maesstrissimo Posted April 22, 2016 Share Posted April 22, 2016 Good evening. I've just installed Armbian in a OPI +2, in a 32 Gb card. The OPI is connected by LAN to my router, in the same way the PC I am using to write this message is. But "Wicd Entwork Manager" says : - "not connected" after "Obtaining IP address" if using wire-default profile. - "done connecting" after "setting IP address " id using a fix IP address setting profile, but in fact, there is no connection. Has anybody faced something like this ? Any idea ? Best regards. maesstrissimo Link to comment Share on other sites More sharing options...
Igor Posted April 23, 2016 Share Posted April 23, 2016 We haven't touch the wireless driver yet ... it's the same as in original source. Possible broken. Link to comment Share on other sites More sharing options...
maesstrissimo Posted April 28, 2016 Author Share Posted April 28, 2016 Hi, Igor, and thanks for your answer. Concerning wifi, I have checked that if I open mi home wireless lan, OP+2 connects and gets IP address. But using wpa2 protocol, OPI+2 and router don't understand themselves. But my original question as about Ethernet. I plug the wire in the OPI+2, but it doesn't get IP address. Best regards. Link to comment Share on other sites More sharing options...
Igor Posted April 29, 2016 Share Posted April 29, 2016 I made an driver update and change one wicd settings. Now it works fine, also to WPA2 AP ... but we need some real world testing to be sure. https://github.com/igorpecovnik/lib/commit/303ace0b48f2f956ba70431cf27f65b990bb0be8 https://github.com/igorpecovnik/lib/commit/dec2e54b062ac9086d8bcd073508183372d3c990 But my original question as about Ethernet. I plug the wire in the OPI+2, but it doesn't get IP address Default settings does not allow this - IP is obtained when adapter goes up @boot time or manually. You need to either use a network manager or so called Laptop-Mode: https://wiki.debian.org/Bonding Link to comment Share on other sites More sharing options...
maesstrissimo Posted April 29, 2016 Author Share Posted April 29, 2016 Hi Igor. First of all, thank you for your answer, and thanks for the modifications added to wicd settings as well. I hope test will be satisfying and they will be available soon. Regarding my ethernet issue, OPI+2 doesn't get IP Address neither if LAN wire plugged before boot not if I demand wicd to connect to the wired network once the system launched. Best regards Maesstrissimo Link to comment Share on other sites More sharing options...
maesstrissimo Posted May 7, 2016 Author Share Posted May 7, 2016 Hi Because of the Security issue alerted by tkaiser, I've installed the latest available img ( 3.4.112 ), compiled with the WIFI patch in. It works perfect, even with WPA2. Great job, Igor ! Thanks a lot ! Maesstrissimo. Link to comment Share on other sites More sharing options...
ARMgunnaservu Posted July 3, 2016 Share Posted July 3, 2016 how do i use these patches to fix wpa2? Link to comment Share on other sites More sharing options...
Igor Posted July 3, 2016 Share Posted July 3, 2016 Go to WICD settings / advanced settings / security or something like this and change wpa driver to none. Link to comment Share on other sites More sharing options...
ARMgunnaservu Posted July 3, 2016 Share Posted July 3, 2016 I guess I'll have to learn how to compile my own script.bin or kernel, I don't know where the problem actually is. Link to comment Share on other sites More sharing options...
UnixOutlaw Posted November 1, 2016 Share Posted November 1, 2016 I actually removed wicd (and associated packages) and installed network-manager and network-manager-gnome... Not a big fan of wicd... I just keep connection entries in /etc/NetworkManager/system-connections/ for the various Networks I join... e.g. One for a Corporate / Enterprise SSID - couldn't connect to it using wicd (file originally created on an amd64 Ubuntu 15.10 machine) - wasn't able to generate the file using either wicd or NetworkManager - but I had the file handy... Just had to remove the MAC address (as seems to get a different MAC address on boot each time - on wlan0, OPi+ 2E). Link to comment Share on other sites More sharing options...
