malaga Posted June 6, 2019 Share Posted June 6, 2019 hello dear Armbian-experts, How to do a command line test of a connection remotely well - there are several ways to test the DB connection remotely, while the access of the MySQL server from another Linux® server. See - for example the following - that uses 44.55.22.11 as the IP address of the MySQL server: # mysql -u fooUser -p -h 44.55.22.11 Enter password: Welcome to the MySQL monitor. Commands end with ; or \g. Your MySQL connection id is 17 Server version: 5.0.45 Source distribution Type 'help;' or '\h' for help. Type '\c' to clear the buffer. mysql> _ some musings: When you set up a remote user, consider the following information: A local user is of course very very different from a remote user. For example, we can say fooUser@localhost is not the same as fooUser@1.2.3.4.5.6.7.8 If we will want both users to have the same permissions, we need to duplicate permissions. Well we have to admit that it is a fact that we cannot recommend granting ALL permissions. For standard users, we recommend granting GRANT SELECT,INSERT,UPDATE,DELETE permissions. Honestly - to speak frankly: To grant access to only a specific table, we can use the database.table command. some examples: Lemme give soom Examples; let us take for example, in the preceding step, you could use fooDatabase.fooTable instead of fooDatabase. what do you say..!? Link to comment Share on other sites More sharing options...
martinayotte Posted June 6, 2019 Share Posted June 6, 2019 3 minutes ago, malaga said: what do you say..!? I don't see anything here related to Armbian ... Link to comment Share on other sites More sharing options...
lanefu Posted June 15, 2019 Share Posted June 15, 2019 hello dear Armbian-experts, How to do a command line test of a connection remotely well - there are several ways to test the DB connection remotely, while the access of the MySQL server from another Linux server. See - for example the following - that uses 44.55.22.11 as the IP address of the MySQL server: # mysql -u fooUser -p -h 44.55.22.11Enter password:Welcome to the MySQL monitor. Commands end with ; or \g.Your MySQL connection id is 17Server version: 5.0.45 Source distributionType 'help;' or '\h' for help. Type '\c' to clear the buffer.mysql> _ some musings: When you set up a remote user, consider the following information: A local user is of course very very different from a remote user. For example, we can say fooUser@localhost is not the same as fooUser@1.2.3.4.5.6.7.8 If we will want both users to have the same permissions, we need to duplicate permissions. Well we have to admit that it is a fact that we cannot recommend granting ALL permissions. For standard users, we recommend granting GRANT SELECT,INSERT,UPDATE,DELETE permissions. Honestly - to speak frankly: To grant access to only a specific table, we can use the database.table command. some examples: Lemme give soom Examples; let us take for example, in the preceding step, you could use fooDatabase.fooTable instead of fooDatabase. what do you say..!? Try stack overflow or a forum in your native languages for questions like this Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
