Armbianmonitor:
Hi all,
In the review of the Fire3
at least one person mentions powering this board via something other than the MicroUSB. This would allow me to use the serial console that's supposedly exposed over that port instead of wiring up yet another USB to serial converter.
What I can't work out is a) which pin/s are used to power it, and b) what kind of power supply is used. I'd rather not fry the board (it'll do that itself under load) so can someone point me in the right direction?
Thanks in advance.
You can power at the debug part but you need to solder pads since they are not there by default. See picture:
Expand
Are you talking about the pads labeled Power Key Jumper?
No, DBG-serial. Pins are probably not soldered, while on the picture they are.
