632] EXT4-fs (mmcblk0p1): re-mounted. Opts: data=writeback,commit=600,errors=remount-ro
[    8.135661] Adding 131068k swap on /var/swap.  Priority:-1 extents:1 across:131068k SS
[    8.219590] [ap6210] Using ap6210 configuration.
[    8.682494] systemd-journald[101]: Received request to flush runtime journal from PID 1
[    9.186599] sunxi_gmac: probed
[    9.192082] eth0: PHY ID 001cc915 at 0 IRQ 0 (sunxi_gmac-0:00) active
[    9.196875] eth0: PHY ID 001cc915 at 1 IRQ 0 (sunxi_gmac-0:01)
[   11.199742] PHY: sunxi_gmac-0:00 - Link is Up - 100/Full
[   19.799483] eth0: no IPv6 routers present
[   62.638592] usb 5-1: USB disconnect, device number 2
[   63.895608] ehci_irq: port change detect
[   63.939154] ehci_irq: port change detect
[   64.281851] usb 5-1: new low-speed USB device number 3 using sw-ohci
[   64.514315] input: Logitech USB Optical Mouse as /devices/platform/sw-ohci.2/usb5/5-1/5-1:1.0/input/input5
[   64.526236] generic-usb 0003:046D:C05A.0004: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-sw-ohci-1/input0
[   70.160329] [ap6210] Dongle Host Driver, version 1.28.23.3 (r).
[   70.167432] [ap6210] Compiled in drivers/net/wireless/ap6210 on Feb 28 2016 at 17:13:38.
[   70.371036] [ap6210] WLAN going back to live
[   70.372797] sdio_reset_comm():
[   70.381236] [mmc-msg] sdc3 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[   70.391740] [mmc-msg] sdc3 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[   70.401051] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[   70.405984] [mmc-msg] sdc3 set round clock 400000, src 24000000
[   70.469641] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[   70.483433] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[   70.489429] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[   70.495419] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[   70.502650] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[   70.524561] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[   70.533018] [mmc-msg] sdc3 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[   70.538189] [mmc-msg] sdc3 set round clock 42857143, src 600000000
[   70.601725] [mmc-msg] sdc3 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[   70.605556] [ap6210] dhd_bus_devreset: WLAN ON
[   70.611595] [ap6210] Final fw_path=/lib/firmware/ap6210/fw_bcm40181a2.bin
[   70.622316] [ap6210] Final nv_path=/lib/firmware/ap6210/nvram_ap6210.txt
[   70.628912] [ap6210] download firmware /lib/firmware/ap6210/fw_bcm40181a2.bin
[   70.919909] [ap6210] Dongle ready, protocol version 4
[   70.926526] [ap6210] Dongle ready, protocol version 4
[   70.938148] [ap6210] Firmware up: op_mode=0x0005, Broadcom Dongle Host Driver mac=98:3b:16:81:07:59
[   70.956258] [ap6210] Firmware version = wl0: Apr 22 2013 14:50:00 version 5.90.195.89.6 FWID 01-b30a427d
[   70.959244] [ap6210] Chip: a962 Rev 1 Pkg 9
[   70.965738] [ap6210] p2p0: p2p_dev_addr=9a:3b:16:81:07:59
[   81.139641] wlan0: no IPv6 routers present
[   86.517656] [ap6210] Couldn't find P2PIE in probe response/beacon
[   86.528817] [ap6210] Couldn't find P2PIE in probe response/beacon
[   86.538836] [ap6210] Couldn't find P2PIE in probe response/beacon
[   86.544727] [ap6210] Couldn't find P2PIE in probe response/beacon
[   86.604441] [ap6210] Couldn't find P2PIE in probe response/beacon
[   92.110103] [ap6210] wl_cfgp2p_do_ioctl: IOCTL req 0x8b03 on p2p0 I/F. Ignoring.
[   92.117048] [ap6210] wl_cfgp2p_do_ioctl: IOCTL req 0x8b1d on p2p0 I/F. Ignoring.
[   92.124434] [ap6210] wl_cfgp2p_do_ioctl: IOCTL req 0x8b09 on p2p0 I/F. Ignoring.
[   93.691415] sunxi_gmac: probed
[   93.696989] eth0: PHY ID 001cc915 at 0 IRQ 0 (sunxi_gmac-0:00) active
[   93.701965] eth0: PHY ID 001cc915 at 1 IRQ 0 (sunxi_gmac-0:01)
[   93.718579] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   94.249248] sunxi_gmac: probed
[   94.254660] eth0: PHY ID 001cc915 at 0 IRQ 0 (sunxi_gmac-0:00) active
[   94.259513] eth0: PHY ID 001cc915 at 1 IRQ 0 (sunxi_gmac-0:01)
[   94.279591] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   96.259989] PHY: sunxi_gmac-0:00 - Link is Up - 100/Full
[   96.267265] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  103.009724] p2p0: no IPv6 routers present
[  106.819706] eth0: no IPv6 routers present
[  159.413080] [ap6210] Couldn't find P2PIE in probe response/beacon
[  159.418491] [ap6210] Couldn't find P2PIE in probe response/beacon
[  159.433247] [ap6210] Couldn't find P2PIE in probe response/beacon
[  159.438638] [ap6210] Couldn't find P2PIE in probe response/beacon
[  159.444145] [ap6210] Couldn't find P2PIE in probe response/beacon
[  159.449463] [ap6210] Couldn't find P2PIE in probe response/beacon
[  159.792900] [ap6210] Couldn't find P2PIE in probe response/beacon
[  159.798485] [ap6210] Couldn't find P2PIE in probe response/beacon
[  159.810808] [ap6210] Couldn't find P2PIE in probe response/beacon
[  159.816694] [ap6210] Couldn't find P2PIE in probe response/beacon
[  161.108750] [ap6210] wl_cfgp2p_do_ioctl: IOCTL req 0x8b03 on p2p0 I/F. Ignoring.
[  161.115986] [ap6210] wl_cfgp2p_do_ioctl: IOCTL req 0x8b1d on p2p0 I/F. Ignoring.
[  161.123417] [ap6210] wl_cfgp2p_do_ioctl: IOCTL req 0x8b09 on p2p0 I/F. Ignoring.
[  162.865714] sunxi_gmac: probed
[  162.871125] eth0: PHY ID 001cc915 at 0 IRQ 0 (sunxi_gmac-0:00) active
[  162.876087] eth0: PHY ID 001cc915 at 1 IRQ 0 (sunxi_gmac-0:01)
[  162.892353] ADDRCONF(NETDEV_UP): eth0: link is not ready
[  164.870859] PHY: sunxi_gmac-0:00 - Link is Up - 100/Full
[  164.878790] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  172.870632] p2p0: no IPv6 routers present
Thanks in advance!
