SchmuseTigger Posted December 9, 2019 Posted December 9, 2019 On 10/4/2019 at 12:41 AM, megi said: Linux 5.4 contains the code changes, dts changes will be included in 5.5. can anybody upload a changed file that I can import? I tried to do that change but nothing happend. 0 Quote
megi Posted December 10, 2019 Posted December 10, 2019 6 hours ago, SchmuseTigger said: can anybody upload a changed file that I can import? I tried to do that change but nothing happend. Bluetooth on Opi3 is already supported out of the box on Linux 5.5-rc1. For 5.4: https://megous.com/git/linux/commit/?h=opi3-5.4&id=00f1b53048ebeaec115d705d78a954c2bff944fe https://megous.com/git/linux/commit/?h=opi3-5.4&id=1f4e6be59748a1695ecf7453a70e1c0f9d73ac14 0 Quote
hsimon806 Posted January 14, 2020 Posted January 14, 2020 (edited) Hello, i cannot activate bluetooth, since i have no device when i enter: hcitools dev. Devices: I have tried newer kernel versions, even the nightly build: Linux version 5.4.8-sunxi64 (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #19.11.7.007 SMP Tue Jan 7 01:51:27 CET 2020 Linux version 5.5.0-rc5-sunxi64 (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #19.11.8.012 SMP Mon Jan 13 00:36:15 CET 2020 Linux version 5.5.0-rc2-sunxi64 (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #19.11.5.365 SMP Tue Dec 31 20:23:16 CET 2019 Linux version 5.5.0-rc2-sunxi64 (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #19.11.7.007 SMP Tue Jan 7 02:01:22 CET 2020 Linux version 5.5.0-rc2-sunxi64 (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #19.11.5.002 SMP Thu Jan 2 02:26:13 CET 2020 at least, i get an mac adress for the hci1 device. hci1: Type: Primary Bus: UART BD Address: 43:45:C5:00:1F:AC ACL MTU: 0:0 SCO MTU: 0:0 DOWN RAW RX bytes:1306 acl:0 sco:0 events:144 errors:0 TX bytes:30126 acl:0 sco:0 commands:144 errors:0 hci0: Type: Primary Bus: SDIO BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0 DOWN RX bytes:0 acl:0 sco:0 events:0 errors:0 TX bytes:0 acl:0 sco:0 commands:0 errors:0 but i cannot activate it. an the firmware seems to be loaded: [ 16.608642] Bluetooth: hci1: BCM: failed to write update baudrate (-110) [ 16.608648] Bluetooth: hci1: Failed to set baudrate [ 16.724719] Bluetooth: hci1: BCM: chip id 130 [ 16.726880] Bluetooth: hci1: BCM: features 0x0f [ 16.749908] Bluetooth: hci1: BCM4345C5 [ 16.749914] Bluetooth: hci1: BCM4345C5 (003.006.006) build 0000 [ 19.953325] Bluetooth: hci1: BCM4345C5 (003.006.006) build 0038 [ 19.954199] Bluetooth: hci1: BCM: Using default device address (43:45:c5:00:1f:ac) and the service seems to be startet: root@orangepi3:~# sudo systemctl status bluetooth.service ● bluetooth.service - Bluetooth service Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled) Active: active (running) since Tue 2020-01-14 07:38:11 UTC; 8min ago Docs: man:bluetoothd(8) Main PID: 693 (bluetoothd) Status: "Running" Tasks: 1 (limit: 2149) Memory: 4.1M CGroup: /system.slice/bluetooth.service └─693 /usr/lib/bluetooth/bluetoothd Jan 14 07:38:09 orangepi3 systemd[1]: Starting Bluetooth service... Jan 14 07:38:11 orangepi3 bluetoothd[693]: Bluetooth daemon 5.50 Jan 14 07:38:11 orangepi3 bluetoothd[693]: Starting SDP server Jan 14 07:38:11 orangepi3 systemd[1]: Started Bluetooth service. Jan 14 07:38:11 orangepi3 bluetoothd[693]: Bluetooth management interface 1.14 initialized any hints for me? Thanks in advance! Edited January 14, 2020 by hsimon806 0 Quote
megi Posted January 14, 2020 Posted January 14, 2020 8 hours ago, hsimon806 said: Hello, any hints for me? Thanks in advance! 0 Quote
hsimon806 Posted January 14, 2020 Posted January 14, 2020 Hello megi, i cannot access the link(https://megous.com/git/linux/commit/?h=opi3-5.2&id=9c296799c4d3dd90986833cfded392098c1979bd) , described in the task. I have found it somewhere else, it is working now! Simply the setting the bt mac was needed. btmgmt --index 1 public-addr 00:11:22:33:44:55 Thank you! 1 Quote
mantouboji Posted July 31, 2021 Posted July 31, 2021 I can't use BT in OPi 3 I added uart1 in armbianEnv.txt ___ ____ _ _____ / _ \| _ \(_) |___ / | | | | |_) | | |_ \ | |_| | __/| | ___) | \___/|_| |_| |____/ Welcome to Armbian 21.05.6 Hirsute with Linux 5.13.6-sunxi64 System load: 6% Up time: 3 min Memory usage: 7% of 1.94G IP: 192.168.20.50 CPU temp: 69°C Usage of /: 23% of 15G RX today: 0 B Last login: Sat Jul 31 08:20:21 2021 from fe80::18b0:75fb:8156:393%wlan0 yaofei@opip3:~$ hciconfig hci1: Type: Primary Bus: UART BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0 DOWN RX bytes:0 acl:0 sco:0 events:0 errors:0 TX bytes:14 acl:0 sco:0 commands:2 errors:0 hci0: Type: Primary Bus: SDIO BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0 DOWN RX bytes:0 acl:0 sco:0 events:0 errors:0 TX bytes:0 acl:0 sco:0 commands:0 errors:0 yaofei@opip3:~$ dmesg | grep brcm [ 6.650807] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9 [ 8.839304] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9 [ 8.839533] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available [ 8.840043] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Feb 11 2020 11:54:51 version 7.45.96.61 (be7af2d@shgit) (r745790) FWID 01-a41d86bd es7.c5.n4.a3 0 Quote
mantouboji Posted August 5, 2021 Posted August 5, 2021 On 7/31/2021 at 4:23 PM, mantouboji said: I can't use BT in OPi 3 I added uart1 in armbianEnv.txt ___ ____ _ _____ / _ \| _ \(_) |___ / | | | | |_) | | |_ \ | |_| | __/| | ___) | \___/|_| |_| |____/ Welcome to Armbian 21.05.6 Hirsute with Linux 5.13.6-sunxi64 System load: 6% Up time: 3 min Memory usage: 7% of 1.94G IP: 192.168.20.50 CPU temp: 69°C Usage of /: 23% of 15G RX today: 0 B Last login: Sat Jul 31 08:20:21 2021 from fe80::18b0:75fb:8156:393%wlan0 yaofei@opip3:~$ hciconfig hci1: Type: Primary Bus: UART BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0 DOWN RX bytes:0 acl:0 sco:0 events:0 errors:0 TX bytes:14 acl:0 sco:0 commands:2 errors:0 hci0: Type: Primary Bus: SDIO BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0 DOWN RX bytes:0 acl:0 sco:0 events:0 errors:0 TX bytes:0 acl:0 sco:0 commands:0 errors:0 yaofei@opip3:~$ dmesg | grep brcm [ 6.650807] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9 [ 8.839304] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9 [ 8.839533] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available [ 8.840043] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Feb 11 2020 11:54:51 version 7.45.96.61 (be7af2d@shgit) (r745790) FWID 01-a41d86bd es7.c5.n4.a3 sorry. Sine my GPS module attached to S-UART-TX and S-UART-RX, I added the uart1 overlay . Now I changed to GPS to UART3, remove uart1 on armbianEnv.txt , the bluetooth works well . 0 Quote
