uzert Posted May 7, 2019 Share Posted May 7, 2019 Armbianmonitor: http://ix.io/1IhH I'm trying to setup serial GSM module, but wvdial/wvdialconf can't connect to modem: WvModem<*1>: Cannot set information for serial port Manual communication (from screen, minicom) is ok, modem responds to all AT comands. Seems like wvdial can't set right baud rate or other parameters Link to comment Share on other sites More sharing options...
Igor Posted May 8, 2019 Share Posted May 8, 2019 Armbian consist from hundreds/thousands of libraries and programs which are developed by hundreds of thousands of developers. Reach out to the one(s) that deal with the application you think it doesn't work. Hardware specific forums (where Armbian people play around) "only" deal with the interface between hardware and operating system. This problem is generic. Moving to appropriate section. Link to comment Share on other sites More sharing options...
