malaga Posted June 6, 2019 Posted June 6, 2019 hello dear Armbian-experts, How to do a command line test of a connection remotely well - there are several ways to test the DB connection remotely, while the access of the MySQL server from another Linux® server. See - for example the following - that uses 44.55.22.11 as the IP address of the MySQL server: # mysql -u fooUser -p -h 44.55.22.11 Enter password: Welcome to the MySQL monitor. Commands end with ; or \g. Your MySQL connection id is 17 Server version: 5.0.45 Source distribution Type 'help;' or '\h' for help. Type '\c' to clear the buffer. mysql> _ some musings: When you set up a remote user, consider the following information: A local user is of course very very different from a remote user. For example, we can say fooUser@localhost is not the same as fooUser@1.2.3.4.5.6.7.8 If we will want both users to have the same permissions, we need to duplicate permissions. Well we have to admit that it is a fact that we cannot recommend granting ALL permissions. For standard users, we recommend granting GRANT SELECT,INSERT,UPDATE,DELETE permissions. Honestly - to speak frankly: To grant access to only a specific table, we can use the database.table command. some examples: Lemme give soom Examples; let us take for example, in the preceding step, you could use fooDatabase.fooTable instead of fooDatabase. what do you say..!?
martinayotte Posted June 6, 2019 Posted June 6, 2019 3 minutes ago, malaga said: what do you say..!? I don't see anything here related to Armbian ...
lanefu Posted June 15, 2019 Posted June 15, 2019 hello dear Armbian-experts, How to do a command line test of a connection remotely well - there are several ways to test the DB connection remotely, while the access of the MySQL server from another Linux server. See - for example the following - that uses 44.55.22.11 as the IP address of the MySQL server: # mysql -u fooUser -p -h 44.55.22.11Enter password:Welcome to the MySQL monitor. Commands end with ; or \g.Your MySQL connection id is 17Server version: 5.0.45 Source distributionType 'help;' or '\h' for help. Type '\c' to clear the buffer.mysql> _ some musings: When you set up a remote user, consider the following information: A local user is of course very very different from a remote user. For example, we can say fooUser@localhost is not the same as fooUser@1.2.3.4.5.6.7.8 If we will want both users to have the same permissions, we need to duplicate permissions. Well we have to admit that it is a fact that we cannot recommend granting ALL permissions. For standard users, we recommend granting GRANT SELECT,INSERT,UPDATE,DELETE permissions. Honestly - to speak frankly: To grant access to only a specific table, we can use the database.table command. some examples: Lemme give soom Examples; let us take for example, in the preceding step, you could use fooDatabase.fooTable instead of fooDatabase. what do you say..!? Try stack overflow or a forum in your native languages for questions like this Sent from my iPad using Tapatalk
