fips Posted June 25, 2015 Posted June 25, 2015 Hello, I used your newest Debian wheezy Image 3.8. Boot up from SD installed to NAND via script so far everything fine. But if I remove the SD card it won't boot anymore, it even doesn't show some output on serial connection. Can you give me a hint how to solve it? Thanks Fips
Igor Posted June 26, 2015 Posted June 26, 2015 NAND install (3.4.x only) script sometime fails. Dirty but working workaround – installing Lubuntu to NAND with Phoenix tools and run the nand-install again. Better solution is under development. Perhaps it's this?
