I'm trying to activate the uart interface Gpio 8 + 10 on the rock pi4. I have currently installed the image of radxa.
--> ARMBIAN 5.67 user-built Debian GNU/Linux 9 (stretch) 4.4.154-rk3399rockpi4b
My Linux knowledge is still in the beginning.
Who can help me to activate the upart interface Gpio 8 + 10 on the rock pi4.
Thank you
The UART2C is the one on GPIOs pins 8/10. It is already activated in Armbian as the Serial Debug port using /dev/ttyS2, so kernel output log will be sent there.
If you want to use that UART for something else, you need to deactivate the kernel log by making sure it has "console=display" in /boot/armbianEnv.txt.
3 hours ago, martinayotte said:
The UART2C is the one on GPIOs pins 8/110. It is already activated in Armbian as the Serial Debug port using /dev/ttyS2, so kernel output log will be sent there.
If you want to use that UART for something else, you need to deactivate the kernel log by making sure it has "console=display" in /etc/armbianEnv.txt.
The file is /boot/armbianEnv.txt and not in the /etc ;-)
Good catch ! :thumbup: ... I'm often suffer of dyslexia ... :P
