aplastiras Posted May 7, 2019 Posted May 7, 2019 Dear All, I am running a project with Tinkerboard and a gigE camera. Trying to take video image through gstreamer (gst-launch). The camera is an Imaging source camera (DFK 33GX249) and I am using the linux library (https://github.com/TheImagingSource/tiscamera) for developing apps. My Tinkerboard is running Armbian Stretch (Armbian_5.50_Tinkerboard_Debian_stretch_next_4.14.52_desktop) Everything is working perfectly untill I am trying to run the command below: tinker@tinkerboard:~$ TCAM_LOG=DEBUG gst-launch-1.0 --gst-debug=tcamsrc:5,tcambin:5 --gst-debug-no-color tcambin ! videoconvert ! autovideosink The output is: Spoiler 0:00:00.123364982 2631 0x1eaad60 DEBUG tcambin gsttcambin.cpp:1153:gst_tcambin_init: init Setting pipeline to PAUSED ... 0:00:00.218217102 2631 0x1eaad60 INFO tcambin gsttcambin.cpp:902:gst_tcambin_change_state: NULL_TO_READY 0:00:00.218272228 2631 0x1eaad60 DEBUG tcambin gsttcambin.cpp:476:gst_tcambin_create_source: Creating source... 0:00:00.227637098 2631 0x1eaad60 INFO tcamsrc gsttcamsrc.cpp:1487:gst_tcam_src_init: Versions: Tcam: 0.10.0_master/a09794d_rev_2230 Aravis: 0.6_version_5a2f97a 0:00:00.227773306 2631 0x1eaad60 INFO tcamsrc gsttcamsrc.cpp:1540:gst_tcam_src_set_property: Set camera name to 0:00:00.227821432 2631 0x1eaad60 INFO tcamsrc gsttcamsrc.cpp:1172:gst_tcam_src_close_camera: Closing device 0:00:00.227855557 2631 0x1eaad60 DEBUG tcamsrc gsttcamsrc.cpp:1244:gst_tcam_src_change_state: State change: NULL -> READY 0:00:00.227879182 2631 0x1eaad60 INFO tcamsrc gsttcamsrc.cpp:1248:gst_tcam_src_change_state: must initialize device 0:00:00.227903390 2631 0x1eaad60 DEBUG tcamsrc gsttcamsrc.cpp:1104:gst_tcam_src_init_camera:<tcambin-source> Initializing device. 134586 <DEBUG> Logger:107: The following library versions are used: Tcam: 0.10.0_master/a09794d_rev_2230 Aravis: 0.6_version_5a2f97a 135485 <DEBUG> Logger:107: The following library versions are used: Tcam: 0.10.0_master/a09794d_rev_2230 Aravis: 0.6_version_5a2f97a 135535 <ERROR> /home/tinker/Downloads/tiscamera/src/utils.cpp:358: Could not open file "/var/lock/gige-daemon.lock" 135674 <ERROR> /home/tinker/Downloads/tiscamera/src/utils.cpp:358: Could not open file "/var/lock/gige-daemon.lock" 0:00:00.317844992 2631 0x1eaad60 DEBUG tcamsrc gsttcamsrc.cpp:1120:gst_tcam_src_init_camera:<tcambin-source> Found 1 devices. 0:00:00.317899533 2631 0x1eaad60 DEBUG tcamsrc gsttcamsrc.cpp:1128:gst_tcam_src_init_camera:<tcambin-source> No serial given. Opening first available device. 210371 <ERROR> /home/tinker/Downloads/tiscamera/src/utils.cpp:358: Could not open file "/var/lock/gige-daemon.lock" 210657 <ERROR> /home/tinker/Downloads/tiscamera/src/utils.cpp:358: Could not open file "/var/lock/gige-daemon.lock" 243575 <INFO> /home/tinker/Downloads/tiscamera/src/aravis/AravisDevice.cpp:142: Automatically set packet size to 1500 bytes 246437 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for Strobe Operation 246812 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for Strobe Polarity 246978 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for Strobe Enable 247575 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for Auto Functions ROI Preset 248594 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for Balance Ratio Selector 249202 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for Gain Auto 249903 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for Whitebalance Auto 250049 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for Whitebalance Mode 250234 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for White Balance Auto Preset 250486 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for White Balance Temperature Preset 251199 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for Offset Auto Center 252258 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for Trigger Activation 252433 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for Trigger Source 252559 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for Trigger Mode 252717 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for Trigger Selector 253228 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/aravis_utils.cpp:153: Returning EnumerationProperty for Exposure Auto 253951 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/AravisDevice.cpp:1056: Adding format desc: BayerGB8 (47524247) 254218 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/AravisDevice.cpp:1056: Adding format desc: BayerGB12Packed (50434247) 254356 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/AravisDevice.cpp:1056: Adding format desc: BayerGB16 (36314247) 254953 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/AravisDevice.cpp:183: Returning 47 properties 255047 <DEBUG> /home/tinker/Downloads/tiscamera/src/PipelineManager.cpp:127: Received 3 formats. 255138 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/AravisDevice.cpp:183: Returning 47 properties 255737 <DEBUG> /home/tinker/Downloads/tiscamera/src/PropertyHandler.cpp:273: Created 47 properties 0:00:03.608042167 2631 0x1eaad60 DEBUG tcamsrc gsttcamsrc.cpp:674:gst_tcam_src_get_all_camera_caps: Found 3 pixel formats 0:00:03.612041225 2631 0x1eaad60 INFO tcamsrc gsttcamsrc.cpp:687:gst_tcam_src_get_all_camera_caps: Device provides the following caps: video/x-bayer, format=(string)gbrg, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg12p, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg16, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 250/9 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 25/1 ]; ANY 0:00:03.612253851 2631 0x1eaad60 DEBUG tcamsrc gsttcamsrc.cpp:674:gst_tcam_src_get_all_camera_caps: Found 3 pixel formats 0:00:03.616111157 2631 0x1eaad60 INFO tcamsrc gsttcamsrc.cpp:687:gst_tcam_src_get_all_camera_caps: Device provides the following caps: video/x-bayer, format=(string)gbrg, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg12p, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg16, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 250/9 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 25/1 ]; ANY 0:00:03.617689372 2631 0x1eaad60 INFO tcamsrc gsttcamsrc.cpp:913:gst_tcam_src_get_caps: Available caps = video/x-bayer, format=(string)gbrg, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg12p, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg16, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 250/9 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 25/1 ]; ANY 0:00:03.624107522 2631 0x1eaad60 INFO tcambin gsttcambin.cpp:924:gst_tcambin_change_state: READY_TO_PAUSED 0:00:03.625562361 2631 0x1eaad60 INFO tcambin gsttcambin.cpp:952:gst_tcambin_change_state: caps of sink: video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], format=(string){ I420, YV12, YUY2, UYVY, AYUV, RGBx, BGRx, xRGB, xBGR, RGBA, BGRA, ARGB, ABGR, RGB, BGR, Y41B, Y42B, YVYU, Y444, v210, v216, NV12, NV21, NV16, NV61, NV24, GRAY8, GRAY16_BE, GRAY16_LE, v308, IYU2, RGB16, BGR16, RGB15, BGR15, UYVP, A420, RGB8P, YUV9, YVU9, IYU1, ARGB64, AYUV64, r210, I420_10LE, I420_10BE, I422_10LE, I422_10BE, Y444_10LE, Y444_10BE, GBR, GBR_10LE, GBR_10BE, NV12_64Z32, A420_10LE, A420_10BE, A422_10LE, A422_10BE, A444_10LE, A444_10BE, P010_10LE, P010_10BE }; video/x-raw(ANY), format=(string){ I420, YV12, YUY2, UYVY, AYUV, RGBx, BGRx, xRGB, xBGR, RGBA, BGRA, ARGB, ABGR, RGB, BGR, Y41B, Y42B, YVYU, Y444, v210, v216, NV12, NV21, NV16, NV61, NV24, GRAY8, GRAY16_BE, GRAY16_LE, v308, IYU2, RGB16, BGR16, RGB15, BGR15, UYVP, A420, RGB8P, YUV9, YVU9, IYU1, ARGB64, AYUV64, r210, I420_10LE, I420_10BE, I422_10LE, I422_10BE, Y444_10LE, Y444_10BE, GBR, GBR_10LE, GBR_10BE, NV12_64Z32, A420_10LE, A420_10BE, A422_10LE, A422_10BE, A444_10LE, A444_10BE, P010_10LE, P010_10BE }, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ] 0:00:03.626761115 2631 0x1eaad60 INFO tcamsrc gsttcamsrc.cpp:913:gst_tcam_src_get_caps: Available caps = video/x-bayer, format=(string)gbrg, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg12p, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg16, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 250/9 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 25/1 ]; ANY 0:00:03.626938158 2631 0x1eaad60 INFO tcambin gsttcambin.cpp:956:gst_tcambin_change_state: caps of src: video/x-bayer, format=(string)gbrg, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg12p, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg16, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 250/9 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 25/1 ]; ANY 0:00:03.629526126 2631 0x1eaad60 INFO tcambin gsttcambin.cpp:598:gst_tcambin_create_elements: creating elements 276348 <INFO> /home/tinker/Downloads/tiscamera/src/gstreamer-1.0/tcamgstbase.cpp:630: Fixating assumed largest caps: video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 } 0:00:03.631418759 2631 0x1eaad60 INFO tcambin gsttcambin.cpp:630:gst_tcambin_create_elements: Caps were not fixed. Reduced to: video/x-bayer, framerate=(fraction)30/1, width=(int)1920, height=(int)1200, format=(string)gbrg 0:00:03.632585722 2631 0x1eaad60 INFO tcamsrc gsttcamsrc.cpp:913:gst_tcam_src_get_caps: Available caps = video/x-bayer, format=(string)gbrg, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg12p, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg16, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 250/9 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 25/1 ]; ANY 0:00:03.634108227 2631 0x1eaad60 INFO tcamsrc gsttcamsrc.cpp:913:gst_tcam_src_get_caps: Available caps = video/x-bayer, format=(string)gbrg, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg12p, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg16, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 250/9 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 25/1 ]; ANY 0:00:03.634609896 2631 0x1eaad60 DEBUG tcambin gsttcambin.cpp:575:create_and_add_element: Adding bayer2rgb(0x1fd8888) to pipeline 0:00:03.635752067 2631 0x1eaad60 INFO tcamsrc gsttcamsrc.cpp:913:gst_tcam_src_get_caps: Available caps = video/x-bayer, format=(string)gbrg, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg12p, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg16, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 250/9 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 25/1 ]; ANY 0:00:03.637298782 2631 0x1eaad60 INFO tcamsrc gsttcamsrc.cpp:913:gst_tcam_src_get_caps: Available caps = video/x-bayer, format=(string)gbrg, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg12p, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg16, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 250/9 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 25/1 ]; ANY 0:00:03.637795784 2631 0x1eaad60 INFO tcambin gsttcambin.cpp:774:gst_tcambin_create_elements: Using tcambin-debayer as exit element for internal pipeline 0:00:03.637828742 2631 0x1eaad60 INFO tcambin gsttcambin.cpp:776:gst_tcambin_create_elements: Internal pipeline: tcamsrc ! video/x-bayer, framerate=(fraction)30/1, width=(int)1920, height=(int)1200, format=(string)gbrg ! bayer2rgb 0:00:03.637925284 2631 0x1eaad60 INFO tcambin gsttcambin.cpp:784:gst_tcambin_create_elements: Working with exit caps: video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], format=(string){ I420, YV12, YUY2, UYVY, AYUV, RGBx, BGRx, xRGB, xBGR, RGBA, BGRA, ARGB, ABGR, RGB, BGR, Y41B, Y42B, YVYU, Y444, v210, v216, NV12, NV21, NV16, NV61, NV24, GRAY8, GRAY16_BE, GRAY16_LE, v308, IYU2, RGB16, BGR16, RGB15, BGR15, UYVP, A420, RGB8P, YUV9, YVU9, IYU1, ARGB64, AYUV64, r210, I420_10LE, I420_10BE, I422_10LE, I422_10BE, Y444_10LE, Y444_10BE, GBR, GBR_10LE, GBR_10BE, NV12_64Z32, A420_10LE, A420_10BE, A422_10LE, A422_10BE, A444_10LE, A444_10BE, P010_10LE, P010_10BE }; video/x-raw(ANY), format=(string){ I420, YV12, YUY2, UYVY, AYUV, RGBx, BGRx, xRGB, xBGR, RGBA, BGRA, ARGB, ABGR, RGB, BGR, Y41B, Y42B, YVYU, Y444, v210, v216, NV12, NV21, NV16, NV61, NV24, GRAY8, GRAY16_BE, GRAY16_LE, v308, IYU2, RGB16, BGR16, RGB15, BGR15, UYVP, A420, RGB8P, YUV9, YVU9, IYU1, ARGB64, AYUV64, r210, I420_10LE, I420_10BE, I422_10LE, I422_10BE, Y444_10LE, Y444_10BE, GBR, GBR_10LE, GBR_10BE, NV12_64Z32, A420_10LE, A420_10BE, A422_10LE, A422_10BE, A444_10LE, A444_10BE, P010_10LE, P010_10BE }, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ] Pipeline is live and does not need PREROLL ... WARNING: from element /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0: Could not initialise Xv output Additional debug info: xvimagesink.c(1760): gst_xv_image_sink_open (): /GstXvImageSink:autovideosink0-actual-sink-xvimage: Could not open display (null) INFO: Working with src caps: video/x-bayer, framerate=(fraction)30/1, width=(int)1920, height=(int)1200, format=(string)gbrg Setting pipeline to PLAYING ... New clock: GstSystemClock 0:00:03.639916208 2631 0x1fba6f0 INFO tcamsrc gsttcamsrc.cpp:913:gst_tcam_src_get_caps: Available caps = video/x-bayer, format=(string)gbrg, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg12p, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg16, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 250/9 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 25/1 ]; ANY 0:00:03.640072834 2631 0x1fba6f0 DEBUG tcamsrc gsttcamsrc.cpp:703:gst_tcam_src_negotiate:<tcambin-source> caps of src: video/x-bayer, format=(string)gbrg, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg12p, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg12p, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 30/1 ]; video/x-bayer, format=(string)gbrg16, width=(int)480, height=(int)4, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)544, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)640, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)576, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)720, height=(int)480, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)960, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1280, height=(int)720, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1440, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 30/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1080, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 250/9 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)1920, height=(int)1200, framerate=(fraction){ 1375/1344, 2/1, 3/1, 4/1, 5/1, 6/1, 7/1, 8/1, 9/1, 10/1, 11/1, 12/1, 13/1, 14/1, 15/1, 16/1, 17/1, 18/1, 19/1, 20/1, 25/1 }; video/x-bayer, format=(string)gbrg16, width=(int)[ 480, 1920 ], height=(int)[ 4, 1200 ], framerate=(fraction)[ 1375/1344, 25/1 ]; ANY 0:00:03.643406597 2631 0x1fba6f0 DEBUG tcamsrc gsttcamsrc.cpp:712:gst_tcam_src_negotiate:<tcambin-source> caps of peer: video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction)30/1 0:00:03.643430806 2631 0x1fba6f0 DEBUG tcamsrc gsttcamsrc.cpp:716:gst_tcam_src_negotiate: Peer gave us something to work with. 0:00:03.643457931 2631 0x1fba6f0 DEBUG tcamsrc gsttcamsrc.cpp:736:gst_tcam_src_negotiate:<tcambin-source> peer: video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction)30/1 0:00:03.643541348 2631 0x1fba6f0 DEBUG tcamsrc gsttcamsrc.cpp:747:gst_tcam_src_negotiate:<tcambin-source> intersect: video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction)30/1 0:00:03.643647806 2631 0x1fba6f0 DEBUG tcamsrc gsttcamsrc.cpp:1460:gst_tcam_src_fixate_caps:<tcambin-source> Fixated caps to video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction)30/1 0:00:03.643668806 2631 0x1fba6f0 DEBUG tcamsrc gsttcamsrc.cpp:862:gst_tcam_src_negotiate:<tcambin-source> fixated to: video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction)30/1 0:00:03.643695057 2631 0x1fba6f0 DEBUG tcamsrc gsttcamsrc.cpp:926:gst_tcam_src_set_caps: In tcam_set_caps 0:00:03.643707015 2631 0x1fba6f0 INFO tcamsrc gsttcamsrc.cpp:938:gst_tcam_src_set_caps: Requested caps = video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction)30/1 290160 <INFO> /home/tinker/Downloads/tiscamera/src/ImageSource.cpp:68: Source changed to state STOPPED 290465 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/AravisDevice.cpp:409: Setting format to 'format=GBRG,width=1920,height=1200,framerate=30,000000' 0:00:03.655948604 2631 0x1fba6f0 DEBUG tcamsrc gsttcamsrc.cpp:983:gst_tcam_src_set_caps:<tcambin-source> Frame rate = 30 Hz 0:00:03.656001688 2631 0x1fba6f0 INFO tcamsrc gsttcamsrc.cpp:1018:gst_tcam_src_set_caps: Start acquisition 291825 <DEBUG> /home/tinker/Downloads/tiscamera/src/PipelineManager.cpp:222: Found device fourcc 'GBRG' - 1196573255 291860 <DEBUG> /home/tinker/Downloads/tiscamera/src/PipelineManager.cpp:222: Found device fourcc 'GB12 Packed' - 1346585159 291879 <DEBUG> /home/tinker/Downloads/tiscamera/src/PipelineManager.cpp:222: Found device fourcc 'GB16' - 909197895 291913 <DEBUG> /home/tinker/Downloads/tiscamera/src/aravis/AravisDevice.cpp:409: Setting format to 'format=GBRG,width=1920,height=1200,framerate=30,000000' 292989 <INFO> /home/tinker/Downloads/tiscamera/src/MemoryBuffer.cpp:38: allocating data buffer 293070 <INFO> /home/tinker/Downloads/tiscamera/src/MemoryBuffer.cpp:38: allocating data buffer 293112 <INFO> /home/tinker/Downloads/tiscamera/src/MemoryBuffer.cpp:38: allocating data buffer 293162 <INFO> /home/tinker/Downloads/tiscamera/src/MemoryBuffer.cpp:38: allocating data buffer 293196 <INFO> /home/tinker/Downloads/tiscamera/src/MemoryBuffer.cpp:38: allocating data buffer 293231 <INFO> /home/tinker/Downloads/tiscamera/src/MemoryBuffer.cpp:38: allocating data buffer 293263 <INFO> /home/tinker/Downloads/tiscamera/src/MemoryBuffer.cpp:38: allocating data buffer 293295 <INFO> /home/tinker/Downloads/tiscamera/src/MemoryBuffer.cpp:38: allocating data buffer 293325 <INFO> /home/tinker/Downloads/tiscamera/src/MemoryBuffer.cpp:38: allocating data buffer 293359 <INFO> /home/tinker/Downloads/tiscamera/src/MemoryBuffer.cpp:38: allocating data buffer 293398 <INFO> /home/tinker/Downloads/tiscamera/src/PipelineManager.cpp:502: Pipeline creation successful. 293417 <INFO> /home/tinker/Downloads/tiscamera/src/PipelineManager.cpp:512: source -> sink 293432 <INFO> /home/tinker/Downloads/tiscamera/src/ImageSink.cpp:51: Pipeline started playing 294862 <INFO> /home/tinker/Downloads/tiscamera/src/aravis/AravisDevice.cpp:588: Starting actual stream... 295389 <DEBUG> /home/tinker/Downloads/tiscamera/src/ImageSource.cpp:57: PLAYING.... 295414 <INFO> /home/tinker/Downloads/tiscamera/src/PipelineManager.cpp:83: All pipeline elements set to PLAYING. 0:00:03.704468710 2631 0x1fba6f0 INFO tcamsrc gsttcamsrc.cpp:1033:gst_tcam_src_set_caps: Successfully set caps to: video/x-bayer, format=(string)gbrg, width=(int)1920, height=(int)1200, framerate=(fraction)30/1 305275 <WARNING> /home/tinker/Downloads/tiscamera/src/aravis/AravisDevice.cpp:723: Timeout has been reached before all packets were received Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1094.891597] Internal error: Oops: 5 [#1] PREEMPT SMP ARM Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1094.991743] Process swapper/2 (pid: 0, stack limit = 0xee97a218) Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1094.998450] Stack: (0xee97bd50 to 0xee97c000) Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.003311] bd40: 0000c354 f0867000 000000cc cccccea0 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.012447] bd60: 00000fff ef3e5ba0 0000002a 00000728 eb981780 edb5c048 eb981780 00000000 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.021582] bd80: c1408174 eb981838 edb5c000 c14069cc ee97bdfc ee97bda0 c0af78d0 c0ae8990 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.030710] bda0: ee97bdbc edb5c05c 00000008 eb981780 20070193 c0d7143c ee97bddc ee97bdc8 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.039846] bdc0: c0d7143c c0148238 eedb6880 20070193 ee97bdfc eedbaf80 eb981780 00000008 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.048982] bde0: 00000000 00000040 eedbaf6c eedbae88 ee97be14 ee97be00 c0af9674 c0af6df8 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.058110] be00: eedbaf80 eb981780 ee97be44 ee97be18 c0af9724 c0af95f8 c0af9680 eedbaf80 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.067236] be20: eedbae80 c13e5e80 2d9d5000 00000001 00000101 00000040 ee97be8c ee97be48 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.076364] be40: c0afd6d0 c0af968c 000c20f0 0000012c ee97be50 ee97be50 ee97be58 ee97be58 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.085500] be60: ffffe000 c140208c ffffe000 00000003 00000008 0000000a 00000101 c1402080 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.094627] be80: ee97bed4 ee97be90 c0101750 c0afd5cc 00000000 c13e50b0 00000003 00000004 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.103763] bea0: 000c20f0 00200042 ee97bec4 c13e50b0 00000003 c13e50b0 c14ea8e8 00000000 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.112890] bec0: 00000002 00000000 ee97bee4 ee97bed8 c01270b4 c01014ec ee97bf14 ee97bee8 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.122017] bee0: c010ed28 c0127020 00000c03 f0802000 c1405ce0 ee97bf40 c1479ce8 f0803000 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.131145] bf00: ee97a000 00000000 ee97bf3c ee97bf18 c01014d4 c010ebc0 c01083f8 60070013 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.140280] bf20: ffffffff ee97bf74 0000406a ee97a000 ee97bf9c ee97bf40 c010cccc c010144c Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.149408] bf40: 00000001 00000000 00000000 c011b9c0 00000000 00000000 ffffe000 c1405568 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.158535] bf60: 0000406a 410fc0d1 00000000 ee97bf9c ee97bfa0 ee97bf90 c0108408 c01083f8 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.167662] bf80: 60070013 ffffffff 00000051 00000000 ee97bfac ee97bfa0 c0d71304 c01083d8 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.176798] bfa0: ee97bfcc ee97bfb0 c0164b28 c0d712d8 00000084 00000002 10c0387d c14fe7c0 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.185925] bfc0: ee97bfdc ee97bfd0 c0164eac c0164a2c ee97bff4 ee97bfe0 c010e944 c0164e90 Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.195052] bfe0: 2e96c06a 00000051 00000000 ee97bff8 0010192c c010e838 ffffffff ffffffff Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.365267] Code: e50b103c e0030392 e598202c e0820003 (e7923003) Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1095.377260] Kernel panic - not syncing: Fatal exception in interrupt In general the system crashes but I dont know why. I need to know if it because insufficient system resources or from own my fault. How can I cross check something like that? Is there any info in the above results that I can use for starting searching? Can anyone please help me? Thank you in advance Apostolos
aplastiras Posted May 8, 2019 Author Posted May 8, 2019 Hello again, looking at the debug results i notices that the warning comes and the stack limit is mentioned. 305275 <WARNING> /home/tinker/Downloads/tiscamera/src/aravis/AravisDevice.cpp:723: Timeout has been reached before all packets were received Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1094.891597] Internal error: Oops: 5 [#1] PREEMPT SMP ARM Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1094.991743] Process swapper/2 (pid: 0, stack limit = 0xee97a218) Message from syslogd@localhost at May 7 19:48:25 ... kernel:[ 1094.998450] Stack: (0xee97bd50 to 0xee97c000) Does this give any clue for the problem? Is there a limit that can be changed? Thank you in advance Apostolow
Igor Posted May 8, 2019 Posted May 8, 2019 7 minutes ago, aplastiras said: Is there a limit that can be changed? Switch to stock kernel (default). Multimedia support is better there ... if this is the problem.
