Armbianmonitor:
I wanted to test wireguard with my cubox i4, but I'm not able to load the module.
I tried to search the net for this error, but fond nothing useful.
Maybe someone has an idea.
Thank you
Michael
uname -a
Linux loki 4.19.41-cubox #5.85 SMP Wed May 8 15:52:55 CEST 2019 armv7l GNU/Linux
dpkg -l | grep linux
ii  console-setup-linux              1.164                              all          Linux specific part of console-setup
ii  libselinux1:armhf                2.6-3+b3                           armhf        SELinux runtime shared libraries
ii  linux-base                       4.5                                all          Linux image base package
ii  linux-dtb-next-cubox             5.85                               armhf        Linux DTB, version 4.19.41-cubox
ii  linux-headers-next-cubox         5.85                               armhf        Linux kernel headers for 4.19.41-cubox on armhf
ii  linux-image-next-cubox           5.85                               armhf        Linux kernel, version 4.19.41-cubox
ii  linux-libc-dev                   5.70                               armhf        Linux support headers for userspace development
ii  linux-stretch-root-next-cubox-i  5.85                               armhf        Armbian tweaks for stretch on cubox-i (next branch)
ii  linux-u-boot-cubox-i-next        5.85                               armhf        Uboot loader 2013.10-rc4
ii  util-linux                       2.29.2-1+deb9u1                    armhf        miscellaneous system utilities
modprobe wireguard
modprobe: ERROR: could not insert 'wireguard': Exec format error
dmesg | grep wireguard
[320752.917616] wireguard: unknown relocation: 102
modinfo wireguard
filename:       /lib/modules/4.19.41-cubox/kernel/net/wireguard/wireguard.ko
alias:          net-pf-16-proto-16-family-wireguard
alias:          rtnl-link-wireguard
version:        0.0.20190406
author:         Jason A. Donenfeld <Jason@zx2c4.com>
description:    WireGuard secure network tunnel
license:        GPL v2
srcversion:     9996946C3FF07EF91C1E1DA
depends:
intree:         Y
vermagic:       4.19.41-cubox SMP mod_unload modversions ARMv7 thumb2 p2v8
Are you able to build a kernel on your own? Build a fresh kernel with parameter WIREGUARD="yes" ... it is known to work on our most used Allwinner kernel.
Sorry for ma late answer.
But at the moment I sadly have no time to build my own kernel.
I'll try it with the next update.
Hi, I tried it with the new " 5.1.16-cubox #5.90 SMP Sun Jul 7 11:37:47 CEST 2019 armv7l GNU/Linux" kernel, but still the same problem.
I also tried to build the module with dkms with the wireguard package from debian sid, but the build fails. Here is the logfile of the build.
 cat /var/lib/dkms/wireguard/0.0.20190702/build/make.log
DKMS make.log for wireguard-0.0.20190702 for kernel 5.1.16-cubox (armv7l)
Wed Jul 10 23:21:13 CEST 2019
make: Entering directory '/usr/src/linux-headers-5.1.16-cubox'
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/main.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/noise.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/device.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/peer.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/timers.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/queueing.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/send.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/receive.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/socket.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/peerlookup.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/allowedips.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/ratelimiter.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/cookie.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/netlink.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/chacha20/chacha20.o
  PERLASM /var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/chacha20/chacha20-arm.S
  AS [M]  /var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/chacha20/chacha20-unrolled-arm.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/poly1305/poly1305.o
  PERLASM /var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/poly1305/poly1305-arm.S
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/chacha20poly1305.o
  CC [M]  /var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/blake2s/blake2s.o
/bin/sh: 1: scripts/genksyms/genksyms: not found
scripts/Makefile.build:275: recipe for target '/var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/poly1305/poly1305.o' failed
make[1]: *** [/var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/poly1305/poly1305.o] Error 127
make[1]: *** Deleting file '/var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/poly1305/poly1305.o'
make[1]: *** Waiting for unfinished jobs....
scripts/Makefile.build:275: recipe for target '/var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/chacha20/chacha20.o' failed
make[1]: *** [/var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/chacha20/chacha20.o] Error 127
make[1]: *** Deleting file '/var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/chacha20/chacha20.o'
scripts/Makefile.build:275: recipe for target '/var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/chacha20poly1305.o' failed
make[1]: *** [/var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/chacha20poly1305.o] Error 127
make[1]: *** Deleting file '/var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/chacha20poly1305.o'
scripts/Makefile.build:275: recipe for target '/var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/blake2s/blake2s.o' failed
make[1]: *** [/var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/blake2s/blake2s.o] Error 127
make[1]: *** Deleting file '/var/lib/dkms/wireguard/0.0.20190702/build/crypto/zinc/blake2s/blake2s.o'
Makefile:1571: recipe for target '_module_/var/lib/dkms/wireguard/0.0.20190702/build' failed
make: *** [_module_/var/lib/dkms/wireguard/0.0.20190702/build] Error 2
make: Leaving directory '/usr/src/linux-headers-5.1.16-cubox'
What about modprobe wireguard since module should be build into the kernel?
DKMS could need some fine tuning ...
Same problem on hummingboard i2ex (running -cubox kernel) both on kernel 4.14 and 5.1. Built-in module doesn't work - throws this exec format error.
DKMS on 4.14 says that it built identical module to one shipped with kernel. I removed wireguard from /lib/modules, run depmod and installed wireguard -> no luck.
On 5.1 fails to build scripts/ in headers (won't build at all), like headers are broken. Self-built module from linux-source-next-cubox after make oldconfig fails in the same way (Exec format error).
Found older versions of wireguard sources -> wireguard-dkms_0.0.20190406-1_all.deb and wireguard-dkms_0.0.20190227-1_all.deb,  nothing changed.
Trying to load module pops "wireguard: unknown relocation: 102" in dmesg.
filename:       /lib/modules/4.14.132-cubox/kernel/net/wireguard/wireguard.ko
version:        0.0.20190702
license:        GPL v2
srcversion:     721C4EEB0529AC764DAD357
depends:
intree:         Y
vermagic:       4.14.132-cubox SMP mod_unload modversions ARMv7 thumb2 p2v8
filename:       /lib/modules/4.14.132-cubox/updates/dkms/wireguard.ko
license:        GPL v2
depends:
version:        0.0.20190227
license:        GPL v2
srcversion:     17F2A236FAA55F91E7B0A56
depends:
Edited by kitor
We need to fix kernel recompilation first. I tried to build 5.2.y and 5.3.y yesterday, but could not boot the board ... will debug perhaps later today or next week. Then Wireguard.
WG works, thanks!
Yesterday I noticed that at least on 4.14 GPIOs doesn't work for me (exports, sets direction without errors, but real output on pins won't change) , but that's story for another thread. I used oldstable (with kernel 3.14.79-cubox) until yesterday so I just found that - need to investigate first.
