Recently I have discovered bug in kernel or maybe iptables with using Huawei E3372h LTE Hi-Link USB dongle (or maybe other devices which exposes HTTP interfaces over cdc_ether). Odroid enters into kernel panic and reboot.
I am using ARMBIAN 5.85 stable Debian GNU/Linux 9 (stretch) 4.19.42-meson64.
kernel:[   60.801868] Internal error: Oops: 96000004 [#1] PREEMPT SMP
The steps to recreate the bug:
1) disable or remove NetworkManager, use only IPv4,
2) set network interfaces in /etc/network/interfaces
source /etc/network/interfaces.d/*
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet static
        address 10.0.0.1
        netmask 255.255.255.0
allow-hotplug enxXXX
iface enxXXX inet dhcp
enxXXX - is example name of your E3372h (virtual?) ethernet interface.
3) check settings in /etc/sysctl.conf - you need have some routing capabilites on - mine is:
kernel.printk = 3 4 1 3
net.ipv4.conf.default.rp_filter=1
net.ipv4.conf.all.rp_filter=1
net.ipv4.tcp_syncookies=1
net.ipv4.ip_forward=1
net.ipv4.conf.all.accept_redirects = 0
net.ipv6.conf.all.accept_redirects = 0
net.ipv4.conf.all.secure_redirects = 0
net.ipv4.conf.all.send_redirects = 0
net.ipv4.conf.all.accept_source_route = 0
net.ipv6.conf.all.accept_source_route = 0
net.ipv6.conf.all.disable_ipv6=1
net.ipv4.icmp_echo_ignore_broadcasts=1
net.ipv4.icmp_echo_ignore_all=1
vm.swappiness=100
4) set iptables rules to forward packets between local eth0 and usb dongle ethernet:
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
-A POSTROUTING -o enxXXX -j MASQUERADE
COMMIT
*filter
:INPUT DROP [0:0]
:FORWARD DROP [0:0]
:OUTPUT DROP [0:0]
:interfaces - [0:0]
:open - [0:0]
-A INPUT -m conntrack --ctstate ESTABLISHED -j ACCEPT
-A INPUT -j interfaces
-A INPUT -j open
-A INPUT -j DROP
-A FORWARD -i enxXXX -o eth0 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -i eth0 -o enxXXX -p tcp -m multiport --dports 80,443,9001,9111,3690 -j ACCEPT
-A FORWARD -i eth0 -o enxXXX -p icmp -m icmp --icmp-type 8 -j ACCEPT
-A FORWARD -j DROP
-A OUTPUT -j ACCEPT
-A interfaces -i lo -j ACCEPT
COMMIT
5) connect to local eth0 other computer (set static IP to eg. 10.0.0.2, netmask 255.255.255.0 and gateway 10.0.0.1),
6) from other computer you should be able to ping E3372h eth interface: 192.168.8.1,
7) open web browser (I have Firefox) - enter address: http://192.168.8.1
8) after 5-10 seconds kernel panic occurs
9) after reboot there is a green background on screen via HDMI (need to hard power off and on to start without green screen).
I have attached two fotos: 1 - kernel oops messages; 2 - green screen.
Has anyone had a similar problem?
